Old 08-10-2012, 03:10 AM   #43
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
Lightweight 17s (RPF1s) w/ 215s sounds like the way to go. (or maybe w/ 245/40R17?... same diameter)
18s look nice, but clearly not the best for lap times. Let alone Portland's shitty streets.
Can't wait for Enkei to come out with their 17x9 +35 RPF1s in 5x100!
Entropy is offline   Reply With Quote
Old 08-10-2012, 11:14 AM   #44
Jayde
Jayde's Avatar
Interesting read. I'll look into stickier tires for next summer!
Jayde is offline   Reply With Quote
Old 08-10-2012, 11:31 AM   #45
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Originally Posted by vtmike View Post
It's not the width but the diameter that slows it down. The wider tires were 18's. Interestingly the wider 18's had more grip but slower lap times. Would have been interesting to see the results of lighter wider 17" wheels with the 235 tires.
Sent from my Galaxy Nexus using Tapatalk 2
The wider tire is also going to increase aerodynamic drag and rolling resistance (especially with a sticky tire like the star spec).
I'm pretty sure the stock tires were installed as training wheels, with the understanding that they be replaced when the owner/driver is ready to push the car a little higher. (They also, no doubt, were installed to try to get acceptable mpg numbers for the car).
-Justin
Justin.b is offline   Reply With Quote
Old 08-10-2012, 12:45 PM   #46
Jdogg180
Jdogg180's Avatar
Drives: 2008 Fit Sport
The larger diameter 18" rim will have it's weight farther from the hub that the same weight 17" rim so it's very likely the straight line performance was reduced as well as braking. It would be a very small amount but the margin as pretty small. So lighter wider 17's would give you more grip and if you can stay under or very close to the weight of the stock wheel tire combo you will see that wider is in fact better.
Jdogg180 is offline   Reply With Quote
Old 08-10-2012, 05:12 PM   #47
D1cker
Drives: B9 S4/ND2
The problem I see with this is that they went 235/40/18 instead of 235/40/17. I bet the car would have been fastest on the 235/40/17's because it would actually slightly increase the gearing...
D1cker is offline   Reply With Quote
Old 08-10-2012, 06:23 PM   #48
Chad
Chad's Avatar
Drives: FR-S Whiteout
Originally Posted by Razz View Post
I would like to see someone test 16 inch wheels and lowering the car.
I agree would be interesting.
Chad is offline   Reply With Quote
Old 08-10-2012, 06:59 PM   #49
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
I'm running Enkei PF01 17x8 w 235/40 17 Star Specs. Compared to stock, diameter was ~1/4" less and weight was up ~ 4oz. See post #16 here:
http://www.ft86club.com/forums/showthread.php?t=7934
I ran 17x9 RPF1s with the same tire on my NC Miata, which probably gives slightly better turn in. Surely the magazine guys knew the 18s would be slower. Maybe that was just the size they could source for free/cheap. For me, the best news in the article was that the stock suspension help up to the extra grip, as I have not tracked my 86 yet. Then again, there's a reason the only car mag I read is GRM.
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
phm14 is offline   Reply With Quote
Old 08-10-2012, 11:44 PM   #50
bucket
Drives: 4 wheels
I think they knew that the 18s would be slower, but wanted a "surprising result inside". It isn't really a secret or a new discovery that if you keep adding big wheels, then you are going to hit a point where they slow you down. GRM did a similar article awhile back where they tested 15, 16, 17, and 18 with the same width rubber on a car. The 17" combo posted the best times.
bucket is offline   Reply With Quote
The Following User Says Thank You to bucket For This Useful Post:
phm14 (08-11-2012)
Old 08-11-2012, 01:48 AM   #51
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
so, do you sacrifice any MPG with stickieer tires ? i meant to say, with the same size-diameter -- im assuming the compound might not be as gas friendly as the prius tires...
just wondering...
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports-
SoCAL
rikdrt1 is offline   Reply With Quote
Old 08-12-2012, 01:09 AM   #52
Supergoji
Performance nut
Supergoji's Avatar
Drives: Nissan Twin turbo 300zx
but then there is also the issue of brakes. you can only fit a 13 inch rotor under a 17. with 18's you can do a 14inch.
Supergoji is offline   Reply With Quote
Old 08-12-2012, 09:33 AM   #53
miodculae
FRS Adept
miodculae's Avatar
Drives: Firestorm FRS
for the most part, air rolls across and over the body. if the wheels are aligned and/or tucked in the wells, there should be no additional drag.
rolling resistance may increase with a higher UTQG (250-300+) but the difference in MPG would be negligible.
miodculae is offline   Reply With Quote
Old 08-12-2012, 09:34 AM   #54
mike2100
mike2100's Avatar
Drives: 23 BRZ
Why do you need bigger brakes?
mike2100 is offline   Reply With Quote
Old 08-12-2012, 10:04 AM   #55
UncleFester
I was told the 17x9's will be +45.
UncleFester is offline   Reply With Quote
Old 08-12-2012, 11:16 AM   #56
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Originally Posted by Want.FR-S View Post
The key message of this video: no need to swap wider gripper tire. Just stay at the stock size.
Attachment 9467
That is entirely untrue and completely misses the difference between a 215/17 and a 235/18.
See below.
LSxJunkie is offline   Reply With Quote
Road & Track: 5 minutes to a faster FRS (/BRZ) via Tires xjohnx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 11-18-2013 06:31 PM
Road and track vid DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-29-2011 10:00 PM
Road & Track: Scion FR-S Preview FutureFT86 Scion FR-S / Toyota 86 GT86 General Forum 3 08-29-2011 10:54 PM
GT5 - fastest Suzuka (full track) times NESW20 Other Vehicles & General Automotive Discussions 11 04-03-2011 01:20 AM
Road & Track says 2013 Champion Scion FR-S / Toyota 86 GT86 General Forum 6 09-08-2010 12:33 PM
