Old 07-20-2015, 11:12 PM   #533
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
What do you mean by LTFT's adapted? Is there somewhere I can look to see what range is good for each selected parameter?
Originally Posted by Wayno View Post
Because you have too much information on the screen. Look at this instead.
http://datazap.me/u/mgpaxman/stg-1-d...zoom=6888-7193
It looks fine. Just log again once you have LTFT's adapted.
MGPAX is offline   Reply With Quote
Old 07-21-2015, 03:09 PM   #534
MGPAX
Still 17!
MGPAX's Avatar
Stage 1 tune after 100 miles but with hot air temps:
http://datazap.me/u/mgpaxman/7-21?lo...zoom=3611-4190
Old 07-21-2015, 05:19 PM   #535
ztan
Drives: Toyota 86
Originally Posted by erok81 View Post
I have a few questions on these two logs.
This one is on spring pressure: http://datazap.me/u/erok81/log-1437240088?log=0&data=6
And this is high boost: http://datazap.me/u/erok81/log-1437240088?log=1&data=6
Both logs don't go to redline because I am seeing a few psi higher than my target levels. Due to that, I didn't want to rev it out too high just in case.
Looking at them I can see the IAM stays pretty constant at 0.7x. The AFR seems a little on the lean side too, but I'm not a tuner.
What do you guys think?
This is an off the shelf tune for a turbo car. My wastegate spring is 7.25psi and the high boost target should be 9psi. However, I usually see 9-10psi on the low map and 11-12psi on the high map.
What turbo and exhaust are you running, what fuel, and which off the shelf tune? Quite a bit of FLKC at WOT. I run quite a lot less cam overlap and a bit richer at WOT with minimal FLKC (Greddy T518Z). Your overboost may be wastegate size/flow related.
ztan is offline   Reply With Quote
Old 07-23-2015, 03:28 AM   #536
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Open up your tune in RR.
Open "Mass Airflow / Engine Load".
Open "MAF Sensor Scaling".
Change the value in the 3.44 g/rev column from 80.88 to 83.30.
That will make that lump between 4400 and 5500 more reasonable.
http://datazap.me/u/mgpaxman/7-21?lo...3855-3831-3801
Old 07-23-2015, 02:52 PM   #537
MGPAX
Still 17!
MGPAX's Avatar
@Wayno I can't open this tune as it is the one that came on my OFT. I have a greyed out export file icon when I see it in OFM.
I can't look at it at all in RR.
I can't look at the stock one either. EDIT: I finally figured out I can pull a .ori file onto RR. Still can't export OFT preloaded file tho. All good tho.
Help!! Please!
Old 07-25-2015, 11:54 AM   #538
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
SO i installed my new Tomei UEL last night and flipped to the UEL e85 oft tune.
you guys seeing anything outta place? car feels and sounds fine
http://datazap.me/u/itsjustdavep/fir...=1-2-4-8-11-13
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 07-25-2015, 12:59 PM   #539
phrosty
looks fine, though it's a very small log.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 07-25-2015, 01:02 PM   #540
itsjustdavep
I'm about to go pull a full log here in a minute. Gotta drove bout a half hour
Old 07-25-2015, 06:53 PM   #541
Wayno
Wayno's Avatar
Help!! Please!
Download from oft site.
Old 07-25-2015, 08:27 PM   #542
itsjustdavep
what about these, i think i may have a small leak from header to OP, not sure if that'd reflect in the logs
http://datazap.me/u/itsjustdavep/len...g=0&data=12-13
http://datazap.me/u/itsjustdavep/len...og=1&data=1-13
Old 07-25-2015, 10:48 PM   #543
phrosty
what about these
You're consistently running slightly rich, even in closed loop. Not sure what to make of that.
Old 07-25-2015, 10:50 PM   #544
itsjustdavep
I notice that now that I've been staring at em. I'm gonna slide a thicker gasket in between the header and the over pipe tomorrow. Maybe that leak is causing it
Old 07-25-2015, 10:58 PM   #545
MGPAX
Still 17!
MGPAX's Avatar
http://datazap.me/u/mgpaxman/runup-2...7-8&zoom=7-186
Mine are doing the same and I'm stage 1.
I need to scale my MAF sensor map.....but cant find a program that will work with the oft .csv files.
Old 07-25-2015, 11:41 PM   #546
MGPAX
Still 17!
MGPAX's Avatar
So the ones on the OFT are the same as the ones on the site?
Sorry...I didn't know...Just knew I couldn't look at it to see what it was.
Thanks for all your help btw~
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
