Old 01-11-2016, 01:55 AM   #519
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Originally Posted by Manic View Post
Thanks! As for the taping, all I know is that you need to be in a really clean environment and be really meticulous about the painting. When I had to wet sand any imperfections, the masking tape I used to seal the taillight would get a little wet and start to come off.
A friend of mine tried to do the signal cutouts and ended up having asymetric patterns
Well, I gave it my best shot... I didnt end up with asymetric cutouts, but the taping could have definitely gone better. Is there some kind of professional tape that makes perfect lines?
I had some Rona green painters tape laying around... I thought I did a decent job with the cutouts, but the tint "bled" through the lines in some spots... oh well...
Joe-G is offline   Reply With Quote
Old 01-11-2016, 01:56 AM   #520
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
It came out ok... Not perfect, but idk I guess we can let the pictures speak for themselves.
I used 4-5 coats of Red Duplicolor Metalcast, and 2-3 coats of Duplicolor Acrylic Clear Coat. I also used some autobody grade wax and grease remover I had laying around from a previous project. However, I didn't bother to scuff up the housings... Others seem to have no problems, but I guess only time will tell...
All taped up... Should have taken more time during this step. Oh well...
Right. After a few light coats of Metalcast.
2-1 by joeag., on Flickr
Left, also after a few light coats of Metalcast.
3-1 by joeag., on Flickr
Couple coats of clear, and after drying. Color came out OK!
Here's the left side
4-1 by joeag., on Flickr
5-1 by joeag., on Flickr
6-1 by joeag., on Flickr
7-1 by joeag., on Flickr
Right Side
8-1 by joeag., on Flickr
9-1 by joeag., on Flickr
Side by Side
10-1 by joeag., on Flickr
11-1 by joeag., on Flickr
12-1 by joeag., on Flickr
13-1 by joeag., on Flickr
And sitting indoors to cure! (Garage is a little too cold up on this side of the border)
15-1 by joeag., on Flickr
Old 01-11-2016, 11:35 PM   #521
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Redid mine last night as they had faded over the last summer. Decided that I was going to do it heavy and proper this time so I used a whole can of VHT nightshade red, and then an entire can of Spraymax 2k (which is by far the most vile stuff I have ever come across, even with a proper respirator on) Turned out great. Bit of orange peel but that sanded and buffed right out.
BDotG is offline   Reply With Quote
Old 01-12-2016, 05:35 AM   #522
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Most of these "spray jobs" look much better than I thought they would... cool!!
I am a sh!t handyman, so bought Valenti's myself (and I love the shape of the lights - especially at night). But had I known about this first I probably would've gone this route!
I like driving!
86 South Africa is offline   Reply With Quote
Old 01-12-2016, 04:10 PM   #523
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
@joeag: Look great! I'm tackling this soon. I want to go with the same cutouts as you since my reverse lights are where the stock signal lights are. (Diode Dynamics Tail as turn module). I'll let you know how mine turns out.
eggncheese is offline   Reply With Quote
Old 01-13-2016, 10:09 AM   #524
toast
Drives: 14 BSP Edelbrock BRZ
If you are going to mask off a section to keep it clear the best way I have found is to pick up a roll of pinstriping tape. Gives a perfect edge and then you can overlap with the painter's tape a little off that edge.
toast is offline   Reply With Quote
Old 01-13-2016, 11:44 AM   #525
stevemp5
Drives: scion fr-s
Little question guys.. How much time need to wait before applied clearcoat on red metalcast? And 1can of metalcast and 1 can of spraymax clear coat enough for this project? Thanks for the help
stevemp5 is offline   Reply With Quote
Old 01-13-2016, 12:32 PM   #526
BDotG
BDotG's Avatar
1 can of each is perfect (use it all) Id wait about 30 minutes between the last coat of base and the clear.
Old 01-13-2016, 02:06 PM   #527
stevemp5
Drives: scion fr-s
OK cool man! Thanks for your help
Old 01-18-2016, 11:05 AM   #528
eggncheese
I used Frogtape - Delicate surface to mask off my area and got really clean lines. I'll share my entire process once I take more pictures after the clear dries. Just a thought, but I think using electrical tape would give you really smooth and crisp lines.
This is post redding, and pre-clear
Old 01-20-2016, 12:24 AM   #529
Bluebatmobile
Drives: 1997 Acura NSX
nice .
B@t™
Bluebatmobile is offline   Reply With Quote
Old 01-26-2016, 01:26 AM   #530
Tor
Tor's Avatar
Drives: Toyota GT86
Can I use any read spay paint to do this? Or does it have to be a transparent tinting color?
(Metalcast not available from Dupli Color in Europe as far as I can tell).
Tor is offline   Reply With Quote
Old 01-26-2016, 10:10 AM   #531
qoncept
qoncept's Avatar
Definitely not, you need a transparent paint.
qoncept is offline   Reply With Quote
Old 01-26-2016, 07:04 PM   #532
Tor
Tor's Avatar
Drives: Toyota GT86
So Metalcast is a dedicated tinting paint?
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
