Old 12-15-2016, 06:55 PM   #43
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Skipping gates without without matching up puts a tremendous additional load on the synchros. The energy dissipated accumulates at the square of the velocity so it makes a big difference.
Spread the wealth. It's not necessary to engage the clutch in each gear, just rake through all the gates if you're not double clutching.
Ahh. I suppose that does make sense. I suppose I could at least pop it into an in between gear without releasing the clutch to help things along (or maybe this is a good excuse to practice double clutching so that I can say I'm good at it, lol.)
Stang70Fastback is offline   Reply With Quote
Old 12-15-2016, 07:00 PM   #44
Ultramaroon
not playing cards
Ultramaroon's Avatar
I used to just pause skipping gates for upshifts but @CSG Mike shamed me out of that habit. Old dogs can learn new tricks. Hell, for that matter you schooled me big time with the no-clutch-double-clutch. I never would've considered it.
I still lift a little, though.
CSG Mike (12-15-2016)
Old 12-15-2016, 07:04 PM   #45
Stang70Fastback
A.K.A. Starlord
Yeah, that was my thought. "I could just give it a second to slow down," but I guess, if anything, that would only work in one direction anyway... shit. Maybe after 40,000 miles that's why I'm starting to have a weird issue shifting into 5th, lol.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 12-15-2016, 07:12 PM   #46
strat61caster
strat61caster's Avatar
There is nothing requiring you to go through every gear during the shifting process. Some people think shifting from 3rd to 5th is "strange" or "unusual" or "wrong,"
FYI, Honda says that's why S2000 transmissions were giving out prematurely. Good discussions on it over at s2ki, if it lets me link the post:
http://www.s2ki.com/forums/s2000-und...g-bad-1026367/
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
CSG Mike (12-15-2016), humfrz (12-16-2016), Ultramaroon (12-15-2016)
Old 12-15-2016, 07:13 PM   #47
Stang70Fastback
A.K.A. Starlord
Lol, I just got done reading all 5 pages of that thread and was about to link it here when you posted.
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
CSG Mike (12-15-2016), strat61caster (12-15-2016)
Old 12-15-2016, 09:29 PM   #48
stevesnj
stevesnj's Avatar
After 1000k mile break in the first thing I did was do a 6>4 downshift doing around 60mph. Never had an issue doing that. But like others have said it's experience. It's been a smooth rapid shift when I do do that. Typically for passing.
My 2016 Build thread
Old 12-15-2016, 09:53 PM   #49
ls1ac
ls1ac's Avatar
shift
some times the shift gate will help with proper sequence shifting.
The Following User Says Thank You to ls1ac For This Useful Post:
cat94 (12-15-2016)
Old 12-15-2016, 10:01 PM   #50
Ultramaroon
not playing cards
Where does that belong?
Old 12-15-2016, 10:06 PM   #51
ls1ac
ls1ac's Avatar
it is out of a Getrag racing trans from a Noble M400
Old 12-15-2016, 10:10 PM   #52
Ultramaroon
not playing cards
Oh, yours!
Shit, that's a cool machine.
Old 12-15-2016, 11:08 PM   #53
ls1ac
ls1ac's Avatar
parts
this was why the trans was apart, not what you want to see when you crack the case open.
Road America.
this is what happens in 5th gear mid pull 150 to 160mph too much torque for a small light trans
Old 12-16-2016, 12:09 AM   #54
Ultramaroon
not playing cards
Road America.
Well, that just sucks. Is it all fixed up now?
Old 12-16-2016, 08:51 PM   #55
ls1ac
ls1ac's Avatar
those pieces came from the first oops at road America.
we thought it might be a bad gear set so we replaced the trans with an other one.
well it happened again at mid ohio, the original design was for 340 hp.
with multiple engine changes we are short of 500 hp.
we now have taken out about 50 ft/lb of torque.
we also have installed a cooling pump and radiator and cryoed the gears.
as with any race car there is always a weakest link.
Ultramaroon (12-16-2016)
Old 12-20-2016, 11:41 AM   #56
LotsaMiles
Drives: Scion FR-s, xB, iA, Silverado Z71 4
As discussed earlier in the thread there is nothing wrong with the two gear downshift and there are certainly times when it is needed. Cat just isn't there yet with his experience and may very well be driving at revs and in situations where it just isn't required.
On a related note. I just watched a youtube video of an FRS on the track with a dash cam. The guy was coming around a left hand corner and downshifted too far. He might as well have pulled the e-brake. The car immediately slid to the left right into the wall.
LotsaMiles is offline   Reply With Quote
The Following User Says Thank You to LotsaMiles For This Useful Post:
Tcoat (12-20-2016)
Blocking Your TPMS Light DarrenDriven DIY (Do-It-Yourself) Guides 77 03-30-2017 12:18 AM
Dealers wrongly mounted your front plate, blocking airflow Zhangy Scion FR-S / Toyota 86 GT86 General Forum 55 04-20-2015 02:47 AM
Rev match downshift possible with OFT Simon99 Software Tuning 24 08-17-2014 05:20 PM
Blurring/Blocking Licence Plates in Photos btoast Off-Topic Lounge [WARNING: NO POLITICS] 18 06-10-2014 01:42 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
