#43 |
What you're showing isn't ideal, but is unlikely to cause any issues.
Your camber is not adjusted evenly, the multiple screw holes are there to facilitate alignments. You can make it 'look' even, but it's a gamble if it actually is unless you or someone else measures it. A good alignment shop will adjust it for you in an ideal way, but that of course costs money. Not a bad idea to go back and button it up, but you will still need to tighten up every nut and bolt you can find to try and solve the noise if you can. It may be a spring binding on the perch, only solution would be a bearing between the spring and a perch. Stiffer swaybar would only add another noise source as another aftermarket component that doesn't live up to OE standards. It certainly won't make anything quieter unless it corrects something like a swaybar rubbing. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Kendallkab (01-25-2017), Yoshoobaroo (01-27-2017) |
#44 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
And also note OP that camber plates replace the oem rubber top hats so NVH will increase no matter what so it may just be something you live with from now on
| The Following User Says Thank You to finch1750 For This Useful Post: | Kendallkab (01-25-2017) |
#45 | |
Drives: Black MT LMT BRZ
#46 |
The way you described it scared us haha. Glad it wasnt as bad as we thought. Did the coils come with the preload adjusted already?
#47 | |
No everything was loose when I got them |
#48 |
assuming that you can set the preload and height independently, tighten up the preload collar enough so that the spring cannot move but not too much that it compresses the spring. if you want to control the height, use the other collar.
| The Following User Says Thank You to ryoma For This Useful Post: | Kendallkab (01-26-2017) |
#49 | |
Drives: SWP BRZ
right height is similar or same on right and left? I cant believe your friend installed camber that way lol |
| The Following User Says Thank You to zc06_kisstherain For This Useful Post: | Kendallkab (01-26-2017) |
#50 |
Drives: FRS
kinda hard to tell without a wider shot for reference, but i think your driver-side tophat is backwards.
[edit] looking at your pictures closer, im almost 100% positive your tophats on BOTH sides are going the wrong way.
| The Following User Says Thank You to 8R6 For This Useful Post: | Kendallkab (01-26-2017) |
#51 | |
Drives: SWP BRZ
also "L" & "R" should be readable from you standing in front of wheel. |
#52 |
Drives: FRS
i think he does have the L/R in the correct sides like you described, but the tophats and camber plates look like theyre mounted in the wrong direction
#53 | |
Drives: SWP BRZ
it's readable from Engine to wheel point. still OP needs to take it off and re install properly |
| The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post: | 8R6 (01-26-2017), Kendallkab (01-26-2017) |
#54 |
Drives: 2014 FR-S
These guys are correct, those top hats are positioned the wrong way. The "L" and "R" is supposed to be on the fender side. So if you look at the first pic, the "L" needs to be on the bottom right side. This makes the camber adjustment a side to side adjustment. As you have it now your camber would adjust corner to corner and that is not cool.
As for preload adjustment, this is a pretty good write up on how to do it. Its Megan coilovers but they are set the same way. Also you can do this while coilover is on the car. |
| The Following User Says Thank You to KnightRyderx2 For This Useful Post: | zc06_kisstherain (01-26-2017) |
#56 |
The Stig's German cousin
WOW. OP, don't let your "friend" touch your car again. He clearly doesn't know a damn thing about MacPherson strut suspensions, putting the top hats on like that.
The gap in the plates is fine. Almost all designs do that at extreme ends of the adjustment range. What your "friend" did however, putting one top hat at one end of the range and the other at the middle, is totally bonkers, especially since he didn't have alignment tools; and it's double bonkers since the top hats are oriented incorrectly. He pretty much just gave you a random ass alignment...emphasis on the ass. Do not bother with an alignment until you've corrected the orientation of the top hats. I would go ahead and move the right adjustment to be about equal with where the left is. |
| The Following User Says Thank You to renfield90 For This Useful Post: | Kendallkab (01-26-2017) |
| ***NEED SOME HELP IN THE NEXT FEW HOURS IF POSSIBLE??*** | NorCalGirl | Northern California | 1 | 01-21-2015 06:39 PM |
| Help installing coilovers | eSOLOR | Northern California | 13 | 12-16-2014 01:51 AM |
| Installing Coilovers in Las Vegas | bobsacamenoh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 09-09-2014 10:14 PM |
| Crap lights on my dash after installing coilovers. | Eelusive | BRZ First-Gen (2012+) — General Topics | 43 | 02-12-2014 02:08 PM |
| 32 Hours 7 Minutes | Wes B. | Other Vehicles & General Automotive Discussions | 11 | 12-26-2012 10:10 AM |
