Old 07-14-2012, 11:29 AM   #43
WTF
WTF's Avatar
Drives: FT86, BMW 5, JZA80, Porsche 986S
Originally Posted by blu_ View Post
You will need to find someone with a lift or jacks, but it should be doable. The holes are on the side of the vehicle, by where you would look for the rear jack points. IIRC they about a foot or two from the front of the rear tire. They are obvious if you are looking for them. The plugs are about 4" long and 2" wide.
So the plug doesnt actually go where the strut top damper adjustment is in my pictures, the water is actually coming from a problem further underneath the car?? hmm this could mean there is water settling in the subframe and finding its way to the strut top?
When I wrote this, I assumed that maybe there was something missing where the camber adjust goes, but it seems it may be an even larger issue? :S
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
WTF is offline   Reply With Quote
Old 07-14-2012, 11:32 AM   #44
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Yes, if its because they didnt put those plugs in, then it would mean water has been accumulating in your subframe and the mosture starting accumlating up there.
blu_ is offline   Reply With Quote
Old 07-14-2012, 11:42 AM   #45
WTF
WTF's Avatar
Originally Posted by |-Goku-| View Post
I know that some people are referring to this hole on the underside of the car, and that during PDI, it should be installed. But my question is, if this hole is capped like it should be, does this still prevent water from getting inside like the OP is referring too?
I have a feeling the water I am seeing is from a different area completely, however thanks very much for that image.. I will look to see if mine is in there or not.. That would be a very big oversight if that one wasn't in there!
I am assuming the water I am reporting is coming up through the strut itself, as you can see road grime in the strut top, so it's obviously not very well sealed.. I figure if they arent going to seal the strut top, then a measure to stop that water getting into the car eventually should be in place..
Old 07-14-2012, 11:54 AM   #46
whataboutbob
AutoX-10/10ths every run
I'm missing my tie-down grommet on the driver's side, and I can confirm that there are no caps on top of the struts in my trunk.
Old 07-14-2012, 03:04 PM   #47
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
Check in your glove box. And if it's not there. Take it into the dealer
|-Goku-| is offline   Reply With Quote
Old 07-14-2012, 03:05 PM   #48
|-Goku-|
|-Goku-|'s Avatar
Take it to the dealer and let us know what you find!
Old 07-14-2012, 03:23 PM   #49
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
this is a nasty mistake, thanks for the heads up, it will be the first thing to check when i get my car
adprokid is offline   Reply With Quote
Old 07-14-2012, 04:44 PM   #50
White64Goat
Maybe the holes above the rear struts are more 'noise generators'.....
Old 07-14-2012, 05:21 PM   #51
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Sounds like we need to start a list of items that need to be checked when we get our car.
I don't know how to set that thread up. Any help out there?
So far.
1. Check if grommet is in place about 1' in front of the rear tires
2. Make sure there is transmission fluid
3.
4.
5.
DrDuquette is offline   Reply With Quote
Old 07-14-2012, 05:34 PM   #52
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
So far.
3.
4.
5.
Great idea. Could be a sticky thread at the top that could be updated.
One of the old hands here able to set that up?
nzer is offline   Reply With Quote
Old 07-14-2012, 06:51 PM   #53
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Originally Posted by pyro530 View Post
Thanks for the heads up. I'm going to go get myself a couple $0.25 body plugs tonight.
Where are you getting the body plugs. I don't live far from you, Yuba City
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 07-14-2012, 06:55 PM   #54
Mr. Mcoupe
Mr. Mcoupe's Avatar
Drives: ExigeS,M3,S2k,MCpe,MR2T,T4R,Sienna
Everyone stop buying this car!
Current: 19 GT-R[]17 M2[]17 WRX[]14 T4R[]12 NV2500[]07 Exige S[]07 S2k[]05 M3[]03 M3[]02 MCoupe[]94 MR2T[]93 MR2 T[]92 MR2 T[]91 MR2 T[]95 SC400[]
Gone but not forgotten: 04 STI[]05 MR2 Spyder[]04 S2k[]03 IS300[]90 MR2[]
Mr. Mcoupe is offline   Reply With Quote
Old 07-14-2012, 07:03 PM   #55
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Is this the hole you guys are talking about? The opening is only 1.5" long and 0.5" wide. Its on both side of the car. I don't see any grommets in the glove box.
Name:  DSCF2358 (Large).JPG
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 07-14-2012, 07:15 PM   #56
ahausheer
Re-member
Drives: Toyota camry
That's the hole that should be capped with the rubber grommet during PDI. Water and road debris can get up there and eventually cause rust or rattles but I would personally worry about a small animal getting up there and taking a shit or dying. Ive opened my hood and found poop on top of the engine because an animal found it to be a warm dry safe place to take a nap in the winter.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 02:56 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 02:57 AM
Impressive boot space! BD AUSTRALIA 14 08-24-2012 04:30 AM
Fatal FRS Flaw!! Skin Scion FR-S / Toyota 86 GT86 General Forum 4 07-12-2012 04:21 PM
Pics of rear passenger area with plastic removed JRitt Cosmetic Modification (Interior/Exterior/Lighting) 20 06-12-2012 08:17 AM
