Old 10-18-2014, 01:34 PM   #5475
sickmint79
Drives: bmw
Originally Posted by DeliciousTuning View Post
Why is your fuel so bad? Just doesn't make sense especially being the US receives a lot of oil from Saudi Arabia. Correct? You would think you would have the best fuel. Learn something new every day.
Cheers,
William Knose
refineries are the guys actually making the gas. as i recall, iran can't even refine its own gas, since they have sour crude - they need to export the oil and import the finished gas.
Originally Posted by 8686 View Post
refining technology is old. We need to import some new technologies from the US and some corn juice.
it would seem corn based us ethanol on its way to saudi arabia is not high on the list of likely things to happen! fyi this is also very political and not based on market and economic need here - corn is not the best input for ethanol by any measure. corn itself in the us is a very protected market (corn is subsidized, brazilian sugar has tariffs iirc)
sickmint79 is offline   Reply With Quote
Old 10-18-2014, 11:16 PM   #5476
brianhj
Drives: 2017 Camaro 1SS
Is this supercharger supposed to whistle so loud?
Seems like it's awfully loud with almost no gain on the low end. Kinda disappointed to be honest. Stage 1 with 93, stock header. Reminds me more of when my stereo would have a bad ground and would pick up alternator whine.
I could live with the whistling if it produced results on pay with the amount of noise it's making!
Edit: I'm not bashing it or the car, just looking for feedback /opinions
Edit2: E85, header, and intercooler are on my list of upgrades, which should I go with first? Maybe I should go with rotrex instead?
brianhj is offline   Reply With Quote
Old 10-19-2014, 01:06 AM   #5477
s2d4
s2d4's Avatar
Yes all PD whines.
It's a PD, tends to have more power in the low end than centrifugal ones, like running a V6.
Old 10-19-2014, 01:35 AM   #5478
brianhj
Originally Posted by s2d4 View Post
Yes all PD whines.
Yeah I get it's supposed to whine but holy shit it's like a loud whistle or howl.
Also low end feels just as weak as stock. Definitely not like running a V6 lol
Old 10-19-2014, 01:37 AM   #5479
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Get the intercooler and a 70mm pulley and it will. Huge difference.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 10-19-2014, 01:45 AM   #5480
brianhj
Thanks for reply, sorry I forgot to mention I'm running the 69mm pulley from delicious tuning
Old 10-19-2014, 01:46 AM   #5481
brianhj
Low end just seems so sluggish, just like stock. I guess I was expecting more
Old 10-19-2014, 01:49 AM   #5482
CK_Bladesmith
Drives: Raven FR-S
It's not gonna have the "pull you back in the seat" torque like a v8 but it certainly should be better than what you describe. Maybe your car is pulling timing due to too much heatsoak from not having an intercooler? Just a thought.
Old 10-19-2014, 01:52 AM   #5483
brianhj
Yeah I mean it feels stock until I really get on it. I wanted to go S/C route to have low end improvement but there doesn't seem to be any, just the overbearing noise.
Maybe so, how could I find out? I did the install and uploaded tune from delicious myself. Take it to dyno?
Old 10-19-2014, 01:55 AM   #5484
CK_Bladesmith
Drives: Raven FR-S
Bill at delicious may have a better answer for you. I'd get in touch with him.
Old 10-19-2014, 03:50 AM   #5485
sam69
Drives: GT 86
Was speaking to one of the guy's I know at Sprintex a while ago and he said you shouldn't run the 69mm pulley without the intercooler as it creates way to much heat soak so you're most likely loosing power not gaining.
First thing would be to get the cooler into it then go exhaust if you want a bit more but speak to William at Delicious Tune .
sam69 is offline   Reply With Quote
Old 10-19-2014, 07:19 AM   #5486
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
I agree, the whirrling noise at idle does sound like a bad ground on a stereo but that's not uncommon. My buddy had a factory supercharged 2003 Mustang GT that sounded the same. As for the howl, I imagine that's at above 3,500 RPM or so right, or do you perhaps have an air intake system that exacerbates the noise?
I personally love the charger whine when I step on it, but my exhaust headers are pretty loud so that kind of overpowers everything else
Well, torque doesn't really start building up past stock numbers until 2,500 rpm. 3,300-3,500 rpm is where the torque starts to flatten out. So yeah, below that it should feel like stock.
I've seen Zach from Delicious say that an intercooler is a must with smaller pulleys. Also that a 69 mm pulley with intercooler and E85 should make somewhere around 300 whp, so that's something to aim for.
I will say that even with an intercooler on the stock 75 mm pulley that the kit does not make my car feel like a high displacement torquey V6. Overall, torque and power are still relatively low when compared to modern V6s. It's definitely not like a 3.5+ liter displacement V6, the low and mid-range powerband aren't punchy. Instead I would say that the kit makes the car feel more like the older low displacement V6 engines, such as an E36 325i or VR6 motors. The motors that require you to really wring them out. So still not a lot of power and torque, but still good enough to pass people on the freeway or to be lazy with your shifts
Oh, I just remembered something. What ecu map are you running? If you're not changing your map each time you start up your car then the default accelerator setting is set to "soft". This map I guess was intended for better fuel efficiency and smoother (laggy in my opinion) throttle response and acceleration. The accelerator trim options for each map should be as follows; soft, standard, sport and drag. I believe these settings were introduced in tune version 8.65. Every time I get in my car I have to set the map back to standard, because I can't stand the soft setting.
Here's how to switch maps.
[ame="https://www.youtube.com/watch?v=GGdrhnKNr_8"]Scion FRS EcuTeK ProECU RaceROM Switchable Maps - Cruise Control - YouTube[/ame]
I wish "standard" was the default setting instead of "soft". I mean, standard as a default setting makes sense right?
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 10-19-2014, 07:19 AM   #5487
brianhj
Really?? I could throw the original pulley on. Maybe I'll try that
Old 10-19-2014, 07:25 AM   #5488
brianhj
Wow! Thanks for all the info. I'm thinking I need to put the original pulley on.
Holy cow I have different maps? I thought there was just one.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
