#43 |
Drives: 2013 Subaru BRZ Limited (CBS)
Welp, just did this today along with the clutch pedal adjustment. You can definitely feel where the engagement point is now. Another recommend for this little mod.
I think I'll be playing with the clutch pedal adjustment a bit tomorrow. The friction point is a bit too close to the ground for my tastes when set slightly below the brake pedal. I'm sure this is all personal preference...
2006 Lotus Exige Aspen White (Supercharged Honda K24A2 swapped.)
1994 Autozam AZ-1 Mazdaspeed 1996 Mazda Miata (Track car.) 2007 Suzuki SV650 (Track bike.) |
#44 | |
Drives: Asphalt FR-S MT
How To: Free Clutch Spring Removal in 15 Minutes - A must do for manual trans!
Best I can explain is the first inch or so of travel is very very loose. As in a could push the pedal in about in inch with no more than my finger. The pedal resistance progressively increases as the pedal travels down further. But it starts out with zero resistance. The pedal wouldn't snap back to the very top if your foot slipped off while it was compressed. Interesting. I didn't know that would help get rid of the looseness at the beginning of the travel. Last edited by Kronos; 04-10-2016 at 05:11 PM. |
| The Following User Says Thank You to Kronos For This Useful Post: | Calum (04-10-2016) |
#45 |
Hmmmm.... I have no play in my clutch pedal. At top position it is resting against the cruise control switch which takes out the slop.
#46 |
Drives: 2015 BRZ
Complete...now time for a test drive.
A hammer helped remove spring after stud was removed Mid drive first impression. Engagement more predictable. Clutch travel feeling very nice. Almost feels like previous aftermarket clutches I have had in the past. Sent from my iPhone using Tapatalk Last edited by vvtlift; 04-10-2016 at 02:02 PM. |
#47 |
Drives: '13 BRZ
So I just did this mod.It's a heavier feel which I like but I still feel like it's missing something in the way of feed back.an improvement but I was hoping for more I guess. Still good for a free mod
#48 |
Drives: 2013 GBS BRZ Limited
Just did this mod along with adjusting the pedal height last night and so far I'm loving it. The only problem I have is the top end of the pedal travel is kind of "spongy" but I'm sure I can adjust that out by tinkering with the pedal a bit more.
Oh, and the OP says be careful not to lose the E-clip... well, being the rebel that I am, I lost the E-clip. Does anybody know where I can get a replacement? Now that the spring is out the clevis the pin holds on doesn't do anything, right? I assume if the pin were to fall out I wouldn't suffer any sort of catastrophic clutch failure leading to a fiery death. |
#49 |
BAE
Drives: Asphalt FRS
Can we do this without adjusting the clutch engagement mod?
#50 |
[||]--(86)--[||]
Drives: 2015 Firestorm FR-S
Yes, the spring may be removed independently.
[||•]==(86)==[•||]
| The Following User Says Thank You to Sosa For This Useful Post: | Decimus (04-18-2016) |
#51 | ||
Hail Magnet
Secondly, no, no catastophic failure, but it wont be as secure should you decide to re-install the spring. |
| The Following 2 Users Say Thank You to HunterGreene For This Useful Post: | Mazikowski (04-19-2016), Ultramaroon (04-18-2016) |
#52 | |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
You could install it in the store parking lot. |
| The Following User Says Thank You to murdoc For This Useful Post: | Mazikowski (04-19-2016) |
#53 | ||
not playing cards
Fifth post of the previous thread. Anyone interested can PM me.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | HunterGreene (04-18-2016) |
#54 | |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Some people will remove the spring and then put everything back together, without the spring. I simply took everything off completely and put it in a ziploc bag; the clevis and pin don't really do anything anymore once the spring is gone. I wouldn't worry too much about losing it unless you plan to put it back in the future.
@bpennerz
| The Following User Says Thank You to SLVRSRFR For This Useful Post: | stock (06-04-2016) |
#55 | |
Exactly what I did. I just tossed all the loose parts in a small ziplock bag. The part where the spring attaches and the pin goes through just dangled there for a year until I decided to put the spring back in. Didn't effect anything or get in the way. And if you do decide to put the spring back in you could probably find a proper sized e clip at a hardware store. |
#56 | |
I wound up messing with it some last night and took out some of the play. I had adjusted the rod in a little too much. Adjusting it to bring the pedal "back up" a little, putting a little pressure against the rod but not enough to actually push it any, got it feeling much more solid. I've still got a little buffer but it feels like most other manuals I have driven in the past. It's definitely taking some getting used to since I don't have all that travel before it disengages... I absolutely love how much feel I have in the clutch with the spring removed. It feels a bit heavier, but not bad and is way more communicative. |
| Clutch return spring removal | MikeyBRZ | Engine, Exhaust, Transmission | 186 | 09-16-2020 01:40 PM |
| How To: Clutch Spring Removal in 15 Minutes | eric6 | DIY (Do-It-Yourself) Guides | 165 | 02-15-2017 12:44 AM |
| FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped | susko | Transmission and Driveline | 2 | 01-21-2016 04:42 AM |
| Clutch spring removal | Sandy | AUSTRALIA | 4 | 07-22-2015 11:14 PM |
| Clutch Spring Removal & Throwout Bearing | DemonRawr | Issues | Warranty | Recalls / TSB | 2 | 05-13-2015 09:08 PM |
