#491 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
So. Damn. Smooth now. I like the concept of this short shifter, but I think the JDM or none would be best
#492 |
not playing cards
Sounds like you got it dialed in. It's not rocket science but it takes some patience, doesn't it?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | weederr33 (03-26-2017) |
#493 | |
Glorious BRZ Master Race
Drives: Subaru Libird
FYI, all the DIYs and videos I've seen posted say to adjust the reverse lockout with reference to the lever in 1st gear. That makes the gate slightly too wide because my lever would hiccup into a notch if I pulled any slight bit to the left instead of straight down in a 1-2 upshift. The service manual says to adjust the lockout with lever positioned in 2nd, not 1st. For the 0.8-1mm shim between the plate and lever I used a credit card before torquing down the plate down to 5.5 ft-lbs. 1-2 shift now feels perfectly precise. Seeing as your guys' brackets caused your 1-2 gates to narrow and overlap into the lockout plate whereas my gate widened away from it says there's something way off with how the pieces fit between your kits and mine.
#494 |
No No, don't you get it it doesn't work or installed right (i.e. TRD shifter) it's the part not the installer. While other have had success with the TRD those that haven't insist it's a flawed part it can't possibly be them.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#495 |
I'm not pointing the finger at installation error in that post. We've already been over that. I even said parts aren't fitting same.
| The Following User Says Thank You to switchlanez For This Useful Post: | stevesnj (03-26-2017) |
#496 |
So I took a few video's of the Quickshifter in action. I haven't had any bolt loosening issues so I guess this is how it's supposed to function? You can see I shift hard to 2nd and 3rd and then some rev matching and normal shifting. The other video is with the car off and just cycling through the gears. It's notchy but not bad notchy but sportier I guess. Well iI hope this helps someone out to see how it it functions. The driving mode and knob is my 86 nanny rotary switch attempt. Looks bad and changing it to push button.:P . Any embed code for Vimeo?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete Last edited by stevesnj; 04-01-2017 at 09:47 PM. |
| The Following 3 Users Say Thank You to stevesnj For This Useful Post: |
#497 |
Drives: 2017 ISM PP BRZ
TWM Short Shifter
Any opinions on the design or experience with this piece?
https://www.twmperformance.com/short...-short-shifter |
#498 | |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
here's a link to make it easier: https://www.google.com/search?q=site...utf-8&oe=utf-8 There are several threads on the subject. Here's a review: http://www.ft86club.com/forums/showthread.php?t=50382
| The Following User Says Thank You to JohnJuan For This Useful Post: | JSube (08-15-2017) |
#499 | |
. Looked for "short" shifter and found everything but TWM
| TRD Quickshifter | lovebeingbleu98 | Brakes, Suspension, Chassis | 3 | 02-13-2014 01:14 AM |
| Amazing Wax | geb2391 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-12-2013 05:42 PM |
| The most amazing thing I've done with my BRZ so far | azngolfur | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-09-2013 09:23 PM |
| Concept-Three-LED's DRL's are AMAZING! | soros151 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-09-2012 02:42 AM |
