Old 03-11-2013, 05:20 PM   #505
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by blkwrxwag View Post
I have the Injen map + exhaust. I also found that the 0 map worked really well and the 1 map just seemed a bit boggy. I assumed that was because of the crap CA gas as the 1 is for 92 octance, and we only get bad 91. I'm going to try downloading the software and try the 0 map + more timing in increments to see if the best map is somewhere between the two.
Cali here, I have the exact same experience. I filled at a USA gas station last time and I was having RPM dips where it would drop to 500 and shoot up to 800 and then drop down to 700 almost everytime I came to a stop. Switching to the lower octane map fixed this for me.
I just got my cable so I will probably be trying the 89 octane maps.
For fuel in/out how does one determine if my car is running leaner/richer? Is it kind of a feel it out thing? And for the timing in/out I assume timing in will have better performance but if I get a CEL I should switch back correct?
l0aded is offline   Reply With Quote
Old 03-11-2013, 07:57 PM   #506
subiestar
Drives: CBS Limited BRZ
I would think if you're running an OBDII reader like Torque Pro app, you can tell by your AFR. But one time I tried logging 2 pulls, 1 with 92 Fuel Standard and the other with 92 Fuel Out, and my AFR seem to be the same. I'll have to run more test when I have the time.
btw, I did get a P0102 CEL (MAF low voltage fault) running 92 oct All Drop-in Filter map with Timing Standard and Fuel Out. This was just having an Apexi panel filter (everything else is stock).
subiestar is offline   Reply With Quote
The Following User Says Thank You to subiestar For This Useful Post:
l0aded (03-14-2013)
Old 03-11-2013, 10:40 PM   #507
QFry
QFry's Avatar
Drives: '13 Argento FR-S
Ive gotten the p0102 as well...check to make sure your plugs/connectors are all in tightly...mine was caused by improper connection...
2013 Argento FR-S -> Lots of random PlastiDip, UNIChip Custom Tune, aFe Takeda Intake, Nameless Performance front pipe and axle back exhaust, Motegi MR125 7.5x17, Rally Armour mud flaps, Gloss black vinyl roof, ACT street clutch and flywheel,Whiteline bushings; Kartboy Shortshifter and shift bushing
QFry is offline   Reply With Quote
Old 03-12-2013, 01:45 AM   #508
subiestar
yeah, my first thought was my inlet hose connections. Double checked every connection was fine. It was just that one map causing the CEL, other maps are fine so far.
Old 03-12-2013, 10:03 AM   #509
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Have any unichip users tracked their cars hard yet with an aggressive map applied? Any issues?
Old 03-12-2013, 12:16 PM   #510
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Is there a map for panel filter+catless front pipe+catback?
Darryljr11 is offline   Reply With Quote
Old 03-13-2013, 10:07 AM   #511
bakerr6
Drives: 2013 raven black fr-s
I'll be tracking it at mid ohio this year. There is one of the first members to own it that tracked it a couple times last year, and had good results.
I'll also be running multiple auto-x events this year
bakerr6 is offline   Reply With Quote
Old 03-13-2013, 10:39 AM   #512
swift996
swift996's Avatar
Hey, I'll be up there (Mid-Ohio) June 10th, are you going to be?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-13-2013, 11:01 AM   #513
bakerr6
Trying to make that date, depends on what happens between work/family. I have a lot of work to get done around the house between now and then (wont start until tax season is over) that if I get eveerything done, I'll be heading up there. I will however be heading there in august.
Old 03-14-2013, 06:20 PM   #514
Ingeberger
Ingeberger's Avatar
Drives: 2013 Scion Fr-S
I have a (hopefully) quick question. What's the difference between Timing In and Timing Out? Fuel In and Fuel Out? Thanks!
Ingeberger is offline   Reply With Quote
Old 03-14-2013, 06:56 PM   #515
l0aded
Addicted
l0aded's Avatar
http://www.ft86club.com/forums/showthread.php?t=26134
Scroll down 4 posts.
The Following User Says Thank You to l0aded For This Useful Post:
Ingeberger (03-14-2013)
Old 03-14-2013, 07:24 PM   #516
Ingeberger
Ingeberger's Avatar
AWESOME. For some reason I chose to scan through all 24 pages of this thread instead of checking page 1 of the Map thread... -_- Thanks!
Old 03-14-2013, 10:49 PM   #517
ML
ML's Avatar
Drives: 13 White MT FR-S
So my car has been bogging down (throttle response) pretty bad since I put on the Injen Intake, and the car feels pretty unresponsive below 4500 rpm. I finally got my cable, and was wondering on thoughts about which fuel/timing map I should use. I was thinking Fuel in, and timing standard. Thanks
Old 03-14-2013, 10:56 PM   #518
ScionFrsFan
best bet is the injen map with standard timing and standard fuel and see how that feels.
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 03:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 04:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-04-2013 12:05 AM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 06:31 PM
