Old 06-16-2018, 04:06 PM   #491
stlgrym3
Drives: 2017 Subaru BRZ Limited
You mean already been saved on my laptop? Also I noticed every time I open the Manager software it goes through some update process, is this normal?
stlgrym3 is offline   Reply With Quote
Old 06-16-2018, 05:08 PM   #492
stlgrym3
Is the stock ROM labeled as Original File in the first slot of list of tunes in the OpenFlash Manager?
Old 06-16-2018, 11:57 PM   #493
steve99
Yes
Old 06-22-2018, 05:35 AM   #494
skogs
Drives: GT86 2013
Euro V4
Does anyone know if there will be made v4 tunes for euro-models?
Improved throttle-map sounds good. The current v2 one is a bit aggressive, and i suspect it messes with the rev-matching on my auto.
skogs is offline   Reply With Quote
Old 06-22-2018, 06:20 AM   #495
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
There's no throttle map changes in V2 or V4. The AVCS maps can play havoc on AT particularly if you have a shorter FD or EL though.
Old 06-22-2018, 07:33 AM   #496
skogs
Drives: GT86 2013
According to their website, v4 will provide "Remapped throttle tables." But if it is the valve control doing the damage it won't matter. I'm guessing that most of the midrange boost in power comes from changing that system.
I'm back to driving stock now because of this issue, and i really miss the extra midrange torque.
http://support.openflashtablet.com/s...ne-files-v4-03
Old 06-22-2018, 08:54 AM   #497
Wayno
Wayno's Avatar
Only for MY17 and only for 6MT, which is what their dev car would be.
The 6AT doesn't respond well to turning the throttle into an on/off switch which is what people around here would refer to as "more responsive". You can work around most hardware, but it takes very subtle changes and patience.
The Following User Says Thank You to Wayno For This Useful Post:
skogs (06-22-2018)
Old 06-22-2018, 01:43 PM   #498
Kodename47
Kodename47's Avatar
Drives: UK GT86
The V4 tunes are based on euro/Aus spec files. If you wanted you could copy the OEM throttle strategy into the V4 file to see how it runs.... It's only 5 tables or so.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Yoshoobaroo (06-22-2018)
Old 06-22-2018, 04:22 PM   #499
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Huh, is that why the EVAP pressure OBD PID on them is dead?
Old 06-22-2018, 04:32 PM   #500
elBarto
elBarto's Avatar
Drives: Toyota GT86
The Euro V4 tunes released like a month ago on the website.
I've used ZA1JA01I as an example but just type in your needed CalId in the searchbar
V4 A01I
Don't use the supplied OFT def's to edit them (they are outdated), use a modified def from Wayno, Steve99 or Kodename47
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 06-22-2018, 06:51 PM   #501
skogs
Drives: GT86 2013
V4 A01I
The tune for my calid haven't been released yet, but I'll give it some time. Hopefully it will fix the problem. The rough shifts i get from v2 are not worth the extra power.
Old 06-22-2018, 07:09 PM   #502
elBarto
elBarto's Avatar
Drives: Toyota GT86
Wich CalId do you have?
Old 06-23-2018, 09:01 AM   #503
skogs
Drives: GT86 2013
ZA1JA00i
Old 06-23-2018, 09:32 AM   #504
tomm.brz
Drives: brz 2017 hksv2
the v4 for k00g euro MT is SO bad that is embarassing
not only it does make car slower than stock, it also knocks like -2 / -3 everywhere
i ask myself if they actually try them to some euro cars before releasing it or just randomly suppose they *could* work but they have no idea how they behave in the actual cars
specially stage1 and stg2+ are particularly bad
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
