Old 05-04-2016, 12:19 PM   #505
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Originally Posted by Dru670 View Post
first of all you will fall inlove with the sound and the power from 1st to 2nd and 3rd oooowweeee
I know i have Tomei UEL
Old 05-04-2016, 03:31 PM   #506
HLHachiRoku
Drives: 2015 HL FR-S
Originally Posted by Roneezy View Post
I'll check out steve99 and waynos posts, didn't see that. Thank you!
Also I'm running the Stage 2 UEL 91 tune that I downloaded from February, not the recent one.
Fyi not all chevron are top tier fuel like any other station. Download gas buddy from the app store, you can see which are top tier. Then you can narrow down the top tier stations that have the better fuel. Even the top tier ones can have not so good quality I have found =/ hate how they took away 93 gas >.<
[||•]=(86)=[•||]
2015 Hot Lava FR-S (Sold)
OFT → My non sensor flexfuel UEL tune
Plus other mods
HLHachiRoku is offline   Reply With Quote
Old 05-06-2016, 01:23 AM   #507
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
Yeah when I started using Chevron and my crickets went away I thought that was the best... but now that I put shell my car feels a bit different, like a better feeling. Butt dyno says its good lol. Crickets came back with shell though but I guess hearing them is a good sign!
Roneezy is offline   Reply With Quote
Old 05-06-2016, 02:44 PM   #508
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I used to run 93 map but i switched to 91
tired of searching for good gas and monitoring my IAM drops below 1 every time lol
Old 05-06-2016, 02:54 PM   #509
FrostedFlakes
Drives: 2013 Raven FRS
From what I read from some posts here, I get a sense that even the minimum 91 octane could contribute to knock (or just won't cut it) in those living in areas where the temperature is higher than the normal condition which this tune was made for.
Would this mean the only safe bet would be to use fuel that is 93 or above?
FrostedFlakes is offline   Reply With Quote
Old 05-06-2016, 03:19 PM   #510
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
What kind of gas mileage are you guys getting with this tune? After running it for a couple of weeks I'm averaging around 23 mpg. Where I live 93 is about $1 more per gallon than E85, so I'll be going back to the E85 tune soon. This does seem like a very solid tune though for running 93.
smg1138 is offline   Reply With Quote
Old 05-06-2016, 03:28 PM   #511
Dru670
Drives: 2016 Scion FR-S
Just wondering but aren't they located in CA (Shiv/Openflash)? I get what you are saying because im in Vegas and I guess I have to accept the fact that my car will run shitty regardless because of our temps and poor gas quality. But if Shiv is in CA then I would think the OTS tunes were tested and tuned there aswell. Hope shiv can give us a lil bit info regarding the conditions in which they were made for all his OTS tunes.
Dru670 is offline   Reply With Quote
Old 05-06-2016, 07:28 PM   #512
FrostedFlakes
The tune was tested by various volunteers in different parts of North America. I would assume CA would have been part of that test.
Summer is coming up and the temperature is getting hotter everywhere. People are going to take their cars out to nice drives on highways, roads, and hilly areas. I am curious to know how well the tune can perform in those conditions or how well can your local pump gas handle the tune in those conditions....
Old 05-06-2016, 08:34 PM   #513
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
For those that were running the "old" stage 2 91/93 and are now running the later one, did you feel a difference that makes it worthwhile? My car runs great on the current one, trying to decide if I should pull the trigger on this.
Old 05-06-2016, 08:36 PM   #514
phrosty
Yes.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 05-07-2016, 11:06 AM   #515
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
There's no harm in trying, you can flash right back if you dont think it's worth it.
headlikeahole is offline   Reply With Quote
Old 05-07-2016, 11:12 AM   #516
Noxcyn
Noxcyn's Avatar
Drives: '15 Scion FR-S - Ashphalt (MT)
I think its worth it, you get a better throttle response right off the flash i find, more power in gears 1-4 and you can still feel it in 5/6 as well.
My UEL header sound better, more of a rumble and the set up is overall more aggressive.
I thought about flashing back, but i really have no reason to. Fuel economy is basically the same for a daily driver, and you love your car that much more. Just gotta data log every once in a while and check knocking. In some of my newest logs i have knock correction spike to -1.6 in random times. Im guessing its just a gas quality thing cause nothing else spiked
Over all worth it, if u dont like it, flash back
Noxcyn is offline   Reply With Quote
Old 05-07-2016, 11:23 AM   #517
B-R-Z
B-R-Z's Avatar
That's the thing, is something I may not or hardly even notice worth having to nurse the tune with logging every X weeks and having to be more concerned about gas quality? My engine feels super peppy and powerful as it is, and it runs healthy. Idk, I'll sleep on it I guess.
Old 05-07-2016, 11:27 AM   #518
WRBrzRX
Drives: runs&drives
yes, update yours, it feels closer to e85 down low, it made me switch back permanently until track days
WRBrzRX is offline   Reply With Quote
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
