CANADA Canada
Old 03-11-2019, 10:45 AM   #43
wparsons
wparsons's Avatar
~175k kms on an early 2013 (July 2012 delivery).
flickr
Old 03-11-2019, 01:11 PM   #44
Rakshaa
Milton 86 Club
Rakshaa's Avatar
Drives: Lexus IS350, GT86, Mini Cooper, CBR
Update from my last post 2 years ago @ 97k - now just past 166k on my 2014. Took delivery almost exactly 5 years ago, so that's about 33k per year.
Rakshaa is offline   Reply With Quote
Old 03-11-2019, 01:33 PM   #45
Way down from what it would have been if still on my 2014 to 2017 schedule. Would have been pushing 300,000 by now if still driving like I was.
D_Thissen (03-18-2019), korhun (09-18-2019), SLVRSRFR (03-14-2019), wparsons (03-11-2019)
Old 03-14-2019, 10:40 AM   #46
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
230,000
Jeez. That's inspiring!
I'm currently just shy of 170k right now, but keep in mind my car was 2 years old already when I bought it with 1000km showing on the odometer at purchase (August 2012 in-service date; purchased in August 2014), so 169k of that has been in "only" 4.5 years.
What issues have you fellow high-milers experienced so far?
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 03-14-2019, 10:53 AM   #47
Rakshaa
Milton 86 Club
Rakshaa's Avatar
We're almost at the exact same mileage and I've had my car for relatively the same amount of time (5 years). For me, no issues as of yet minus regular maintenance and having to change out the brake pads.
The Following User Says Thank You to Rakshaa For This Useful Post:
SLVRSRFR (03-18-2019)
Old 03-14-2019, 11:18 AM   #48
I have had no real "issues" beyond normal wear and tear that would occur with any other car. The only catstrphic failure I had was my own fault for not changing the TOB when it first started making noise. I waited too long, it melted down and took out the whole clutch and the tranny case cover.
Replaced both summer and winter tires once each.
New battery last month.
Some slight faded areas on the outer driver seat bolster from getting in and out so much.
Tear in the vinyl of same bolster where seatbelt got caught between it and the door and I just pulled it too hard.
Many many chips from debris and rocks on the highway. Lower body ones have not rusted even after 4 salty winters. Ones along top of windshield are a nightmare scene. Obviously not the same level of rust resistant panels used in both locations.
There is some surface rust on any untreated bolts and fittings but no worse than any other car I have ever owned.
First new car in my last 5 where I have not had to replace the windshield yet even though it has taken high velocity hits from rocks the size of the Deathstar.
All in all it is in no better or worse shape than any other new car I have driven for the same number of kilometers.
Old 03-18-2019, 10:24 AM   #49
SLVRSRFR
That's great to hear! I've had a few issues here and there, but nothing unexpected. I also had my TOB detonate around 84k but was able to limp the car to the dealer and lucky enough to get it covered under warranty. I also had P0018 pop up last summer just outside of my warranty period, but after fighting with Subaru Canada for 2 weeks, they covered 80% of the bill under goodwill.
I needed a new battery not long after buying the car, but I think that's because the car was 2 years old on paper with only 1000km on it, so probably sat for long periods of its early life.
I also lost the password for my headunit after replacing the battery, but claimed a faulty unit under warranty and got a new head-unit installed free of charge.
I just did brakes about 10k ago (upgraded to StopTech), still on my original clutch, which doesn't feel like it needs changing anytime soon (yet). One of my fog light bulbs went out, I have a squealing accessory belt upon cold-start, and I am experiencing P0351 on and off currently (bad ignition coil), but the car does not act any differently so I haven't rushed to fix that one yet. I'm starting to get some noise from my front wheel bearings so those will have to be done soon as well. Also getting some light "clicking" from the front suspension at low speed over bumps; I'm guessing bushings, but will further diagnose once the weather warms up.
Otherwise, besides my driver's sun-visor breaking and the light on my driver's-side heated seat switch no longer working, I haven't had much to complain about! Also have some light wear and tear starting to show in certain places (steering wheel), and lots of stone chips and a couple of small dings here and there, but that is to be expected with any car. My headlights are also starting to get cloudy on the top part, so I will have to see if I can get a headlight restoration done this summer.
@bpennerz
The Following User Says Thank You to SLVRSRFR For This Useful Post:
Dadhawk (03-18-2019)
Old 03-19-2019, 07:49 PM   #50
Cookies
Drives: 2014 FRS Black
Car currently sitting at 140k. I bought it at 90k and had just had a clutch replaced, guy before me must have drove it like shit.
