#491 |
Drives: 86
What rear spats is everyone running with their diffusers ?? Naked ??
#492 |
Drives: BRZ, STI, GT350R, Supra, 987.2
#493 |
Is there any possible to install velox rear diffuser without oem diffuser?
#494 |
#495 |
#496 |
BAE
Drives: Asphalt FRS
Quick question @VeloxEric , the mounting points at the sway bar... How high are we supposed to mount the diffuser for proper flow? Or is it subjective? Im currently using the biggest spacers and want to know how high its supposed to be mounted. Its currently mounted at the lowest hanging position.
#497 |
Drives: 2013 white out fr-s
Just installed my diffuser, also used the lowest setting plus the a big spacer and a small one on each of the back bolts, had to cut about a 1x5 of the diffuser off to fit my hks legamax exhaust, all worth it in the end
#498 | ||
![]() This is the only shot I can currently find. Quote:
Eric |
#499 | |
![]() Found another. Edit: May as well photodump. ![]() ![]() ![]() ![]() Kyle has over 20k on his diffuser now, no issues to date! ![]() ![]() ![]() ![]() ![]() ![]() We also did a blog post regarding the rear up-turn lip which has some skepticism associated with it. We will continue to prove function over time even though we have proven function time and time again. A few people feel it necessary to voice their *opinions* that it doesn't work, which is false. http://www.velox-motorsports.com/#!D...f24c9615a08dcc Last edited by VerusEric; 06-06-2016 at 12:51 PM. |
#500 |
Drives: 2015 dgm brz
does this fit with the APR rear spats?
#501 |
#502 |
Does anyone know how well the Tanabe Concept G single exit fits with the diffuser?
#503 |
JHerbert Racing
Drives: 2013 Scion FRS
I am considering running in Nasa TT and want to ditch my heavy Q300. Does the diffuser work with the Buddy Club Spec II exhaust? It is not listed in the confirmed fit list or the confirmed doesn't fit list on FT86 Speedfactory. Thanks!
#504 | ||
Sorry I can't be of more help guys, hope that helps a bit. Eric |
| Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory | naikaidriver | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 02-28-2017 02:48 PM |
| Single-Exit Exhaust Diffuser/Hole Problem... Solution! | Anthony | Cosmetic Modification (Interior/Exterior/Lighting) | 75 | 10-13-2016 07:40 PM |
| Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 09-22-2016 01:41 AM |
| DriveWay Labs Rear Diffuser - FT-86 SpeedFactory | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 435 | 01-15-2015 07:20 AM |
