go_a_way1
Old 05-02-2014, 09:10 PM   #4971
shif7i7down
Erected Member
Drives: frs
Originally Posted by jebuwh View Post
Is there anyone around the sgv/LA area that has one they would like to showoff? I am very interested in one of these haha
It seems that most of the esc owners are in cali 😞..
Can't wait to get mines, hopefully the may batch gets completed schedule. 🐲🐉🐡
shif7i7down is offline   Reply With Quote
Old 05-02-2014, 10:05 PM   #4972
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Next time you are in the Cites, Minnesota that is, let me know. Although I'll probably have my solution by then. LOL
Originally Posted by Sojhinn View Post
Looks like Im meeting up with a forum member this weekend to show off the Phantom. Its always fun to show people how great the kit is.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 05-02-2014, 10:08 PM   #4973
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
I'll be in Janesville over Memorial Day, let me know if yours is installed and I'll try to get in your area. Am interested and would like to observe one in action.
Old 05-03-2014, 01:37 AM   #4974
shif7i7down
Erected Member
Drives: frs
we'll have to wait and see if I can get it by memorial day, if all goes well you are welcome to check it out.
I'm not sure if it has to go through customs since it's coming from Canada, or how long it takes customs to release it.
Old 05-03-2014, 01:45 AM   #4975
DAEMANO
Time Traveller
Not sure if there are any Phantom ESC owners in LA. If you can get down to Orange County I'd be glad to show you my install.
Old 05-03-2014, 02:11 AM   #4976
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
I can probably do that. I'm all over for work. Though I know if I try one with the ESC I'll be forced to buy one haha
jebuwh is offline   Reply With Quote
Old 05-03-2014, 04:00 AM   #4977
DAEMANO
Time Traveller
Ok, pm if/when you'll be in the area. Also I can be at the Tuesday night meet in Irvine most Tuesdays.
Sent from my RM-940_nam_att_200 using Tapatalk
Old 05-03-2014, 04:04 AM   #4978
raven1231
I'm in Ohio lol
Old 05-03-2014, 05:45 AM   #4979
raven1231
So I got a problem... I am running the Esc on 93 octane with the oft tune. For the first few days everything was perfect. This morning However everytime after I engage the Esc all the lights on my dash turn on and the power is cut off causing the car to stall... Any ideas what's causing this ?
Old 05-03-2014, 06:56 AM   #4980
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
damn, that's the second esc down in the last 8 hours. Jpit's is down too http://www.ft86club.com/forums/showthread.php?t=64908
electronics can cause some weird things to happen.. I can think of only two ways for the esc to affect the engine.
1. the power from the dump batteries is either back feeding through the motor controller into the stock charging system, and either shorting the stock batteries, or putting voltage where it doesn't belong.
2. the motor/compressor is locking up causing the engine to starve for air.
You could take the compressor off the intake, and with the car turned off, have someone hit the wot switch to make sure it is working properly, if it spins up like normal, then you can probably count out the theory of it choking out the engine. If it doesn't spin, then your motor or controller is bad
Then you could unhook the ground wire from the motor controller to the negative battery terminal(which I believe is the charging path). This should remove any connection between the esc and the cars electrical system. With the charging path removed, you could test out the system again, the dump pack won't recharge so you will have only a few runs, but if you trigger the switch and the car doesn't die, then you know that power or a short from the dump packs are screwing with your electrical system, which would either be a bad dump pack or bad motor controller.
on second thought, you might want to unhook both the positive and the negative wires from the controller to the factory battery terminals, then tape them up to make sure they don't touch each other or ground against the body. If the controller or batteries are faulty in some way, it is possible for just one wire to still connect that signal to either +Voltage or ground via the dump batteries, likewise if the power is back feeding through the controller and the charging wire hits the body, you are could have some unwanted welding going on under your hood.
Old 05-03-2014, 08:22 AM   #4981
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
You need to isolate the problem. I suggest the following:
1. Read the ECU log to see what it thinks the problem may be. If this doesn't provide enough information you will want to trouble shoot the Phantom system, OFT & the installation itself.
2. Turn off the Arm switch on the cockpit indicator and see if the problem persists. Regardless of the result, disconnect the controller (+) and (-) from the battery as well as the 24V connector. This takes the ESC off line. The compressor will not cause enough restriction for the engine to stall/stop. If the problem persists it has nothing to do with the Phantom system. If the problem goes away, reconnect the system, paying attention to the hook-up sequence in the instructions. If it comes back, contact Rob...and don't use (completely disconnect) the Phantom system until Rob has had an opportunity to evaluate the problem.
2. Assuming that the problem presents itself in step 2 above, reflash to your OEM tune. If the problem persists it has nothing to do with the tune software. If the problem goes away, reflash the tune. If the problem continues with a reflash, but works with the OEM tune, contact Shiv.
3. If the problem is present with 2 & 3 above, the problem has nothing to do with the components of the ESC or tune, but you may have created a path for a short or similar problem. Recheck your work making sure that nothing is loose. It's possible that something was dislodged as you snaked wires. Look in the proximity of where you worked for a dislodged connector.
4. If you can't locate the issue, bring the car to the dealer for evaluation.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 05-03-2014, 08:39 AM   #4982
raven1231
Thanks, but the thing is it doesn't do it when going wot. With the system connected but off. So it has to be with t the system itself.
Old 05-03-2014, 08:56 AM   #4983
Gary in NJ
Gary in NJ's Avatar
It may or may not. Completely disconnect the controller and see if the problem is resolved. If not, look elsewhere.
Old 05-03-2014, 09:01 AM   #4984
raven1231
Being that it runs when its off makes me thing the tune isn't the problem either . Unplugging the controller will disengage the system thoufh right? Wouldn't that be the same as leaving it off ? Also it still pulls great when going wot and the voltage drops when engaged so I'm guessing the compressor is good as well
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
