Old 04-06-2016, 07:57 PM   #43
MechOps
Drives: 2013 BRZ Limited
Originally Posted by track junkie View Post
This is easier, faster, and smoother when you are downshifting on the street. You don't need to shift to neutral it's unnecessary.
  1. Clutch in
  2. blip throttle
  3. shift to lower gear
  4. release clutch
This. It took me some time to get used to and I'm still trying to master this method. Besides, it's fun to hear that engine rev up just for a moment. This method makes for a smoother ride.
MechOps is offline   Reply With Quote
Old 04-06-2016, 08:23 PM   #44
ButeraFRS
Guest
Posts: n/a
  1. Clutch in
  2. blip throttle
  4. release clutch
Yep this is what I do probably every time I drive. I never shift into neutral when downshifting or skipping gears etc. Steps 2 and 3 are done at the same time for a much quicker and smoother shift.
For heel-toe it's the same deal except my toe is on the brake and my heel is on the gas. I only use that for twisty roads or if I feel like I'm going into a corner too hot. Rarely if ever for daily driving.
Old 04-06-2016, 08:30 PM   #45
Da Breeze
Drives: 2014 subaru brz and forester
Smile
Originally Posted by Wired86 View Post
Damnit. I need just sit in a car with a good manual driver for a while to learn shit. I mean, I can get from point A to point B now, but I want to get better. I want to learn these situations. Trying to figure them out for myself will work I'm sure, but it will take a long time. haha. I'm almost at 1k miles, and I still feel like such a newby.
It just takes practice. Go out on a weekend for 30 to 60 minutes somewhere that has curves and hills. Try rev matching first, then heel and toe when you are comfortable. I have been driving with manual transmissions for 40 years, and I still feel like a rookie.
Da Breeze is offline   Reply With Quote
Old 04-06-2016, 09:25 PM   #46
Gaiakai
Gaiakai's Avatar
Drives: '21 Civic Type R
What everyone else said, but would also like to leave this here:
[ame="https://www.youtube.com/watch?v=_cbZlhduYJY"]5 Things You Should Never Do In A Manual Transmission Vehicle - YouTube[/ame]
That guy also just posted a technical video on heel-toe today, if you have 5mins to kill.
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram!
Gaiakai is offline   Reply With Quote
Old 04-06-2016, 09:28 PM   #47
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Back when YouTube was relatively new I found a series of videos by s0ggyrice that explains how to drive stick pretty well:
https://www.youtube.com/playlist?lis...8EA7254AE8EC79
When I was in much younger nobody could teach me how to drive stick like a pro so I just relied on watching a lot of footwork cam from Best Motoring and Hot Version videos lol!
krayzie is offline   Reply With Quote
Old 04-06-2016, 09:34 PM   #48
rastapete
rastapete's Avatar
Drives: 2017 Subaru BRZ
Originally Posted by extrashaky View Post
Luftwaffel defined it above, but to put it into easier terms:
This has to do with engine braking, using the compression of the engine to slow the car. If you downshift to use the engine to slow the car, the engine speed (RPM) has to come UP to meet the transmission speed. If you just downshift and drop the clutch, the car's momentum will yank the engine up to speed and shock the entire driveline behind it: transmission, u-joints, differential and axles. You can slip the clutch to bring up the engine speed less abruptly, but that puts more wear on the clutch disc over time.
However, imagine instead that you bring the engine RPM up with the throttle instead, so that it's spinning fast enough that there is no jerk, and you don't have to slip the clutch. That's rev matching. You just blip the throttle up so that the engine speed and transmission input shaft speed match. It puts less wear on the clutch and every component behind it.
Some cars actually rev match for you. The latest Corvette will do it. Apparently you can flash a tune on our cars that will do it also. The computer recognizes when you're downshifting and blips the throttle on your behalf to make your downshifts smoother.
I've been wondering what happens if you try to downshift and the car also tries to downshift.
Most people who use engine braking without rev matching simply slip their clutch to bring up the engine speed. Doing that puts more wear on the clutch surface and springs, but it won't necessarily hurt the car. Maybe it takes 5K or 10K miles off the clutch. Maybe not.
You're right that heel/toe isn't necessary in normal street driving. Rev matching is a good skill to have, though, because that's not really about what's necessary. It's about driving more smoothly and putting less wear on the car. Maybe it'll last a long time without any advanced techniques. Maybe it would last even longer with them.
