Old 11-14-2016, 01:26 AM   #43
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
You refused to look at my pretty chart.
Wouldn't have made a difference. Wasn't going to graph all 48 logged parameters, and even if I did, would have been an unreadable mess of squiggly colored lines with no axis labels.
I can scan lines A thru AW with the labels frozen at the top much faster.
Numbers are easier to read than squiggly lines. I can spot patterns easier.
I managed to find and diagnose the fuel cut in a few minutes by visual pattern matching, in an excel sheet with 63,357 cells. Give my method some credit.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 11-14-2016, 01:49 AM   #44
Ultramaroon
not playing cards
Ultramaroon's Avatar
I managed to find and diagnose the fuel cut in a matter of a few minutes by visual pattern matching, in an excel sheet with 63,357 cells. Give my method some credit.
I did the same thing at first. I don't even use excel. I use Open Office. Datazap is an easy way to share and collaborate. You can toggle parameters at will, zoom in and out, normalize them against each other. All kinds of handy stuff.
In no way did I discredit your method. Quite the opposite, I remained attentive even after you turned up your nose at my offering. Why? Because I knew I would learn something. Until tonight, I wasn't even aware high-boost fuel cut was a thing.
It's not a contest. When I say "Thanks, Spartarus." I mean it.
Spartarus (11-14-2016)
Old 11-14-2016, 11:51 AM   #45
Spartarus
...Just add nauseum
Spartarus's Avatar
Well then, thanks, and cheers.
I was feigning indignance about datazap. Hence the Matrix reference. It was meant as a joke. That, and I really do prefer my spreadsheets.
Anyway, boost fuel cut is an ECUTEK tuning feature. I'm not an ECUTEK tuner but I see that he's tuned by James M and he is.
I'm actually over my head once you get into the specific details of ECUTEK features, but it makes a lot of sense for the symptoms.
-Spartarus
The Following User Says Thank You to Spartarus For This Useful Post:
Ultramaroon (11-14-2016)
Old 11-14-2016, 01:35 PM   #46
Ultramaroon
not playing cards
Of course!
I was joking too. Hell, I thought it was a well-placed tit for tat. I was stretching a bit from my first post so it was a relief to see you jump in. I blew a good hour trying to make sense of the raw data before finally giving in to charts.
Hey, @Kiske, not a foregone conclusion but it does fit. Keep us posted.
Spartarus (11-15-2016)
Old 11-14-2016, 02:59 PM   #47
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Getting another 4bar onmi tonight. Sadly i dont have another sensor other than the syock whoch wouldnt rear right with boost anyways.
Old 11-16-2016, 07:59 PM   #48
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Got the MAP sensor in today. So far so good on my first test drive. Will go for another drive after dinner. Fuel trims are still a bit off but, with the hard reset I expect that until a good 100 miles or so.
The Following User Says Thank You to Kiske For This Useful Post:
Ultramaroon (11-16-2016)
Old 11-16-2016, 09:21 PM   #49
Ultramaroon
not playing cards
And the crowd goes wild.
SPAR-TA-RUS! SPAR-TA-RUS!...
humfrz (11-16-2016)
Diagnosing a brake noise, need help.. Subie_Nubie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-27-2017 03:47 AM
Diagnosing dead battery amaciose Electronics | Audio | NAV | Infotainment 1 11-06-2016 02:55 PM
Diagnosing the A/T tranny azynneo Southern California 2 07-08-2016 05:01 PM
Diagnosing low oil pressure BDotG Issues | Warranty | Recalls / TSB 6 02-29-2016 05:09 PM
