Old 03-25-2017, 11:08 PM   #491
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Right? Even with fresh stock bushings it's plenty tight. Any shorter and even more people would complain about not being able to shift into second when it's cold.
So. Damn. Smooth now. I like the concept of this short shifter, but I think the JDM or none would be best
MS, CSCS, TSAC-F, CPT
Old 03-26-2017, 12:03 AM   #492
Sounds like you got it dialed in. It's not rocket science but it takes some patience, doesn't it?
weederr33 (03-26-2017)
Old 03-26-2017, 01:32 AM   #493
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Yeah I still have to really tug to get into 1st and 2nd without the quickshifter. So I'm going to see if maybe I can somehow adjust the reverse lockout plate.
Contrary to you guys, my shift gate to 2nd gear widened after installing the bracket.
FYI, all the DIYs and videos I've seen posted say to adjust the reverse lockout with reference to the lever in 1st gear. That makes the gate slightly too wide because my lever would hiccup into a notch if I pulled any slight bit to the left instead of straight down in a 1-2 upshift. The service manual says to adjust the lockout with lever positioned in 2nd, not 1st. For the 0.8-1mm shim between the plate and lever I used a credit card before torquing down the plate down to 5.5 ft-lbs. 1-2 shift now feels perfectly precise.
Seeing as your guys' brackets caused your 1-2 gates to narrow and overlap into the lockout plate whereas my gate widened away from it says there's something way off with how the pieces fit between your kits and mine.
Old 03-26-2017, 09:49 AM   #494
stevesnj
stevesnj's Avatar
Originally Posted by switchlanez View Post
Contrary to you guys...
No No, don't you get it it doesn't work or installed right (i.e. TRD shifter) it's the part not the installer. While other have had success with the TRD those that haven't insist it's a flawed part it can't possibly be them.
My 2016 Build thread
Old 03-26-2017, 12:41 PM   #495
switchlanez
I'm not pointing the finger at installation error in that post. We've already been over that. I even said parts aren't fitting same.
The Following User Says Thank You to switchlanez For This Useful Post:
stevesnj (03-26-2017)
Old 04-01-2017, 08:09 PM   #496
stevesnj
stevesnj's Avatar
So I took a few video's of the Quickshifter in action. I haven't had any bolt loosening issues so I guess this is how it's supposed to function? You can see I shift hard to 2nd and 3rd and then some rev matching and normal shifting. The other video is with the car off and just cycling through the gears. It's notchy but not bad notchy but sportier I guess. Well iI hope this helps someone out to see how it it functions. The driving mode and knob is my 86 nanny rotary switch attempt. Looks bad and changing it to push button.:P . Any embed code for Vimeo?
The Following 3 Users Say Thank You to stevesnj For This Useful Post:
cbryant514 (08-17-2017), LancePower (04-02-2017), switchlanez (04-01-2017)
Old 08-15-2017, 10:23 AM   #497
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
TWM Short Shifter
Any opinions on the design or experience with this piece?
https://www.twmperformance.com/short...-short-shifter
JSube is offline   Reply With Quote
Old 08-15-2017, 11:20 AM   #498
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
google this: site:ft86club.com twm shifter
here's a link to make it easier:
https://www.google.com/search?q=site...utf-8&oe=utf-8
There are several threads on the subject.
Here's a review: http://www.ft86club.com/forums/showthread.php?t=50382
JohnJuan is offline   Reply With Quote
The Following User Says Thank You to JohnJuan For This Useful Post:
JSube (08-15-2017)
Old 08-15-2017, 01:31 PM   #499
JSube
JSube's Avatar
Embarrassed, but thanks, appreciate it . Looked for "short" shifter and found everything but TWM
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 12:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 04:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 08:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 01:42 AM
