#43 |
Drives: GT86 GTS
| The Following 2 Users Say Thank You to Bobster For This Useful Post: | Hyper4mance2k (04-12-2017), SuperTom (01-05-2020) |
#44 |
Drives: toyota 86 2017
i just install one, i don't know about 15hp, but it definitely fell batter, and the opening is about 3 to 4 time the OEM.
#45 |
Drives: frs
#46 |
Drives: 2013 WRB BRZ Limited
I have one I am posting for sale, i got it for trade for some work. Its in great shape and I already use a perrin inlet setup. if anyone is interested replay on my post. it will be going up shortly.
-B |
#47 |
Drives: 2018 BRZ premium
sorry to bring up the past but does the snorkel fit the stock opening? i read somewhere that a snorkel replacement cost about 50 bucks from injen
#48 |
Drives: Jeep 75th, Porsche GT3RS, BRZ tS
Any concerns with that snorkel blocking radiator/oil cooling?
#50 |
Drives: 2013 GT86
Hi guys
I tested this intake on dyno Numbers are real!!!!! My 2013 86 is on 60K km ODO automatic gearbox (because of no manual option for us here in iran!) and on pomp gas ( octane 91. The highest number of gas octane in country )because of this reasons my dyno numbers are lower, compare to your cars. results: without intake:147.90 whp 175.69 n.m with intake:163.31whp 183.32 n.m dyno: dyno jet 224xlc 2017 |
#51 |
LMGTFY
Drives: 13 FRS, 91 Miata
Is that without intake and with tune.
And is that with intake and a tune. If not this is useless. The intake always makes more power initially because the MAF scaling is off. Once fixed or once the ECU readjusts after the install the gains go away. |
| The Following 3 Users Say Thank You to x808drifter For This Useful Post: |
#52 |
Drives: 2013 GT86
nope
Both results: without tune |
| The Following 3 Users Say Thank You to Rshex For This Useful Post: |
#53 | |
Drives: 2017 toyota 86
You need AFR plot in the with intake run. Most aftermarket intakes have the MAF housing designed differently causing the MAF scaling to be off causing AFR to lean out resulting in more power from leaner AFR rather then the actual intake. Ideally you would compare stock + tune vs intake + tune. |
#54 |
Drives: JRSC BRZ SOLD
Power has way more to do with ignition timing than AFR..
#55 |
#56 |
| Injen intake... | Brahsbrah | Engine, Exhaust, Transmission | 22 | 04-20-2014 02:16 PM |
| FS: Injen Air Intake | ozne99 | Engine, Exhaust, Bolt-Ons | 0 | 01-13-2014 12:05 AM |
| FS in MA: Injen intake | Jesse | Engine, Exhaust, Bolt-Ons | 4 | 07-02-2013 10:00 PM |
| FS: Injen intake | mike123mdc | Engine, Exhaust, Bolt-Ons | 2 | 07-01-2013 08:56 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 02:31 PM |
