Old 10-29-2016, 12:02 AM   #533
duqx
Drives: 15' FR-S, 02' 911
I have seen quite a few people in this thread purchase these kits. Any updates on how they have performed with some track duty? I am on the fence between sport & stage2.
Been holding up alright? Any issues with brake bias?
With the close price between sport and stage 2, it seems that if you have the rim clearance, the stage 2 kit is the way to go with the 6piston and larger brake pads.
duqx is offline
Old 10-29-2016, 02:06 AM   #534
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
The sport kit has been good for me. I haven't noticed any issues with brake bias, I know all of the kits are within 5% of OEM so I think it would take a very experienced driver to notice the difference at that level.
Lynxis is offline
Old 11-06-2016, 04:03 AM   #535
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline
Old 11-06-2016, 04:27 AM   #536
MaximeT
MaximeT's Avatar
:o
MaximeT is offline
Old 11-23-2016, 02:26 PM   #537
cgjeff
Drives: 2015 Scion FRS
Need some clarification before ordering...
Running 18 x 9.5 +38 Enkie RPF1's and want to order Front/Rear Brake Kits. Sent an e-mail with all the same info and received this back:
Hi Jeff,
All our kits will fit these wheels.
Thank you!
Simon
Granted, I have not read all 39 pages, but did see a few posts that some kits are not compatible with my wheels. I can print out the templates, but thought there might be someone with the same setup that can provide a quick answer.
Thanks!!
cgjeff is offline
Old 11-24-2016, 03:36 PM   #538
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Hi Jeff,
Thank you!
Simon
Thanks!!
The Stage 2 and 4 Front kits will NOT fit with those wheels without a MIN 5MM spacer. Even then, it is very close. The rears should fit no problem.
The Racers Line is offline
Old 11-28-2016, 12:04 PM   #539
cgjeff
Thanks for the information... it what I figured, but wanted to make sure before ordering!
cgjeff is offline
Old 11-29-2016, 03:10 PM   #540
maregt
Drives: Subaru BRZ
Hi everybody,
can someone confirm which spacer is needed in order to safely (5mm clearance?) fit the stage 2 behind stock wheel?
Thank you
maregt is offline
Old 11-29-2016, 03:33 PM   #541
Cartman
Cartman's Avatar
Drives: GT86
5mm... that would be 20mm spacers... I run 15mm with barely any clearance without issues though.
Cartman is offline
Old 11-29-2016, 03:59 PM   #542
maregt
Drives: Subaru BRZ
Nice, i think i'll go with 20mm bolt-on then
Thank you
maregt is offline
Old 12-03-2016, 11:39 PM   #543
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
I recall coming across it somewhere, but cant seem to find it now....
Can someone confirm bias numbers for the sport kit, and stage 2, with OEM rear calipers?
One is better than the other IIRC?
Joe-G is offline
Old 12-09-2016, 09:11 PM   #544
8R6
8R6's Avatar
Drives: FRS
@Rafi@RR-racing
my rotors are still in great shape right now, but for future reference, where/what are direct replacements i can get for just the rotors? i have the sport kit and the description says its "STI OEM size", so does that mean i can just get a 5x100 STI rotor? just not sure if the hat height is the same or not...
thanks
8R6 is offline
Old 12-14-2016, 06:57 PM   #545
frslee
Just drive it
Drives: 13' FR-S
Originally Posted by 8R6 View Post
@Rafi@RR-racing
thanks
I believe 2004 Impreza WRX STI will fit. That's what I remember from Rafi's email.
frslee is offline
Old 12-15-2016, 02:27 AM   #546
maregt
Drives: Subaru BRZ
I'm interested in this too.
I'm evaluating the sport performance rear with a stage 2 front, but i remember a graph showing a big shift in brake bias towards the rear, so I'm a bit worried cause I'm on stock strut and weight transfer to the front while braking on track is significant.
The comparison was made using the base model rear disc (277mm solid) as a reference, I have the 290mm vented, so I think my situation is not that bad, however i'd appreciate a lot if someone can confirm that the car is safely drivable on track with stock strut (stock spring and everything) and stock size tire (r-compound)
Thank you very much
maregt is offline
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
