Old 04-01-2016, 07:47 AM   #29
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
If you think the pedal is too stiff once the spring is out, like I said, lower the pedal. Will fix all of your problems
xxBrun0xx is offline   Reply With Quote
Old 04-03-2016, 03:59 PM   #30
Irace86
Drives: BRZ + Ducati M796
Just removed the spring. Unless you are in stop and go traffic with pencil legs, or have a 550whp pressure plate, do this mode now! Feels much more linear and predictable like others have said. The spring seems to assist mostly at the end but our clutches begin to disengage close to the firewall so this spring is torture.
Irace86 is offline   Reply With Quote
Old 04-08-2016, 06:43 PM   #31
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
So to all who liked this mod, good on you! I spent 6 months with no spring and decided it should go back in. The slop on top was just too much for me.
On another note, if anyone wants the spring back in, it's no easy task!
Kronos is offline   Reply With Quote
Old 04-08-2016, 08:29 PM   #32
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
sly is offline   Reply With Quote
Old 04-09-2016, 08:40 AM   #33
Curtski96
Curtski96's Avatar
Drives: Pearl white '13 frs
Oh wow you really wanted that back in lol creative
Curtski96 is offline   Reply With Quote
Old 04-09-2016, 12:03 PM   #34
JSanders
FR-S Newb
JSanders's Avatar
Guess I know what I'll be doing today when work slows down..... Glad I found this post, I though it was just my driving skills slipping a bit... .Why make it so numb Toyota?? Whyyyy??
"Driving is the synchronization of vision, analysis, and movement. It is an art form." -Unknown
JSanders is offline   Reply With Quote
Old 04-09-2016, 12:15 PM   #35
sly
sly's Avatar
I thought the same thing too. When I bought my 2016 and took it for a test drive, I was a little embarrassed when I took it back to the dealership and all you could smell was the clutch. I had the hardest time engaging the clutch properly and it turns out it was just that stupid spring. Taking it out makes the clutch feel a lot more like my Ford Ranger. Which I like...
Old 04-09-2016, 01:44 PM   #36
yefoo
Drives: 2016 BRZ CWP
Just did this mod yesterday along with the clutch pedal height adjustment. I'm still on the fence. =/
a little background: when I bought the car I noticed the lack of clutch feedback but after 3-ish months of daily driving I adapted pretty well with muscle memory and relying on other things (ears, rpm, butt dyno) to engage to clutch.
anyone else in the same boat as me I'd recommend adjusting the clutch pedal height BEFORE doing this mod. I kinda wish I did and looking at Kronos's post I'm gonna have a fun time trying to put the spring back in.
I'll probably drive around without the spring for a couple of weeks though, who knows, maybe I do like it.
yefoo is offline   Reply With Quote
Old 04-09-2016, 08:38 PM   #37
Kronos
Kronos's Avatar
How To: Free Clutch Spring Removal in 15 Minutes - A must do for manual trans!
Yeah man it was pretty brutal haha. Took about an hour to get it all back in properly
Old 04-09-2016, 08:50 PM   #38
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
Can you elaborate on what you didn't like? The slop on top (I'm assuming of the pedal travel) isn't something that people have mentioned... Or at least I haven't come across it.
2016 Scion FR-S
1991 Acura NSX
2012 Mazda Miata (Track)
2019 Triumph Bonneville Bobber
2007 Suzuki SV650 (Track)
akiranakayama is offline   Reply With Quote
Old 04-09-2016, 09:27 PM   #39
sly
sly's Avatar
Originally Posted by akiranakayama View Post
The slop on top
When you remove the spring, the pedal doesn't return completely to the top. If you lift up on the clutch with your foot, the pedal will come up about an inch or so. The spring pulls against the pedal and causes it to rest at the very top of its travel. When you remove the spring the pedal will rest slightly lower.
It doesn't affect anything though. If anything it removes some of the slop at the top by causing the pedal to rest at the beginning of its travel. As soon as you press on the pedal, the clutch starts moving. By using a spring, the pedal rests higher and will move an inch before it begins to do anything. You just don't feel it with the spring because it makes the pedal numb.
Old 04-09-2016, 09:48 PM   #40
Calum
That Guy
Drives: 2013 asphalt FRS MT
Also, doesn't most of the slop go away once the up switch is adjusted?
Old 04-09-2016, 10:03 PM   #41
sly
sly's Avatar
Yes. I just haven't done that yet to mine. Thanks for the tip.
Old 04-10-2016, 02:15 AM   #42
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
Originally Posted by VeloxEric View Post
This spring can be removed with relative ease
Thank you. I did not remove the spring, I replaced it. Your write-up made it painless!
...that E-clip was a pain, opted for flat-head screwdrivers over needle nose pliers.
[||•]==(86)==[•||]
Sosa is offline   Reply With Quote
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 12:40 PM
How To: Clutch Spring Removal in 15 Minutes eric6 DIY (Do-It-Yourself) Guides 165 02-14-2017 11:44 PM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 03:42 AM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 10:14 PM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 08:08 PM
