Old 02-28-2017, 05:09 AM   #43
Bobster
Drives: GT86 GTS
Originally Posted by marlonthegreat View Post
install pix please
Bobster is offline   Reply With Quote
The Following 2 Users Say Thank You to Bobster For This Useful Post:
Hyper4mance2k (04-12-2017), SuperTom (01-05-2020)
Old 02-05-2018, 08:33 PM   #44
The13Cleaner
Drives: toyota 86 2017
i just install one, i don't know about 15hp, but it definitely fell batter, and the opening is about 3 to 4 time the OEM.
The13Cleaner is offline   Reply With Quote
Old 02-05-2018, 08:50 PM   #45
Teseo
Drives: frs
Originally Posted by Bobster View Post
"OEM" oil cooler?
Old 07-22-2018, 10:06 AM   #46
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
I have one I am posting for sale, i got it for trade for some work. Its in great shape and I already use a perrin inlet setup. if anyone is interested replay on my post. it will be going up shortly.
-B
HeresMyMind is offline   Reply With Quote
Old 02-02-2019, 05:19 PM   #47
Victorscp
Drives: 2018 BRZ premium
sorry to bring up the past but does the snorkel fit the stock opening? i read somewhere that a snorkel replacement cost about 50 bucks from injen
Victorscp is offline   Reply With Quote
Old 02-13-2019, 11:53 PM   #48
Buteo
Drives: Jeep 75th, Porsche GT3RS, BRZ tS
Any concerns with that snorkel blocking radiator/oil cooling?
Buteo is offline   Reply With Quote
Old 02-17-2020, 11:32 AM   #49
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
No independent dynos yet?
Blighty is offline   Reply With Quote
Old 11-06-2021, 07:50 AM   #50
Rshex
Rshex's Avatar
Drives: 2013 GT86
Hi guys
I tested this intake on dyno
Numbers are real!!!!!
My 2013 86 is on 60K km ODO
automatic gearbox (because of no manual option for us here in iran!)
and on pomp gas ( octane 91. The highest number of gas octane in country )
because of this reasons my dyno numbers are lower, compare to your cars.
results:
without intake:147.90 whp 175.69 n.m
with intake:163.31whp 183.32 n.m
dyno: dyno jet 224xlc 2017
Rshex is offline   Reply With Quote
The Following 3 Users Say Thank You to Rshex For This Useful Post:
blsfrs (11-06-2021), gpvecchi (11-07-2021), SuperTom (04-07-2025)
Old 11-06-2021, 04:36 PM   #51
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Is that without intake and with tune.
And is that with intake and a tune.
If not this is useless. The intake always makes more power initially because the MAF scaling is off. Once fixed or once the ECU readjusts after the install the gains go away.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
churchx (11-06-2021), tomm.brz (11-06-2021), Yoshoobaroo (11-06-2021)
Old 12-05-2021, 02:50 AM   #52
Rshex
Rshex's Avatar
Drives: 2013 GT86
nope
Both results: without tune
DocWalt (06-27-2022), Lantanafrs2 (12-05-2021), SuperTom (03-28-2022)
Old 12-05-2021, 12:58 PM   #53
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by Rshex View Post
Hi guys
results:
What are the 4 runs in 1st dyno? All stock no tune?
You need AFR plot in the with intake run.
Most aftermarket intakes have the MAF housing designed differently causing the MAF scaling to be off causing AFR to lean out resulting in more power from leaner AFR rather then the actual intake.
Ideally you would compare stock + tune vs intake + tune.
Old 12-05-2021, 05:26 PM   #54
PulsarBeeerz
Drives: JRSC BRZ SOLD
Power has way more to do with ignition timing than AFR..
PulsarBeeerz is offline   Reply With Quote
Old 12-06-2021, 11:05 PM   #55
86TOYO2k17
The ECU isn’t changing timing On it’s own because of an aftermarket intake..
Old 12-06-2021, 11:44 PM   #56
PulsarBeeerz
Its not making 10+whp from .2-.5 AFR lean either but here we are.
Injen intake... Brahsbrah Engine, Exhaust, Transmission 22 04-20-2014 01:16 PM
FS: Injen Air Intake ozne99 Engine, Exhaust, Bolt-Ons 0 01-12-2014 11:05 PM
FS in MA: Injen intake Jesse Engine, Exhaust, Bolt-Ons 4 07-02-2013 09:00 PM
FS: Injen intake mike123mdc Engine, Exhaust, Bolt-Ons 2 07-01-2013 07:56 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
