Old 08-08-2019, 11:41 AM   #5083
peaches
Drives: '14 BRZ Limited
@CSG_Mike Like I said before when I was running NA I saw oil temps in the 260 range, what kind of oil temps should I be looking for with the SC? I need to update the warning lights on my gauge and do some logging.
peaches is offline   Reply With Quote
Old 08-14-2019, 03:53 PM   #5084
peaches
I installed all the OEM foam pieces on the JR radiator (previously only had half of the top piece) and installed the APR cooling plate, temps went down during cruising and come down faster after getting off the highway. The top and bottom pieces are easy, had to trim the side pieces slightly since the shape of the radiator is different. Part numbers for whoever is interested:
45167CA000
45167CA010
45167CA020
45167CA030
Waiting on the TrackSPec louvers to ship so I can put those on, not sure they'll be here before the next event.
The Following 5 Users Say Thank You to peaches For This Useful Post:
CSG Mike (08-14-2019), jflogerzi (08-14-2019), mistople (08-20-2019), new2subaru (08-14-2019), sroby (08-17-2019)
Old 08-20-2019, 12:14 PM   #5085
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Can anyone help me with the part numbers or links to the two rubber hoses that are cut as part of the JRSC installation during steps 80 and 89? Tried a quick search but I didn't see any obvious listings.
80. Remove the cosmetic intake manifold cover. Locate the Power Brake hose where it exits the
backside of the intake manifold on the driver side. The hose will make a 90º bend downwards.
Remove the hose from the car and cut the hose 2” down from the 90º bend. Install the vacuum
tee (03301-10004) into the Power Brake hose with the small fitting facing towards the driver side
fender. Secure with two (2) 11.5mm CTL clamps provided and re-install the assembly.
89. High Performance PCV Valve Installation:
A. Locate the PCV hose where it exits the backside of the intake manifold on the
passenger side. The hose will make a 90º bend downwards. Remove the hose from the car and
pull the outer cover off the hose.
B. Cut the hose 2” down from the 2nd 90º bend.
mistople is offline   Reply With Quote
Old 08-20-2019, 01:38 PM   #5086
CSG Mike
CSG Mike's Avatar
Brake Booster:
Part Number: 26140CA112
Supersession(s): 26140CA111; 26194CA110
PCV:
11815AC740
Old 08-20-2019, 03:56 PM   #5087
mistople
mistople's Avatar
Brake Booster:
PCV:
11815AC740
Awesome, thank you!
What does supersession(s) refer to?
Old 08-20-2019, 04:27 PM   #5088
CSG Mike
CSG Mike's Avatar
Awesome, thank you!
That's what it replaces (supersedes)
Old 08-20-2019, 05:25 PM   #5089
AndreC
Drives: Fast track beast
Do we know recirc valve specs?
(Inlet/outlet sizes)
Mine is getting a bit melty, looking to replace it with a GFB Mach 2.
Sent from my SM-G965W using Tapatalk
AndreC is offline   Reply With Quote
Old 08-20-2019, 09:47 PM   #5090
CSG Mike
CSG Mike's Avatar
Don't overtighten the clamps!
Old 08-27-2019, 10:13 AM   #5091
steved
Drives: 2013 FRS
Cool, I'll try that.
Will this help oil temps as well? How about hood vents? I get that both help with coolant, but I'd love to never see 262F for oil pop up on my AiM ever again!
@mistople did you get back to the track with any of these fixes?
I was at area27 over the weekend which is a much larger momentum track than the previous one I ran and after shoring up the radiator with extra foam and trimming the OEM trim pieces I'm in the same temperature range (ambient temp was 6f cooler, and I was exceeding 265 before I turned my heater on full, and then it held at 264.8)
steved is offline   Reply With Quote
Old 08-27-2019, 10:20 AM   #5092
AndreC
On another sc thread, someone talks about a spun bearing, which possibly could be from over pressuring the crankcase.
So that made me think of the pcv valve we use in our kits.
Can it fail? Should it be a maintenance item?
Do we know a part #?
Old 08-27-2019, 10:49 AM   #5093
mistople
mistople's Avatar
I did not. I was actually supposed to be at that event as well. I withdrew my entry for fear of my car’s health!
I haven’t had time to mess with the air guides yet. Still having tune issues, so one thing at a time..
Old 08-27-2019, 02:52 PM   #5094
peaches
I trimmed and reinstalled the panels around the FMIC and didn't see any further drop in temps after I did the foam pieces (while cruising on the highway). Will be at PittRace this weekend, not sure what to expect but I'll report back on Friday night. Maybe the temps I'm seeing are because south FL sucks, temps and humidity in PA are much lower at the moment.
The Following User Says Thank You to peaches For This Useful Post:
CSG Mike (08-27-2019)
Old 08-30-2019, 03:58 PM   #5095
enivid
enivid's Avatar
Drives: WRB JR BRZED
Has anyone here successfully installed a wastegate on the charge pipe to blow off a few lbs of boost?
Sent from my Pixel 2 using Tapatalk
enivid is offline   Reply With Quote
Old 08-30-2019, 04:54 PM   #5096
CSG Mike
CSG Mike's Avatar
Yes. Remember Nam Yoon? That's what we did on his SOS SC'd S2k.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
