03-21-2020, 03:46 PM | #4971 |
Drives: Halo 860
Is there any easy way to convert inches to degrees? It seems like everyone on the boards talks in inches but I only have degrees for reference on my own setup.
03-21-2020, 05:10 PM | #4972 | |
The Following User Says Thank You to strat61caster For This Useful Post: | deca (03-21-2020) |
04-09-2020, 01:05 PM | #4973 | |
Drives: '23 BRZ
For 90/10 street track, I run -3.2F/-2.5R camber and zero toe all around fwiw. |
The Following 2 Users Say Thank You to ZDan For This Useful Post: | CSG Mike (04-10-2020), strat61caster (04-09-2020) |
04-09-2020, 02:19 PM | #4974 |
My VTEC fluid is full
Drives: EFF JAY
-1* front camber with bolts is a high # (or low depending on how you look at it). You should be getting at least -3.2* with bolts, 225 tires, & OEM spring perch (clearance). Much like an SSC car.
04-09-2020, 02:34 PM | #4975 |
SSC Konis have a non standard enlarged upper bolt hole and use two camber bolts. -1.0 to -1.5 is exactly where one camber bolt in OE spec mounting holes should be.
04-09-2020, 02:53 PM | #4976 | |
Drives: EFF JAY
SSC Konis should have standard size holes. The enlarged holes were an issue (or advantage) in the past. SSC uses (1) camber bolt per front corner. And it should installed on the bottom. This is if you are following rules. |
04-09-2020, 03:37 PM | #4977 | ||||
The rules totally allow for using the 'factory crash bolt' from the bottom hole in the top position, the language allowing factory published/authorized methods of alignment adjustment is copy pasted from the Street class rules. https://www.reddit.com/r/Autocross/c...l_live_thread/ Quote:
https://www.ft86club.com/forums/show...&postcount=949 Quote:
04-09-2020, 04:25 PM | #4978 | |
Drives: EFF JAY
04-09-2020, 06:57 PM | #4979 |
Drives: 2023 BRZ
Your kindness is appreciated, iLuveKetchup.
Director of Rocky Mountain 86CUP
The Following User Says Thank You to Pat For This Useful Post: | CSG Mike (04-10-2020) |
04-10-2020, 11:52 PM | #4980 |
Drives: Track preped NA FRS
For all that is worth, as im sure most here already do this or have at least tried it. When I tried to squeeze the most camber out of 1 camber bolt + camber plates, as I was maxing at -3.4 in one side but could go all the way to -4.5 on the other side, the guy who makes my alignments decide to just slack all bolts with the car sitting on its weight. After readjust we were able to now get to -4.7 on one side and -5.0 on the other, so in classes where the hardware you have to work with is limited, this is probably one of the things to do to maximise your chances.
The Following User Says Thank You to Icecreamtruk For This Useful Post: | CSG Mike (04-13-2020) |
04-13-2020, 11:06 AM | #4981 | |
Be sure to try to re-center as much as you can, and double check thrust angle. Also, check your steering and measure ackerman in addition to caster, as by playing with tolerance, you're introducing a lot of new variables. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | i8ur911 (04-13-2020), Icecreamtruk (04-14-2020) |
04-13-2020, 12:56 PM | #4982 |
Drives: Miata
04-15-2020, 01:46 PM | #4983 |
04-15-2020, 02:08 PM | #4984 |
Drives: Miata
I don't understand what you are saying.
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