Not wrong. It's just that the throwout bearing and pressure plate will get less wear if you get into the habit of taking the car out of gear and letting the clutch out when you're going to be sitting long enough for that to make sense. How much less wear? Who knows. Maybe it's not enough to even matter. But it doesn't really hurt anything to do it.
I usually watch the traffic lights or pedestrian signal on the cross street. When it turns yellow, I put the car back in gear to be ready to go.
The part that may not have been clear is that people are talking about engine braking, using engine compression to slow the car instead of/in addition to the wheel brakes. So as that applies to your question, I do in fact step down through the gears one at a time to slow the car. I normally use the engine to slow the car without even thinking about it.
It's a stylistic choice. If I weren't using engine braking, I would do it exactly like you're doing it.
The next obvious question is: Why do I use engine braking?
For one thing, it's smoother and feels more stable. When you use the brake pedal, the car wants to rock forward. Accelerate again and the car rocks back. Use engine braking, and it feels more like the stopping force is more centered.
Second, it keeps you in the correct gear. Suppose traffic in front of me slows down, and I use engine braking to slow down also. Then traffic takes off again. I'm already in the correct gear to accelerate. Suppose I'm in a slow-moving lane, and I get a chance to slip into a hole in a faster-moving lane. The car is already set up for that move before I even know I have the chance to make it.
See, I was taught to always be driving the car. A lot of people are only really driving the car when they're accelerating. If you take the car out of gear and coast to the stop light, coasting really isn't driving. I like to drive the car right up to a stop, ready to drive away from it.
Nice post.
rastapete is offline   Reply With Quote
Old 04-06-2016, 09:41 PM   #49
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Originally Posted by Tectoniic View Post
I prefer the paddle on the steering wheel for downshifting
I use the gear selector lever.
The Twins make me smile
Old 04-06-2016, 11:24 PM   #50
Wired86
Wired86's Avatar
Drives: 2016 Subaru BRZ, Limited, MT, CBS
That was a really solid post. I will likely read and reread that as you gave me tons of good tips and advice. I plan to pair this expertise that you provided with:
  1. Clutch in
  2. blip throttle
  4. release clutch
Thanks for all the tips and helping out a manual rookie, everyone. I think I know what to do now for a while until I am ready to practice heel toe. What both of these guys said. haha
Originally Posted by softgrip View Post
Last night I took a corner that would have given me a 4 wheel power slide in the WRX. The BRZ hunkered down and massacred the corner with no loss of traction or speed.
Wired86 is offline   Reply With Quote
Old 04-06-2016, 11:36 PM   #51
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
I highly encourage you to check out the video @Gaiakai posted also. It's good information, and Engineering Explained is one of my favorite channels, actually. They break down a lot of concepts many people don't grasp in the automotive world.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 04-06-2016, 11:38 PM   #52
Wired86
Wired86's Avatar
I actually watched that video about 5 times right before getting my brz and once or twice since I got it a few weeks ago. haha. He has lots of great advice. I have just watched lots of videos and have gotten myself all mixed up on what is best for shifting. You guys straightened me out pretty well, I believe. It is just a matter of practice now.
Old 04-06-2016, 11:38 PM   #53
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
I heel toe every time I'm coming to a stop because racecar, and you should always be in gear until you're stopped.
spicyricecake is offline   Reply With Quote
Old 04-06-2016, 11:46 PM   #54
Wired86
Wired86's Avatar
Wouldn't heel toe just be:
1) Clutch in
2) brake + blip throttle (heel toe)
3) shift to lower gear
4) release clutch
So exactly what was said above, plus braking?
Old 04-06-2016, 11:48 PM   #55
Ultramaroon
not playing cards
Ultramaroon's Avatar
  1. Clutch in
  2. blip throttle
  4. release clutch
No, this is wrong. Blipping the throttle does absolutely nothing for the transmission with the clutch disengaged. If you're going to rev-match blip the throttle just before you engage the clutch.
1. clutch disengaged
2. downshift
3. blip throttle
4. engage clutch
Old 04-06-2016, 11:48 PM   #56
spicyricecake
1) Clutch in
4) release clutch
exactly what I meant. I was too lazy to type
Trouble downshifting to 2nd MT kEnYUnoT Issues | Warranty | Recalls / TSB 4 11-12-2015 06:59 AM
[Poll] Preferred method to start stop on hills Koa Scion FR-S / Toyota 86 GT86 General Forum 62 02-20-2015 04:34 PM
1-Bucket Method (Gary Dean) - The best rinseless wash method Obsidiank Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 09-23-2013 01:00 PM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 09:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 01:20 PM
