Old 09-13-2012, 03:16 PM   #5419
ionshards
ionshards's Avatar
Drives: 03 Matrix
I got to run 3 laps in a Balboni Edition Gallardo this morning. It was amazing. I don't know if anything is going to top it in the near future.
ionshards is offline
Old 09-13-2012, 03:42 PM   #5420
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Is bacon allow to play w pc while they're driving? If it is, this bacon need more training driving, cuz he almost ram into the bus...
ichitaka05 is online now
Old 09-13-2012, 04:25 PM   #5421
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
I shot the sheriff , but i did not shoot the deputy...... Mkay
A reason why Bob Marley was never a lawyer!!
Long Live Marley!!
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline
Old 09-13-2012, 06:02 PM   #5422
serialk11r
Drives: '06 AM V8V Coupe
.94 so ~ 13.7?
Seems lean. What is their injection strategy (single or multiple? Outboard/showerhead or port? ) and rpm range (intake velocity guess?) ? Also if they're using fuel additives?
Power-wise the 12.5 comes from being practically ideal rather than chemically ideal. Having excess fuel so given imperfect mixing ALL the oxygen will still get used.
So I would guess that maybe the higher rpm allows better mixing. Also if they have injection outboard the throttle bodies that can help atomization/mixing .
Last, if they're maybe playing with adding toluene to their fuel as an anti detonant it's heavier but the ECU and wideband don't know that.
Best I can do with my limited knowledge .
Injection strategy is port injection, rpm cutoff is 12k (they didn't change the cams or anything to adapt to the restrictor), 14:1 compression ratio, 100 octane race gas (standard for FSAE, no additives allowed ). My guess is the 14:1 compression ratio has something to do with why they run so "lean".
serialk11r is offline
Old 09-13-2012, 06:14 PM   #5423
ichitaka05
Site Moderator
ichitaka05's Avatar
Long Live Marley!!
Maybe so... but some, he was a preacher &/or God lol
I remember a guy that said that he have written down all the words Marley sang, said & etc & made it into his bible lol
Old 09-13-2012, 07:11 PM   #5424
Dimman
Kuruma Otaku
Dimman's Avatar
What motor? CBR 600?
Look into bike forums and see if they follow the 12.5:1 AFR trend.
The fact that he says it's for cooling rather than power makes me think he may be thinking too far on the theoretical side.
Edit: also, I think I used bar's 14.7 rather than stoich's 14.3 in my lambda to AFR conversion .
Because titanium.
Dimman is offline
Old 09-13-2012, 08:15 PM   #5425
shadoquad
a quote out of context
shadoquad's Avatar
Drives: '20 BRZ, '17 Silverado, '17 S1000R
did this guy also smoke a lot of leafy green sticky substance?
shadoquad is offline
Old 09-13-2012, 09:27 PM   #5426
ichitaka05
Site Moderator
ichitaka05's Avatar
Yes & last time I heard from him, he was in metal cage busted
Old 09-13-2012, 11:03 PM   #5427
serialk11r
GSXR600
Might be an older one, since they mentioned being able to pick up blocks for 400 bucks. Not sure though.
I specifically asked, "I thought usually max power is at 0.9 or so?" The guy told me "well, depends on your setup". Yea not sure what's going on. Apparently a few years ago there was a guy on the team who was an expert at tuning, and the fuel maps he left behind were aiming for about 0.94.
Okay checked gixxer.com, they seem to agree on 13.2:1. Except pump gas is probably a little different from race gas... I think the pump gas stoichiometric ratio (with oxygenates) is like 14.1-14.3? In that case, 13.2 is about 0.93 lambda. Going by the usual 14.7, 13.2 is 0.90. Higher compression may work better on a leaner mix.
Old 09-13-2012, 11:45 PM   #5428
Dimman
Kuruma Otaku
Dimman's Avatar
GSXR600
Fuck, I can't keep my numbers straight. Where did 14.3 come from ?
Stoich is 14.8 according to my bike engine book (2008). They hold to the 12 to 13 is optimal for Power on a typical performance bike of the era, but while race tuning it can adjusted leaner for better mixing/charge motion/combustion chamber shape. It's pretty involved, gets into fuel volatility curves and stuff. (Stuff I gloss over. ..)
Also is the fuel a spec fuel, or just can't exceed 100 octane?
Because titanium.
Dimman is offline
Old 09-14-2012, 01:00 AM   #5429
wrxgoose
WUB WUB
Drives: 2013 Firestorm
finally got my new issue of Game Informer in. YAY! i now have something to read while pooping
wrxgoose is offline
Old 09-14-2012, 01:15 AM   #5430
jstans84
Drives: Scion FR-S
Originally Posted by wrxgoose View Post
been watching Jackie Chan Adventures on Netflix. watched it a long time ago, when i was younger. figured i'd watch the rest of em.
Dude how can you watch that when Dinosaurs is on Netflix now?!?
jstans84 is offline
Old 09-14-2012, 02:30 AM   #5431
serialk11r
14.1 is what I found for 10% ethanol fuel. 10% ethanol fuel should be a couple percent less dense (equivalence speaking), but I haven't really checked.
Yes the 100 octane is a spec fuel. Otherwise you'd be able to grab some low octane gasoline, dump as much methanol as possible into it before the octane rating goes over 100, and have a pretty imba fuel right?
Old 09-14-2012, 02:55 AM   #5432
Dimman
Kuruma Otaku
Dimman's Avatar
Toluene. Weapon of choice during the retarded psi turbo F1 days. 1000 hp/L in qualifying trim...
Because titanium.
Dimman is offline
