Old 03-15-2016, 01:55 PM   #477
renfield90
The Stig's German cousin
Originally Posted by cawith View Post
Quick question:
Does clearing engine codes with the OFT reset fuel trims?
When I left for work today, the car gave me CEL and airbag light after a few meters. So I stopped - checked the code (U0073 - CAN COMMUNICATION BUS A OFF) - reset it. Thereafter I turned off the car, reconnected OFT and everything was normal again.
However my LTFT was 0% most of the 30 minute drive to work, which seems to good to be true. It did however vary a bit, mostly at idle with 0.78%. I've just passed 100 km since last flash...
Yes, fuel trims get reset. The idea is that if you had a genuine CEL (something like running too rich), once you applied a fix for that all fuel trims currently stored wouldn't be valid and it's best to start over from scratch.
Bus off error suggests you have a loose or questionable electrical connection to an ECU somewhere.
Old 03-15-2016, 04:13 PM   #478
cawith
Drives: Toyota GT86 6M/T
Damn, now I have to let it learn for another 100 km
Yeah, yesterday on the way home from work my leg somehow hit the OBD cable and mostly wiggled the connector loose. It didn't give me a code then, but driving of today did...
cawith is offline   Reply With Quote
Old 03-15-2016, 05:40 PM   #479
renfield90
If it happens again, recommend you disconnect from OBD, turn the car all the way off for five seconds, turn it back on and see if CEL is still present. My guess is a bus off error might go away if the problem is resolved and save you from having to wipe out your fuel trims.
Old 03-15-2016, 06:52 PM   #480
cawith
I'll remember that, thank you!
Old 03-23-2016, 10:05 PM   #481
SoCalArgento
Drives: 2014 Argento FRS
Is there a time limit for unmmarying an oft?
For example: Can I flash my original (stock) tune from oft to car on a Friday, then wait till Monday to unmarry oft on ofm?
Thanks in advance!
SoCalArgento is offline   Reply With Quote
Old 03-24-2016, 11:26 AM   #482
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Thanks in advance!
You can
tato.valverde is offline   Reply With Quote
Old 03-24-2016, 01:35 PM   #483
SoCalArgento
Originally Posted by tato.valverde View Post
You can
Awesome, just thought I might ask just in case.
Thanks!
Old 03-24-2016, 07:02 PM   #484
pinetree
pinetree's Avatar
Drives: 2013 BRZ Limited
Hi,
Having some issues clearing a check engine light on. Recently got JDL unequal length headers and got a code (guessing O2 sensor), updated to stage 1, and code went away.
Today while on cruise control light went on, and I lost cruise control functions. Got home, and used OFT to check what the problem was, however it says theres no codes to be found. I saw this on the first page:
CEL Code reading clearing - OFT only reads Engine ECU CEL
OFT will read and clear CEL or Engine check light code.
Note the OFT only reads Engine ECU codes it won't read Body computer or Auto Transmission codes. so it possible to get a CEL light and OFT says "No Codes" however it will clear all codes I believe. To read the other codes suggest you get Techstream and suitable adapter or a cheap ELM327 Bluetooth adapter and Android Torque app
I have a manual and never had issues before. I go to the diagnostics tab and check but again OFT says nothing is there, what am I doing wrong?? Any help is much appreciated!!
pinetree is offline   Reply With Quote
Old 03-24-2016, 09:15 PM   #485
steve99
Originally Posted by pinetree View Post
Hi,
If you have catless header you should be on stage 2 tune as they are for catless header and have p0420 code disabled.
oft should read that code though
each time you flash the ecu is reset along with any ce codes
you might be getting a can buss communication code if your connection to obd port is not good that code the oft wont read
you can reset cel codes by diconnecting battery and pressing brake pedal, this will reset ecu .
Old 03-24-2016, 10:55 PM   #486
pinetree
pinetree's Avatar
It's actually catted, which makes it all the more strange. Still not sure why it can't read the code though? Am I correct in that I should have the car on (not engine) and plug in OFT, go through diagnostics, and check ECU?
Guessing I should go to stage 2, flash it, and see what happens.
Also having the issue of not having the cruise control work anymore...is that the car's way of being in 'safe mode' or something?
Old 03-25-2016, 03:38 AM   #487
steve99
even catted headers can cause cel code P0420 as the ecu expexts a cat with the same charastics as the stock one and many aftermarket cats are different enough to still cause the ecu to think its got a problem. you can disable the p0420 in the stage 1 rom and it will be fine
Old 03-26-2016, 07:57 AM   #488
KHANrad_SIN
Drives: Whiteout
Does anyone know what EL header was used when making the EL stage 2 tune?
KHANrad_SIN is offline   Reply With Quote
Old 03-26-2016, 06:18 PM   #489
steve99
best ask the oft guys, but from memory i think itwas an el header the oft guys were developing but they then decided on uel header
Old 03-29-2016, 10:22 PM   #490
SoCalArgento
How can we adjust idle rpm on romraider for the oft? I want to raise it a little higher than the stock 750?
I did a quick Google search on phone and nothing.
Thanks for the help!
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
