Old 10-24-2014, 03:26 PM   #5573
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by TemeCal View Post
Who is your tuner? Your tuner is the one that sets up the maps.
brianhj is offline   Reply With Quote
Old 10-24-2014, 05:00 PM   #5574
TemeCal
Drives: 86
Originally Posted by brianhj View Post
That's who I use, and I have 4 maps. You may want to contact them.
TemeCal is offline   Reply With Quote
Old 10-26-2014, 09:58 PM   #5575
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Had another track day this weekend and 8 or 9 laps in I started to smell gear oil. It went away after a cool down lap and couldn't smell it back at the paddocks. I recently changed the diff and trans fluid and topped off the charger. After a quick inspection there is nothing coming from the trans or diff. Haven't checked the charger yet.
Has anyone smelt gear oil while on track? It's definitely gear oil and not engine oil.
Thanks
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 10-26-2014, 10:02 PM   #5576
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
FYI:
Different customers have different requests and we have been working to accommodate everyone on their requests. When an order/request comes in for only two map being setup we setup two maps and no more as that is what was requested/ordered.
Throttle Map 4 (drag) can be used as much as you like, there is no harm in doing so it is just very aggressive. Once again though all our maps are custom ordered to each customers requests. So map #4 might be different between customers. Like we stated we try to customize as much as we can for each customer.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
MINOCIN (10-27-2014)
Old 10-26-2014, 10:44 PM   #5577
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Are any of you guys running water-methanol injection?
I am on the edge of switching to twin-screw (turbo'd now), but only if I can get to 300hp on a 2nd map using 93 octane and WMI. I'm seeing people posting mid-200s with 70mm pulley and intercooler, so not sure if WMI will be enough?
I tried searching through and only found a few mentions of people buying WMI kits, but no actual results with the twin-screw.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 10-26-2014, 11:39 PM   #5578
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Maybe ask Kalen Gray at https://www.facebook.com/forgedperformanceaustralia
He was running WMI on his kit.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
The Following User Says Thank You to Khorne For This Useful Post:
woode (10-26-2014)
Old 10-27-2014, 09:55 AM   #5579
tegunulgener
tegunulgener's Avatar
Drives: Dark Side
Hi everyone,
I've recently bought S5-210 with charge cooler. I was wondering, do I need an oil cooler? I am not doing track days. Just for street use. I am in the south cost of UK and weather is not too bad compared to the north.
Also another question;
I've seen Deatschwerks injectors. I can see that injectors are for port but not direct. What are the benefits if I purchase those injectors? I guess D4S using direct injectors on some point.
Thank you for answers...
tegunulgener is offline   Reply With Quote
Old 10-27-2014, 10:57 AM   #5580
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Thanks
My guess is that the old oil was just burning off. Either that or you added a little too much and perhaps it came out the tranny or diff vent tube. I don't remember if this car's tranny or diff has a vent tube though.
The Following User Says Thank You to King Tut For This Useful Post:
calispec (10-27-2014)
Old 10-28-2014, 10:51 PM   #5581
evan
Drives: fr-s
I'm running an AEM kit, trunk mounted. It has certainly helped in my case. I was originally running 100% methanol but decided on 50/50 most recently. On E85 and with a local tuner's brzedit tune, I put down ~311whp on a dyno dynamics. This was with a 70mm pulley on the 210, lw pulleys, cf driveshaft, pump, etc. I am thinking of migrating to Ecutek to take advantage of the flexibility switching between pump and ethanol. I might be swapping to a 66 or 69mm pulley soon, so I believe the WMI will help even more. No intercooler, other than the WMI.
evan is offline   Reply With Quote
The Following User Says Thank You to evan For This Useful Post:
woode (10-28-2014)
Old 10-28-2014, 10:54 PM   #5582
woode
Boosted Member
woode's Avatar
You're running E85 + WMI and made 311rwhp, or that was with E85 before WMI? Do you know what % ethanol that was by any chance? And do you have any 93 octane + WMI numbers?
Old 10-28-2014, 10:58 PM   #5583
evan
Drives: fr-s
You're running E85 + WMI and made 311rwhp? Do you know what % ethanol that was by any chance? And do you have any 93 octane + WMI numbers?
Yes E85+WMI(100%). I posted a dyno some time ago. It was straight E85 (no winter blend). It was tested to make sure. On 92 octane and 100% methanol, it made ~276-ish whp. When I dropped to the 50/50 mix on 92 octane, I had to detune slightly. Lost about 8-10whp.
woode (10-28-2014)
Old 10-28-2014, 11:03 PM   #5584
woode
Boosted Member
woode's Avatar
Do you have a full exhaust?
I appreciate all the answers - I am pretty sure I am converting to supercharger, but really want to try to maintain at least 275..300.. hp. Having driven my car at various boost levels on a turbo from 245 to 412hp, I know that ~300 is a pretty good DD power level - especially with the responsiveness of a supercharger.
Old 10-28-2014, 11:06 PM   #5585
evan
Drives: fr-s
Yes, full exhaust front to back and both cats retained. It is P&L from the header to the front pipe. Exhaust is aftermarket 2.5".
woode (10-28-2014)
Old 10-28-2014, 11:07 PM   #5586
woode
Boosted Member
woode's Avatar
Awesome, thanks for the info man!
The Following User Says Thank You to woode For This Useful Post:
evan (10-28-2014)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
