Old 03-11-2016, 05:54 PM   #43
Calum
That Guy
Drives: 2013 asphalt FRS MT
Considering how bad the factory rockers are, I don't think you could do worse.
Old 03-25-2016, 06:36 AM   #44
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
My FR-S will be going under the knife in two weeks, I'm going have I think the 4th or 5th closed deck once its finished at Outfront Motorsports. Thanks for posting this, it helped me find the perfect engine builder in my area.
R2RO is offline   Reply With Quote
Old 05-20-2016, 10:07 PM   #45
SPCorBUST
SPCorBUST's Avatar
Is there any reason to update to a closed deck sub 500hp?
SPCorBUST is offline   Reply With Quote
Old 05-21-2016, 10:45 AM   #46
Irace86
Drives: BRZ + Ducati M796
Adding to that...
Maybe I missed the answer that was said already, but why do this? Is this stronger than sleeves, for different setups than sleeves, necessary for certain hp goals, the weak link in this motor?
Irace86 is offline   Reply With Quote
Old 05-21-2016, 12:02 PM   #47
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Irace86 View Post
Adding to that...
Not saying it's the only reason, but besides supporting higher horsepower I've heard that sleeves have a tendency to drop.
Sent from my SM-G925T using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
Old 07-08-2016, 08:11 PM   #48
SPCorBUST
SPCorBUST's Avatar
Any updates?
Old 07-08-2016, 10:10 PM   #49
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Adding to that...
Different way to add strength. Semi closed, closed, sleeved would all help block strength. Sleeved is probably cheapest, idk the price difference between semi closed and closed though.
Theres pros and cons to each style.
Old 07-08-2016, 10:16 PM   #50
Irace86
Is the combustion chamber a weak point?
Old 07-08-2016, 10:19 PM   #51
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
No, but going tripple crank hp will cause insane amounts of stress, so its preventative measure.
Old 12-31-2016, 10:17 AM   #52
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
Any updates on this process of closed deck FA20's??
I wonder if the cylinders get "pushed over" at all by the pressing in process?
Nigelr32 is offline   Reply With Quote
Old 12-31-2016, 12:20 PM   #53
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
For sure .......and here the ones that came later think they "invented" something ........
The 1908, Model "T" block (shown below) looks pretty much "closed" to me .......
Also, the Model "A" block was "closed" (except on the ends).
humfrz
Best it's closed since it's a side valve
Scrappydoo is offline   Reply With Quote
Old 12-31-2016, 02:04 PM   #54
humfrz
Side valve ........??
Oh, I suppose you would be correct, if the engine was laying on its side .....
But, most of the time, the Model T drivers tried to keep the "shiny side up" .....
humfrz
Old 12-31-2016, 03:28 PM   #55
Ultramaroon
not playing cards
Ultramaroon's Avatar
Side valve like a lawnmower engine. Cutting edge technology.
Old 12-31-2016, 06:48 PM   #56
humfrz
Ultramaroon, back-in-the-day, ...... mowing his estate's lawn ......
humfrz
So UPS dropped this off today xwd Forced Induction 48 08-12-2014 10:06 PM
6/23/14 - Could the Subaru BRZ Be Dropped Entirely? 468Power Scion FR-S / Toyota 86 GT86 General Forum 33 06-25-2014 10:14 AM
Dropped TheseColorsDontRun Mid-Atlantic 0 02-28-2014 08:23 PM
Closed Project Kick Revo Lug Nuts (closed) ARP Extended Lugs Sportsguy83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-25-2014 10:46 AM
86FEST Video just dropped Nivek BRZ Photos, Videos, Wallpapers, Gallery Forum 5 06-30-2013 03:24 PM