Cookies is offline   Reply With Quote
Old 03-19-2019, 08:42 PM   #51
HlfpriceWngs
HlfpriceWngs's Avatar
Drives: 2013 FR-S SWP
Currently at 162k. Only issues are squeaky windows and a blown motor due to a failed J02 recall.
I had my Spark plugs, throughout bearing and clutch replace at 162k. The bearing was getting real noisy and was causing the clutch to feel heavy.
HlfpriceWngs is offline   Reply With Quote
Old 03-20-2019, 09:45 AM   #52
SLVRSRFR
Ah yes; I have the squeaky windows too, and the glass on the driver's side is scored pretty badly.
I'm past caring, but it's still annoying.
@bpennerz
Old 05-31-2019, 03:08 PM   #53
N234
N234's Avatar
Drives:
Brought home on November 2013. Has 209,000km.
Trackdays: about 5-8 times a summer, autox 2-3 times, all-season car.
Finished with my second set of summer tires, plenty of life on my second winters.
- oem
- yokohama ig52c
- Michelin PSS 245/40/17
- Gislaved Nordfrost 5
I'm a year into my 3rd set of front pads, a month into my 3rd set of rears.
- Amazing how long these stoptech street performance can go with such abuse.
Second throwout bearing (installed at 130K, along with clutch) quietly hisses sometimes. I'll change it at ~220 preemptively.
***Coolant change at 130K with Subaru OEM (protect your gaskets people). I should have done it earlier but was nervous. New maintenance tasks are always frightening the first time.
This car lives up to its Subaru name, (you toyota owners should be thankful ).
My Habits:
Never drive off without giving the engine 30 seconds to oil up (2 minutes in the winter).
Drive like grandma unless the oil is at temp (a few minutes later than when the coolant is at temp).
Drive it hard, don't worry, it'll be fine.
Don't change your valve springs unless you engine is already broken.
Oil on time.
N234 is offline   Reply With Quote
The Following User Says Thank You to N234 For This Useful Post:
HlfpriceWngs (06-03-2019)
Old 05-31-2019, 03:55 PM   #54
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
Mine is at an uneventful 97k. The big 100k service is approaching quickly. I will do my spark plugs etc..
New oil/filters has been done every 10k. I replaced the tranny fluid twice.
I am on my second set of summer tires. I am due for new winters coming season.
I have had some cold start issues last winter during the -30C cold snap so I replaced the battery with a Red Top.
The right front developed a clunk. The hub assembly (or bearing) had some play and needed to be replaced.
I installed new front rotors/pads and stainless lines (StopTech) and changed the fluid. I was on my second set of pads, they were not done yet, the original rotors also had some life left.
The car has a couple of upgrades, most notably a UEL header and an OpenFlash Stage 2+ tune.
Guru Woodman is offline   Reply With Quote
Old 09-17-2019, 06:39 PM   #55
subie6ix
Drives: 2014 Subaru BrZ Limited Edition
Im 100% Positive I have the highest clicks
So I have a 2014 brz Limited edition.
I purchased it almost 5 years ago with 21 000 km
I am at 202 500km.
Yes, this car is absolutely addictive. Bang for your buck. I joy ride it everywhere. Subaru6ix on Instagram.
I've only had to change the brakes once, go through oil changes and tire changes. It has never died on me or had any issues. No lie. Subaru really knew what they were doing with this vehicle
subie6ix is offline   Reply With Quote
Old 09-18-2019, 08:06 AM   #56
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I've always had the mentality that it will be fine. I bought the car at ~175k kms, drove it for 2 weeks while getting it prepped for the track (pads, fluid, camber, RS4's). No signs of issues driving on the street. Go to the track, 4 laps in and a smoke-show (blown engine).
Wish I got the reliability you have for your track days!
CrowsFeast is offline   Reply With Quote
Highest mileage FRS\BRZ Grishbok BRZ First-Gen (2012+) — General Topics 199 09-22-2018 03:40 PM
Highest mileage 86 South Africa Issues | Warranty | Recalls / TSB 5 02-26-2016 09:13 AM
Need a favor from a Canadian BRZ owner, (Canadian Base model with Manual Trans)) boomslang CANADA 1 09-07-2014 11:24 PM
I'm pretty sure I have the highest mileage BRZ in the country. Superhatch BRZ First-Gen (2012+) — General Topics 66 01-23-2013 10:06 PM
Highest Mileage FR-S?!? BlaineWasHere Scion FR-S / Toyota 86 GT86 General Forum 6 12-03-2012 10:28 PM
