#4985 |
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe 2006 Saab 9-3 2.0t 1997 Honda Accord Coupe 1995 Honda Prelude VTEC |
#4986 | |
Drives: WR Blue BRZ, 240Z
If the problem completely goes away with the Arm switch off, then it's either something in the ESC system (compressor, controller, harness) or something that the ESC system is interacting with (through the installation). Check you installation again. But if the ESC is shutting down the electrical system...STOP using it. Get in touch with Rob.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#4987 | |
Drives: VW
Thks, Rob. |
#4988 |
That's exactly what it sounds and feels like. I'll email you, thanks Rob !
#4989 | |
I did double check my installation and everything looked perfect. I haven't been engaging it since the issue started. I do appreciate your help and input though, it's nice having for the most part such a helpful forum. I'm going to try Rob's suggestion then get back to all of you on the outcome. On a side note, with the exception of this occurrence, this system has been amazing!
#4990 | |
#4991 | |
#4992 |
Erected Member
Drives: frs
Is this normal?
#4993 |
Well the compressor always needs to brake. Maybe his wasn't set strong enough for some reason.
If its not strong enough it can cause the engine to stall from continuing to force air into the engine. Normally it isn't a problem but if you go WOT and then clutch in right after and the brake isn't fast enough it can cause a stall. |
#4994 |
So I reset the compressor before leaving work as Rob suggested and it worked perfect! Everything is back to normal, I just hope it stays that way. Thanks everyone! By the way I do have to say Rob's customer service has been phenomenal.
#4995 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
Process for reseting the brake: how difficult was it?
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel Last edited by Sojhinn; 05-03-2014 at 03:09 PM. |
#4996 |
literally 5 seconds long. Don't even start the car lol
#4997 |
Erected Member
Drives: frs
Wanna share the procedure? Just in case we may need it in the future.👊💦
#4998 | |
Drives: VW
If you arm 'on' during WOT or a DR pulse the controller has not had time (2 seconds) to initialize...This may trigger a brake re-programming. It is old code that I used to adjust brake force on the fly. I have deleted this function on all but the first 5 kits with new firmware. Good to hear it is solved. Rob. |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
