Old 05-27-2016, 02:28 PM   #505
Apex-Apex
Apex-Apex's Avatar
I've been running e85 for the past week now and it's been pretty good minus the slight cold start. This is my third time with e85 but first time on a N/A car. You definitely can feel how smooth it is as it goes through the RPM.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 05-27-2016, 05:43 PM   #506
StayPuft209
StayPuft209's Avatar
Drives: Firestorm FR-S
Speechless after looking at your picture lol
StayPuft209 is offline   Reply With Quote
Old 05-27-2016, 06:48 PM   #507
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It was sub 50 degrees for a couple days, a week or two ago and I simply edited my cold cranking tables and had no issues, fires right up and can't wait to test it below that.
Old 07-16-2016, 03:24 PM   #508
poptopclk
Drives: Scion FR-S 10 Series
What is the current ROM for OFT for a stock FR-S with US emissions & Auto Trans for E-85
link appreciated ty
poptopclk is offline   Reply With Quote
Old 07-16-2016, 10:25 PM   #509
steve99
link appreciated ty
latest oft tunes here
use the one that matches your calid
for stock frs on e85 use the EL header stage 2 E85 tune
http://www.openflashtablet.com/downloads/
Old 07-17-2016, 08:04 PM   #510
bleox
Drives: 2015 Subaru brz
So their is 26 pages and the search feature in tapatalk sucks.. So my question is on cruise control at 70mph my LTFT is at -12.50 steady and it drops to like 7.50 is that okay ?
bleox is offline   Reply With Quote
Old 07-17-2016, 09:28 PM   #511
steve99
if its your first tank of e85 and their was a fair bit of petrol )n tank coupled with low ethanol content e85 then you will get high negitive fuel trims.
check your afr and for knock
see ecu logging link below
if no knock and the wide open throttle afr and commanded afr are close and in 12 range you will be fine
Old 07-18-2016, 04:16 AM   #512
bleox
How to run E85 on stock 86 BRZ FRS with OFT tune
Btw I meant -7.5.....Yeah it is my first tank of e85...I'm check it out I only have like 25 miles on this tank so far, I'm drive a lil more i rushed from the old tune to the e85 tune...STFT raised a lot and nothing was happening in the LTFT because according to guide it states shortly after it should increase nothing was happening and I switched over ...I think think I made the jump to the e85 to son and some gas aka petrol was still left in the lines or where ever the LTFT sensor is lol
Old 07-18-2016, 07:12 AM   #513
bleox
Also reading through some stuff Iam (advance advance multiplier..right?)shouldn't be higher then 1... Well even before I went on e85 it's always giving me a higher number not sure if that is okay
Old 07-18-2016, 08:35 AM   #514
steve99
Hmmm IAM value is between 0 and 1 . One is good , 0 is bad.
If your IAM is logging at values outside the range of 0 to 1 then its most likely their a problem with the logging on your oft.
Old 07-18-2016, 08:53 AM   #515
bleox
Way to fix it?... Just to be clear it the IAM appears from factory in the data display correct ???Well it also seems to change when I give it gas the patterns are consistent ...
Old 07-18-2016, 11:22 AM   #516
steve99
I would say the iam logging is not correct for your ecu
you may need to update oft and template file
http://www.ft86club.com/forums/showp...79&postcount=2
or it more likely just an error if your on newer rom calid like F40C
Old 07-18-2016, 12:07 PM   #517
bleox
Feeling maybe a lil stupid what is "ignition adv"...? And "adv. multiplier" I'm assuming adv multiplier is the IAM because that one is at 0.9
Old 07-19-2016, 05:52 PM   #518
steve99
IAM = advance multiplier
Ignition advance is total ignition timing
IAM at 0.9 is acceptable but not good, on E85 you should be iam=1 as you should have no knock
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
