Old 07-12-2019, 12:23 AM   #505
kch
Senior Misanthrope
kch's Avatar
Originally Posted by pillbox View Post
Sweet! Are you by chance going to the TSS Ridge day September 1st? I'll be there that day with a few other 86 peeps.
sadly not. i've got a leaky rear main seal and a lack of motivation to do anything about it. taking a break from tracking for a bit. :-\
Old 07-12-2019, 02:00 AM   #506
pillbox
Drives: ZC6
Hope you get it sorted out!
2015 Subaru ZC6 BRZ
SPC Front Camber Bolts - PMU Club Racer Advance - GT Radial Champrio SX2 215/45/17 - HKS Type-S Oil Cooler - Verus Engineering Fuel Starvation Door
pillbox is offline   Reply With Quote
The Following User Says Thank You to pillbox For This Useful Post:
kch (07-12-2019)
Old 07-21-2019, 07:15 PM   #507
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Track: Ridge Motorsports Park
Car: 2017 BRZ
Event: Turn 2
Mods: JRSC, CSG FLA, cycled-out SX2s
Lap Time: ~2:02
Notes: Hit 2:01.09 earlier in the day, but only have AiM data of that particular lap.
[ame]https://www.youtube.com/watch?v=Fn1tApBsjTE[/ame]
mistople is offline   Reply With Quote
The Following 4 Users Say Thank You to mistople For This Useful Post:
86_IT (07-21-2019), femaledog (07-21-2019), mb_ (07-24-2019), NoHaveMSG (07-24-2019)
Old 07-24-2019, 03:01 PM   #508
mb_
Ex-MR2 owner
Drives: Scion FRS
[ame]https://www.youtube.com/watch?v=NhJMsdcokgs[/ame]
Hit a new personal best at my "home" and favorite track, The Ridge Motorsports Park.
After viewing the video and checking Racechrono data, can see where I could make changes to see if I can get into 1:59
mb_ is offline   Reply With Quote
Old 09-02-2019, 06:54 PM   #509
GrabTheWheel
Drives: 16' BRZ
[ame]https://www.youtube.com/watch?v=tIHZv5dv-7Q[/ame]
This was my 1st time on track in a year so it took me a bit to shake off the rust. Speeds over 100mph felt almost foreign to me. Was braking WAY too early almost the entire weekend. My best lap was a 2 min. flat. Most of my rolling laps were 2:02-2:03 in 105 degree weather. Car actually ran really well when it was only 90 degrees in the morning and could go a whole session. But after temps hit 105 and I had the track to myself I had to do 1-2 cool down laps for every 2-3 hot laps which I don't think is bad considering it's still a street car and it was hot as hell! Every time coolant got over 230 I would back off and after a quick cool down back to 200.
At the end of the 2nd day I finally got comfortable and realized how much later I could brake and how much better that would set me up for the turn in. Also I always struggle with bus stop but I feel like I had a real obvious but cool breakthrough at the end the 2nd day. I realized if I just stop focusing on where to put my left tire in relation to the curb and focused all my attention towards eyes up looking at my exit angle to really get on it before riverside without upsetting the car seemed to be key, EYES UP! But by the time I figured this out it was 105 degrees and my tires were losing grip. Still managed to stay out for an hour at the end of day 2 by myself just doing 2 hot laps followed by 2 cool down laps repeat. About 70 gallons of ethanol came out to 140 laps, not the 180-200 I was hoping for but still not bad.
Lucky it was 2 days because the first half of day 1 was wasted. Somehow I immediately boiled my fluid first session out and lost the brakes, rear brakes were smoking horribly. Not very confidence inspiring. Luckily they have a shop there. Swapped brake fluid even though it had Motul in there I guess it was no good anymore. Also had to remove the metal shielding spot welded to the inside of the rear brakes, was creating an oven effect and not allowing the rears to cool.
By the afternoon the brakes felt good again but something was still not right. Didn't feel like I had full control of the car even though all traction was suppose to be off. I'm running Motec ECU and from what I can tell there is no way to have VSC 100% off with CANBUS integration. When the factory traction control and motec traction are off somehow the factory VSC still kicks in and applies the brakes! That's why the car has felt so off and I've been swapping sway bars and thinking it's pushing for the last 2 months!! And that's most likely why my rear brakes were cooked!
The only real solution we came up with is to have the Motec traction activated and turn the wheel speeds all the way up giving me as much wheel spin as I want. Effectively giving me no traction control or VSC so I had total control. My tuner who was at the track with me works with race cars only and couldn't understand for the life of him why I wouldn't want the Motec traction on and just be flat everywhere! In his world all that matters is lap times! I had to explain to him that fun and car control are what matters to me, (ok maybe laptimes a little). Will only get 10-12 days a year.
Last problem is my axle seals leaking diff fluid. Should I just replace the seals or go back to stock rear axles? I just got DSS 600 hp axles. Next up is Motec dash and JRZ dampers plus driver mod.
