Old 09-06-2017, 07:22 PM   #43
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by LudwigMiles View Post
Just because they didn't bend, it doesn't mean the V jackstands did anything. All the weight is still on the weld, genius.
You might as well just use flat jackstands. Same thing.
So what is your point? You said the welds will fold, I'm telling you they won't.
Genius.
Old 09-06-2017, 11:28 PM   #44
palanza87
Drives: 06 Ford Mustang
hm i just avoid the pinch weld altogether and put the jack stand the other way parallel to the weld inside the seam against the body. I think would be sorta dumb to put the pressure on the narrow seam itself.
Genius.
Having really looked at the welds, they are not as solid as you think. Eventually they will give out from putting the jack pressure directly against it.
palanza87 is offline   Reply With Quote
Old 09-07-2017, 01:08 AM   #45
mav1178
mav1178's Avatar
I never said they are solid, I'm just stating my own observation based on 3+ years of ownership and working on the car twice or more per month.
I mostly jack up the car from the front crossmember or rear diff when working on the car.
Old 09-07-2017, 06:23 AM   #46
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yet it still works fine. Guess what the pinch welds on all my Toyotas are still there. None have ever folded on me.
Maybe cause it's a California thing and don't ever have to worry about rust.
And yes, they are as solid as you think. Unless you live in the rust belt.
Old 09-07-2017, 08:43 AM   #47
They are just as solid in the rust belt. Maybe in 20 or 30 years they will reach a point where rust is an issue but if the pinch welds get to a point where they have disintegrated and are no longer structurally sound then that will be the least of the worries.
Spuds (09-07-2017), Ultramaroon (09-07-2017)
Old 09-07-2017, 02:44 PM   #48
driftguy
driftguy's Avatar
Drives: In between cars... 2018 Ninja 1000
This is exactly what I do.
driftguy is offline   Reply With Quote
Old 09-07-2017, 03:22 PM   #49
palanza87
Hmm well maybe the couple posters in here that said theirs folded over had weaker welds? Idk I don't like to use things in a way the factory didn't intend. But yeah I use the middle front and rear differential to lift 95% of the time
Old 09-07-2017, 06:29 PM   #50
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Slotted Jack pads for front pinch welds
I wouldn't say mine were weak.... mine folded over because I jacked the car up improperly. Half because I didn't think I was doing it wrong and half because I had no choice.
By no choice I mean, trying to jack it up on an interlock driveway because no Jack assist ramps and I'm lowered. If the jack can't slide as it lifts you put all of that horizontal pressure on the pinch welds and eventually it folds like it did on me.
So, lesson learned. In hindsight it still really is my fault and I guess a little bit of ignorance on my part to think I could jack it up the way I did. I could've just moved my car to the street and did the work there or in my garage (when available).
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
The Following 2 Users Say Thank You to brzzy For This Useful Post:
Old 09-07-2017, 09:13 PM   #51
LudwigMiles
Drives: '13 BRZ
I'm going to look into this when I apply Fluid Film to the undercarriage.
I am pretty sure this is where the weight is supported by the factory jack.
The inner seam is lower than the outer seam.
The only think I don't like it putting the car directly on the jack stands.
All the weight of the car is concentrated into a very small contact point.
I think I will use a puck or chunk of wood to distribute the weight somewhat.
Only tricky part is to lower the car onto the stands without knocking off the puck or wood.
LudwigMiles is offline   Reply With Quote
FS: BINB Stoptech Slotted Front Rotors(Pair) and 2 full sets of Brake Pads jflogerzi Brakes, Suspension, Chassis 12 10-24-2015 03:26 PM
Pinch weld jack point paint damage? Ingen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 10-12-2015 08:43 AM
Jack Stands + Pinch Weld Wyattkb Scion FR-S / Toyota 86 GT86 General Forum 36 10-12-2015 03:45 AM
Stoptech Slotted Rotors w/ BMB Pads 14BRZ Brakes, Suspension, Chassis 0 06-04-2015 01:16 AM
