Old 05-25-2016, 05:01 PM   #491
Iamwu
Drives: 86
What rear spats is everyone running with their diffusers ?? Naked ??
Iamwu is offline
Old 05-25-2016, 06:13 PM   #492
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Most people run naked I believe? We're coming out with a set that ties in our side splitters (yet to be released) and the diffuser as well. Should be released here in the next month or two.
Eric
VerusEric is offline
Old 05-25-2016, 10:57 PM   #493
quinceyc
Is there any possible to install velox rear diffuser without oem diffuser?
quinceyc is offline
Old 05-25-2016, 11:13 PM   #494
VerusEric
VerusEric's Avatar
Yes, a few people have.
Old 05-25-2016, 11:18 PM   #495
quinceyc
Can you provide some pics to see what it looks like? Thank you !!
quinceyc is offline
Old 05-31-2016, 02:53 AM   #496
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Quick question @VeloxEric , the mounting points at the sway bar... How high are we supposed to mount the diffuser for proper flow? Or is it subjective? Im currently using the biggest spacers and want to know how high its supposed to be mounted. Its currently mounted at the lowest hanging position.
Decimus is offline
Old 06-01-2016, 11:34 PM   #497
kuya
kuya's Avatar
Drives: 2013 white out fr-s
Just installed my diffuser, also used the lowest setting plus the a big spacer and a small one on each of the back bolts, had to cut about a 1x5 of the diffuser off to fit my hks legamax exhaust, all worth it in the end
kuya is offline
Old 06-03-2016, 10:39 AM   #498
VerusEric
VerusEric's Avatar
This is the only shot I can currently find.
In the instructions it states to keep the bottom of the strake parallel with the bottom of the car. If the bottom of the car is parallel to the ground, then the strake should be parallel to the ground. That should be your goal when installing the diffuser for maximum benefits. I cannot guess at how high your mounts should be with specific spacers. Hope that helps.
Eric
Old 06-06-2016, 12:38 PM   #499
VerusEric
VerusEric's Avatar
Found another.
Edit: May as well photodump.
Kyle has over 20k on his diffuser now, no issues to date!
We also did a blog post regarding the rear up-turn lip which has some skepticism associated with it. We will continue to prove function over time even though we have proven function time and time again. A few people feel it necessary to voice their *opinions* that it doesn't work, which is false.
http://www.velox-motorsports.com/#!D...f24c9615a08dcc
Old 06-24-2016, 04:16 PM   #500
wutangbrz
Drives: 2015 dgm brz
does this fit with the APR rear spats?
wutangbrz is offline
Old 06-25-2016, 02:34 PM   #501
VerusEric
VerusEric's Avatar
We haven't found a rear spat it doesn't work with yet, so I would say yes.
Old 06-28-2016, 10:22 AM   #502
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Does anyone know how well the Tanabe Concept G single exit fits with the diffuser?
1Cor10:23 is offline
Old 06-30-2016, 08:25 AM   #503
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I am considering running in Nasa TT and want to ditch my heavy Q300. Does the diffuser work with the Buddy Club Spec II exhaust? It is not listed in the confirmed fit list or the confirmed doesn't fit list on FT86 Speedfactory. Thanks!
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline
Old 06-30-2016, 11:22 AM   #504
VerusEric
VerusEric's Avatar
Looking at photos, I'm going to say it may fit. It is considerably higher up on the chassis than the Tomei Type 80. I can't say for sure though as pictures are often deceiving.
Buddy Club also appears that it will fit. Portion I'd be most concerned about is the exhaust cutout hole, but as far as the exhaust it appears to sit high enough to not be close to the diffuser for the rest of it.
Sorry I can't be of more help guys, hope that helps a bit.
Eric
Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory naikaidriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 02-28-2017 02:48 PM
Single-Exit Exhaust Diffuser/Hole Problem... Solution! Anthony Cosmetic Modification (Interior/Exterior/Lighting) 75 10-13-2016 07:40 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 01:41 AM
DriveWay Labs Rear Diffuser - FT-86 SpeedFactory FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 435 01-15-2015 07:20 AM