GrabTheWheel is offline   Reply With Quote
Old 09-03-2019, 01:27 AM   #510
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
Track: vancouver island motor circuit
Car: 2017 86
Mods:
re71r 245 40 17 17x8 +45
front hawk dtc 60 stoptech rotor
Lap Time: 1:2581 this time,the harry's lap timer is not working right. last time was 1:29
Notes: try to study trail braking to increase my lap times
open to all the tips
second one is faster, i only got one footage due to the harry's laptimer is not working right
[ame]http://www.youtube.com/watch?v=72HigUE5P1Q[/ame]
[ame]http://www.youtube.com/watch?v=OLwCQtgIxDk&t=329s[/ame]
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 10-26-2019, 06:51 PM   #511
M0nk3y
Track Videos - Directory and Discussion
Track: Mid-Ohio Club Course - 1:43.50
Car: FRS
Mods: JDL 4-2-1, 400/350 MCS 2WR, 17x9 RPF1s, 245/40 RivalS 1.5, APRacing Sprint Kit DS1.11s
Note: First time tracking the FRS. Last track event was with my Z4M 6+ years ago. Been doing a ton of autocross so car familiarity is there, but just a bit less out of touch at the higher speed corners (primarily T1 and T11). ARX Event was hosted there a month or so ago, coupled with low 50 OAT left the chicane and keyhole a bit slick
Open to comments/suggestions
[ame]https://m.youtube.com/watch?v=mp8AVx1-Vfs[/ame]
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
steverife (10-28-2019)
Old 11-02-2019, 02:11 PM   #512
86_IT
86_IT's Avatar
Track: WeatherTech Raceway Laguna Seca
Car: 2013 BRZ 86DRIVE Challenge Street Class Build
Mods: ACE A-350, Tein SRC 10k/12k, 17x7.5 WedsSport SA-35R, 225/40 GTRadial SX2, Solid and Spherical bushings everywhere
Note: This was my first time back to Laguna since my crash last year and only my second time there. I drove extra conservatively all day (early braking, bigger lifts, etc.) to relearn the track, get comfortable with the new setup there, etc. I still managed to set a new PB almost a full second faster than last time even with a passenger. I had planned on switching to 245 SX2s on Weds TC105Xs for the last session to try to best my laptime, but I unfortunately broke 2 wheel studs while removing the wheels. Time for an ARP upgrade! Anyway, enjoy the lap!
[ame="https://www.youtube.com/watch?v=h-mP7CCbQ9U"]https://www.youtube.com/watch?v=h-mP7CCbQ9U[/ame]
Instagram: 86_IT Twitter: 86_IT_BRZ Facebook: 86itbrz Youtube:86 IT
86_IT is offline   Reply With Quote
Old 11-11-2019, 12:17 AM   #513
86MLR
86MLR's Avatar
Safety safety safety
https://wwos.nine.com.au/motorsport/...e-2ad1c694dfa2
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 12-16-2019, 08:48 AM   #514
Petah78
Drives: 2022 BRZ sport-tech
Sorry to hear of your accident but I am glad you are back at it. At the time of the incident, did you have any of the electronic driving aids on? (VSA, TC etc) Track mode?
Car: 2013 BRZ
Event: 86Drive Challenge
MODS: ACE 42.7mm Anaconda, Ace Overpipe, Ace Catless Front Pipe, Ace Laguna 90 Catback, SPC Camber Bolts (Front), Winmax W6, Motul RBF600, Stainless Lines, Stoptech Slotted Rotors, Delicious Tune
Lap Time: 1:54.935 Transponder
Notes: Here's the lap I mentioned in my last post where I hit the wall. too much steering angle, on throttle, and low grip area of the track compounded by my inexperience in recovery caused my loss of control.
Unedited version here for analysis:
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 02-07-2020, 03:59 PM   #515
86_IT
86_IT's Avatar
It was in pedal dance mode.
Old 02-19-2020, 09:56 AM   #516
Wagmetwice
Wagmetwice's Avatar
Drives: 2017 Toyota GT86
Thumbs up
Really cool seeing BRZ/FRS/86 killin' out there. I am hoping to get into tracking soon, with places like the FIRM and Sebring so close to me the only excuse is time haha.
Great content in this thread guys!
Wagmetwice is offline   Reply With Quote
Old 02-19-2020, 11:45 AM   #517
5H1F7Y
Drives: 2017 BRZ Premium
[ame]https://www.youtube.com/watch?v=n-zTOxfSAOU[/ame]
Video from the last track day of the season last year. Not the fastest driver, but it always look so much slower on video. Cant wait for more seat time in a few months. got an open track a little after the 4 minute mark, which was nice.
5H1F7Y is offline   Reply With Quote
Old 06-09-2020, 10:54 AM   #518
M0nk3y
Was able to get out to NCM this past weekend with Chin Track Days.
First weekend for NCM since COVID - So I think the track was a bit green. Super hot as well, which I guess makes the track a bit more greasy. Off a bit time wise from Matt Busby (track manager who used to own a BRZ and posted a 2:20.1). I doubt he's still active on these forums but curious on the conditions his time was set in.
Anyways:
Kyle H. - #89 STX
Track Brake Pad Discussion Thread CSG David Tracking / Autocross / HPDE / Drifting 422 04-03-2025 11:13 PM
S2000 vs BRZ at the track: track oriented discussion CSG Mike Tracking / Autocross / HPDE / Drifting 33 01-13-2013 07:54 PM
Mike's track videos. CSG Mike Tracking / Autocross / HPDE / Drifting 2 08-16-2012 05:00 AM
Scion Canada FR-S Track Day Videos! DjDATZ FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 08-14-2012 12:51 AM
Track/Racing Discussion Allch Chcar Tracking / Autocross / HPDE / Drifting 9 05-26-2012 05:39 PM
