go_a_way1
Old 08-30-2019, 05:55 PM   #5097
Originally Posted by peaches View Post
@CSG_Mike Like I said before when I was running NA I saw oil temps in the 260 range, what kind of oil temps should I be looking for with the SC? I need to update the warning lights on my gauge and do some logging.
You shouldn't really be hitting anything over 260, even boosted.
Old 08-30-2019, 09:21 PM   #5098
peaches
Drives: '14 BRZ Limited
Got to 260 again, had to back off. Car runs great otherwise. The foam and side panels are still in place, again I have the DROC. Will be running with the heater on the rest of the weekend.
Sent from my Pixel 2 using Tapatalk
peaches is offline   Reply With Quote
Old 08-30-2019, 09:41 PM   #5099
kev0
Drives: '14
Damn! What are you doing to be getting up to 260 consistently?
kev0 is offline   Reply With Quote
Old 08-30-2019, 10:21 PM   #5100
peaches
Internet here sucks, I can post a video when I have a better connection.
Old 08-30-2019, 10:30 PM   #5101
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
What should be expected in 85-90 deg ambient with the JRSC + track oil cooler? I need to reinstall my air guides, but I'm looking for what's "normal" after doing so since I was at 260+ at one point as well.
mistople is offline   Reply With Quote
Old 08-31-2019, 12:08 AM   #5102
At lap-record pace, maybe 255 max.
Trackspec hood vents dramatically improve cooling, if you need a quick fix.
Make sure all your underbody panels and fender liners are in place and intact.
Old 08-31-2019, 08:36 PM   #5103
steved
Drives: 2013 FRS
That's just it, it doesn't seem to take much with the dual cooler. ~15 minutes on a momentum track at 80F ambient gets me to over 260F oil Temp and I put the heater on max to keep it at 265.
About 10-12 minutes at 86F ambient on a tight heavy braking track and I'm over 270 oil temp.
steved is offline   Reply With Quote
Old 09-01-2019, 12:52 PM   #5104
peaches
Agreed, it doesn't take a lap record pace to get the temps that high. Here I'm running a 2:10 around PittRace being conservative with a passenger that just wanted a ride, notice from the sound I'm not very aggressive in a few sections (
). I turned the heater on in lap 4 as I was already in the 240 range. Ran a 2:08 in a different session and was only able to keep that pace for 2 laps. Other cars I should be able to keep up with are turning 2:02 and 2:00 laps, which I don't dare try to match as I'm not sure I could do 1 lap at that pace.
Under panels and fender liners are all in place. I thought about where my oil temp sensor is for my gauge, maybe it could be giving me a false reading but they match what the EcuTek ODBII interface shows me. Not sure what else I'm missing, or if the DROC just can't keep up. The thing is now, do I have to get the dedicated oil cooler and not use the oil cooler piece from the radiator or are the louvers going to help enough to keep the temps down?
Old 09-02-2019, 03:19 AM   #5105
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
I run Verus hood vents + Jackson DROC+ edelbrock SC my max temps I saw at my the ridge and pacific raceways with 80s F ambient is 240. most of the time 230s. I only saw oil temps as high as 260/270 when I didn't have any oil cooler at all on my previous Series yellow. Even drifting which is lower speed and banging off the rev limit I was seeing 230s and maxing out at 240s.
Elliotw is offline   Reply With Quote
Old 09-02-2019, 01:44 PM   #5106
max20s14
Drives: 14' Raven M/T - 02' is300
Not sure if I should pick up a JRSC or sell car and buy a Cayman S. Anyone wanna chime in on their experience?
max20s14 is offline   Reply With Quote
The Following User Says Thank You to max20s14 For This Useful Post:
jflogerzi (09-02-2019)
Old 09-02-2019, 02:07 PM   #5107
jflogerzi
jflogerzi's Avatar
Honestly what year and model. Both are going to have their pros and cons. If you can afford the cayman and depending on the maintenance records of the cayman I would lean towards selling the twin. Anytime you add extra power and pushing the engine for prolonged periods like on a track, you are rolling the dice. If you have e85 near you this could tip the scale back into supercharging your twin. Personally I love twin boosted. It's exactly what the car needs to be a fun all around car. My kit for excells more on the street but can still be great for Auto-X and and. Some HDPE( nothing competive).
2013 Series 10 FRS #553
Old 09-02-2019, 09:06 PM   #5108
mrg666
pessimistic skeptic
mrg666's Avatar
With JRSC, the car is almost the same power/weight ratio with Cayman. However, that does not mean it will match Cayman performance with just JRSC. Oil cooling, brakes, clutch (if manual), wheels, suspension, etc all need to be upgraded so that you can compare with a Cayman. You need to decide if you will enjoy doing all these upgrades/mods (it is hard work and sometimes frustration) and learn your car inside out. If you just want to enjoy driving and not worry about upgrades/mods, get the Cayman.
Old 09-03-2019, 12:42 AM   #5109
What year Cayman?
Old 09-03-2019, 11:32 AM   #5110
max20s14
What year Cayman?
Ideally a 2009/10
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
