#5475 | |
Drives: bmw
it would seem corn based us ethanol on its way to saudi arabia is not high on the list of likely things to happen! fyi this is also very political and not based on market and economic need here - corn is not the best input for ethanol by any measure. corn itself in the us is a very protected market (corn is subsidized, brazilian sugar has tariffs iirc) |
#5476 |
Drives: 2017 Camaro 1SS
Is this supercharger supposed to whistle so loud?
Seems like it's awfully loud with almost no gain on the low end. Kinda disappointed to be honest. Stage 1 with 93, stock header. Reminds me more of when my stereo would have a bad ground and would pick up alternator whine. I could live with the whistling if it produced results on pay with the amount of noise it's making! Edit: I'm not bashing it or the car, just looking for feedback /opinions ![]() Edit2: E85, header, and intercooler are on my list of upgrades, which should I go with first? Maybe I should go with rotrex instead? |
#5477 | |
It's a PD, tends to have more power in the low end than centrifugal ones, like running a V6.
#5478 | |
Also low end feels just as weak as stock. Definitely not like running a V6 lol |
#5479 | |
Drives: Raven FR-S
Get the intercooler and a 70mm pulley and it will. Huge difference.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#5480 |
#5481 |
Low end just seems so sluggish, just like stock. I guess I was expecting more
#5482 | |
Drives: Raven FR-S
It's not gonna have the "pull you back in the seat" torque like a v8 but it certainly should be better than what you describe. Maybe your car is pulling timing due to too much heatsoak from not having an intercooler? Just a thought.
#5483 | |
Maybe so, how could I find out? I did the install and uploaded tune from delicious myself. Take it to dyno? |
#5484 | |
Drives: Raven FR-S
Bill at delicious may have a better answer for you. I'd get in touch with him.
#5485 |
Drives: GT 86
Was speaking to one of the guy's I know at Sprintex a while ago and he said you shouldn't run the 69mm pulley without the intercooler as it creates way to much heat soak so you're most likely loosing power not gaining.
First thing would be to get the cooler into it then go exhaust if you want a bit more but speak to William at Delicious Tune . |
#5486 | ||
Drives: Asphalt 2013 FR-S
I personally love the charger whine when I step on it, but my exhaust headers are pretty loud so that kind of overpowers everything else ![]() Quote:
I've seen Zach from Delicious say that an intercooler is a must with smaller pulleys. Also that a 69 mm pulley with intercooler and E85 should make somewhere around 300 whp, so that's something to aim for. I will say that even with an intercooler on the stock 75 mm pulley that the kit does not make my car feel like a high displacement torquey V6. Overall, torque and power are still relatively low when compared to modern V6s. It's definitely not like a 3.5+ liter displacement V6, the low and mid-range powerband aren't punchy. Instead I would say that the kit makes the car feel more like the older low displacement V6 engines, such as an E36 325i or VR6 motors. The motors that require you to really wring them out. So still not a lot of power and torque, but still good enough to pass people on the freeway or to be lazy with your shifts ![]() Oh, I just remembered something. What ecu map are you running? If you're not changing your map each time you start up your car then the default accelerator setting is set to "soft". This map I guess was intended for better fuel efficiency and smoother (laggy in my opinion) throttle response and acceleration. The accelerator trim options for each map should be as follows; soft, standard, sport and drag. I believe these settings were introduced in tune version 8.65. Every time I get in my car I have to set the map back to standard, because I can't stand the soft setting. Here's how to switch maps. [ame="https://www.youtube.com/watch?v=GGdrhnKNr_8"]Scion FRS EcuTeK ProECU RaceROM Switchable Maps - Cruise Control - YouTube[/ame] I wish "standard" was the default setting instead of "soft". I mean, standard as a default setting makes sense right?
#5487 | |
#5488 | |
Holy cow I have different maps? I thought there was just one. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
