#505 | ||
Drives: '16 BRZ Limited
#506 |
Drives: Whiteout
I sprayed 2 light dusting coats and then 2 medium coats and then 1 heavy coat. The more coats= the darker red. After VHT I did 3 layers of clear coat and then wetsand. Now they look as dark as TOM's tail lights.
#507 |
Drives: 1997 Acura NSX
nice!
B@t™ |
#508 |
Drives: Asphalt FRS
Is a week too long to wait before clear coat? I got an amazing finish but forgot to get clear! I want spraymax 2k but would have to wait for it to ship. Putting me at 7 or 8 days after ive painted the tails. Is that too long? If so ill have to settle for a different brand that I can get locally. Any suggestions on another good brand if a week is too long to wait?
#509 |
Drives: Subaru BRZ '13 Limited
What does wet sanding the lights do?
#510 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
It smooths everything down so the light doesn't feel or look rough. If you wet sand, the final product will be smooth and even looking, not chunky or blotchy.
Sent from my Nexus 5 using Tapatalk |
#511 |
This looks sick! Mind giving specific instructions on how to do it like this?
#512 |
Drives: Flat grey Toyota 86
Thanks, I would if I could recall the details.
Pretty sure I taped off the pattern that looks red in the center area matching to the lines inside the light. Put down 2-3 coats of dark midnight tint then pulled off the tape, a little wet sanding then red tint the whole thing 2-3 coats. Then wet sanded and cleared to taste. Hope that helps, |
#513 |
Drives: Whiteout frs
Mine
Simple if you have painting skills...i have so... Red vht and last coat is a medium gloss coat, buff, shine and install back...whiteout frs looks amaizing in my opinion with red tails... Btw my turns are red colored leds!!! Looks so good at night
![]() Thanks to evryone who wrote on this thread!!!!! |
#514 |
Hell yeahhh
Took me a long time to make the change...i enjoyed my stocks, i think its a great looking tail light in the frs
#515 |
Is not fast.
Drives: 2014 Whiteout M/T
Did this a while ago, but I forgot to post a photo. Used Duplicolor Red Metalcast, 2 light layers, 3 medium, 1 semi-heavy. Wet sanding when necessary. Then, 3 medium coats of Duplicolor Acrylic Clear Coat. After that, I polished and waxed them.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
#516 |
Canada Eh!
Drives: '13 FRS
Looks good!
#517 |
Canada Eh!
Drives: '13 FRS
Anyone have advice for taping off the signal lights? Any specific method? Or just use tape and cut to shape?
Tape > Cut shape > Spray Tint > Remove Cutout (Dry) > Clear Coat Sound about right? |
#518 |
Is not fast.
Thanks! As for the taping, all I know is that you need to be in a really clean environment and be really meticulous about the painting. When I had to wet sand any imperfections, the masking tape I used to seal the taillight would get a little wet and start to come off.
A friend of mine tried to do the signal cutouts and ended up having asymetric patterns
| Are you going to smoke out your tail lights? | Liquidsnake | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-06-2012 09:02 AM |
| HKS head and tail lamps | DIG1992 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-19-2012 01:04 PM |
| Tail of the Dragon | Tomcat9700 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 02-10-2012 02:30 PM |
| Optional coloured tail lights? | m_life | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-30-2011 06:20 PM |
