Old 06-22-2016, 07:41 PM   #519
StRacngtC06
StRacngtC06's Avatar
Drives: 2013 Whiteout FR-S
Originally Posted by weederr33 View Post
No problems here. It's a great overall package for what you get. Were you going to use Cosworth's tune or getting something custom done?
I would just start with the supplied tune from Cosworth, but I do have a local tuner who is capable.
StRacngtC06 is offline   Reply With Quote
Old 06-24-2016, 01:51 AM   #520
StRacngtC06
Is there a preference for tunes?
Sent from my SM-N920P using Tapatalk
Old 06-24-2016, 06:20 AM   #521
ajc209
Drives: GT86 Cosworth
I'd stick with the Cosworth tune. I'm not sure I know of any other tuners that have done proper cylinder balancing like Matt et al at Cosworth have carried out in the calibration while they had the engine on the test bench (dyno).
ajc209 is offline   Reply With Quote
Old 07-10-2016, 04:20 PM   #522
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Has anyone looked into using the new Jackson Racing radiator/ oil cooler combo with our supercharger, yet?
MS, CSCS, TSAC-F, CPT
Old 07-11-2016, 12:46 PM   #523
pjp
Drives: frs
Are you working on CARB??
I would love to spend $ in Ca
That would make it Easy
pjp is offline   Reply With Quote
Old 07-20-2016, 10:10 AM   #524
weederr33
weederr33's Avatar
@Matt@Cosworth
You guys said the supercharger is rated at ~380 bhp. How much torque do you suspect it will make at maxed out? Recently had to upgrade my clutch which is rated at 315 ft/lb (I still need to daily my car) and wanted to know how it would hold up. Thanks much!
Old 07-20-2016, 10:54 PM   #525
Hamegreg
Hamegreg's Avatar
Drives: 2015 WRB BRZ Aozora Edition
A good assumption torque would be as follows:
Assuming torque is roughly constant from 4000-7000 rpm, we can assume that we have a somewhat near maximum torque at max horsepower (7000 rpm).
Using the equation for torque and horsepower which is:
*all unit are in italic*
Power = Torque * Rotational Speed
Assuming 380 hp at 7000 rpm
380 hp = Torque * (2 * pi rad/rotation) * 7,000 rotation/min
Torque = 380 hp / (2 * pi * 7,000 rad/min)
Torque = 0.00864 hp min/rad
Torque = 0.00864 hp min/rad x 33,000 lbs ft / min hp
Torque = 285 lbs ft
*Roughly*
This is a theoretical value and therefore could be off, but a good assumption nonetheless. I would guess somewhere within 10% up or down from this value is a great guess (256 lbs ft - 313 lbs ft).
Your clutch should be just fine IMO.
Good luck though
Hamegreg is offline   Reply With Quote
Old 07-21-2016, 12:01 AM   #526
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
You know you can just do (HP/RPM)x5252?
I know that's basically what you did, but it's a well enough known equation in car guys heads. No need to show your work here
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 07-21-2016, 05:21 AM   #527
ajc209
Peak torque will be a little higher as it peaks at 5500rm and drops off a little before hitting max power. ~300 lbft ball park. Your clutch will be fine Weeder.
Old 07-21-2016, 08:21 AM   #528
Hamegreg
Hamegreg's Avatar
Originally Posted by Freude am Fahren View Post
You know you can just do (HP/RPM)/5252?
It does make it simpler to use, I just tried to show every step of the way in a somewhat educative manner. I do this for a living so it's a habit to show every step. The internets might not need all of that hehe. Thanks
As for the peak torque at 5500rpm, it is true but I can't assess hp at 5500rpm. I could use a graph and make an interpolation between the current torque and what it would be with the 380hp upgrade. However I wrote this late last night and just wanted to get a number out there. The torque value should still be within the plus or minus 10% though.
Old 07-21-2016, 09:45 AM   #529
weederr33
weederr33's Avatar
That's too much math, man....
Old 07-21-2016, 12:38 PM   #530
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
torque = (hp/rpm) x 5252
Nitro22 is offline   Reply With Quote
Old 07-21-2016, 12:46 PM   #531
Freude am Fahren
Haha, yeah, there are a few ways to express it, I wrote one, then went to change it and only changed part of it. I originally wrote HP/(RPM/5252). But HP/RPM x 5252 is better because you can put it right into a calculator without parentheses.
Don't you love when you try to be a smartass and mess it up
Old 08-03-2016, 03:43 PM   #532
weederr33
weederr33's Avatar
Ok, so my first real issue with the supercharger kit. The idler/ tensioner pulley that came with the kit has malfunctioned for some reason and is grinding against the engine block. Not sure why it happened, but I already emailed Cosworth about getting a replacement asap. I think this should be an easy fix, but probably shouldn't drive the car till I get a pulley.
On another note, I wonder if the Raceseng pulley's would work?
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
