Old 01-23-2014, 05:53 PM   #477
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Originally Posted by Bigmaxy View Post
Thanks Skorov (and others). I do believe this is an AU/EU possibly JP issue.
In searching the net I have seen images of cars which still have the washers installed including @nix
I noticed nix had a cable tie holding the intercooler piping back but others don't seem to have needed to do that. Just not sure if I need to trim one of the hoses. Possibly the one going to the intercooler to bring the hose closer to the centre of the car so it passes to the inside of the washer.
Thanks again all. Cheers
His zap tie issue I believe was cause he was one of the first kits. I believe he said that he mentioned the issue to avo and they corrected it
Not sure why the washer bottle issue still exists tho as I thought he told avo about that as well
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 01-23-2014, 05:59 PM   #478
Bigmaxy
Drives: Pegasus GTS86
Cheers. Just to be clear. It's not the washer bottle that is the problem. Rather it's the washer jets for the HID headlamps.
I've done the mod to lower the washer bottle down, so that is sorted. :-)
Bigmaxy is offline   Reply With Quote
Old 01-23-2014, 06:53 PM   #479
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
I had the same problem as well, but i did manage to fith the bumper back on with the headlight washer. It wasn't a perfect fit and there are a small gaps as well, but they still work after testing them out. Going to get back and post some pics later.
liquidsky44 is offline   Reply With Quote
The Following User Says Thank You to liquidsky44 For This Useful Post:
Bigmaxy (01-23-2014)
Old 01-23-2014, 09:22 PM   #480
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
I still have my washer fitted - you can see it in the pictures here (the ic pipe has been held back via a cable tie)
Pitman is offline   Reply With Quote
The Following User Says Thank You to Pitman For This Useful Post:
Old 01-23-2014, 10:33 PM   #481
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Originally Posted by Mr.Jay View Post
I believe this is a au/eu issue as @nix dealt with the same thing.
I believe his solution was to drill out the hole a bit bigger and drop the washer fluid bottle down more.
Check his build thread
The instructions says that, so you have a couple of inches of clearance.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 01-23-2014, 10:35 PM   #482
Bigmaxy
Awesome. Do you know if some trimming was also required of the pipes or any other techniques such as sliding the silicone hose a long way up the pipe to the throttle body?
Just went down and bought some long cable ties so will give that a go but feels like a lot of force will be required to hold them back.
Thanks heaps.
Also thanks @Draco_PR23 and @Mr.Jay The pictures above may show what it is I am referring to. It's the headlight washers rather than the washer fluid bottle that is creating the grief. Only cars with the HID washers would have this problem. I spoke to Lee @ Avo and he suggested trimming the intercooler silicone hoses down to provide more clearance. I've already taken off 30mm from the right hand side (drivers in my country) and it has helped. I'm thinking cable tie for the rest. Could possibly take more that 30mm off but I don't want to get cocky. I took 15mm off the side with the washer fluid bottle.
The Following User Says Thank You to Bigmaxy For This Useful Post:
Draco_PR23 (01-23-2014)
Old 01-23-2014, 10:45 PM   #483
Draco_PR23
Fiebru
Draco_PR23's Avatar
Thanks heaps.
As far as I know, no trimming is required ... I didn't had any problems with that pipe, but I tried to slide the hose as much as I could to the pipe is really close to the pulley.
To help you slide the hose to the pipe some ppl use hair spray or some kind of oil lubricant.
Edit: Got it! Here we don't have those, didn't know it was an issue.
Current Cars:
Old 01-23-2014, 10:45 PM   #484
liquidsky44
As you can see without any adjustment the bumper would still fit, but not seated perfectly as it used to.
The Following 2 Users Say Thank You to liquidsky44 For This Useful Post:
Bigmaxy (01-24-2014), Draco_PR23 (01-23-2014)
Old 01-24-2014, 07:38 AM   #485
nix
nix's Avatar
Drives: AVO BRZ
Yeah we used the biggest (widest) fuck off cable tie we can find and because the FMIC pipe was actually over length we were able to pull it back out of the way.
Then with the oil cooler install the way it mounted had to remove the washer assemblies, and crimp the lines, disconnect the pump etc.
Have since removed that oil cooler kit and gone back to washers for the time being.
@Pitman what shroud do you have for your oil cooler or where can I see more pics of it in action? I really should get on here more and read up on peoples threads ...
Edit ... I don't know if AVO ever addressed this. They generally said 'oh that's interesting, we never had that problem' whenever I reported any issues, but to their credit they seem to have made a lot of changes to the kit. They liked what I did with my car and were helpful and sent free replacement parts on anything that didn't fit properly or broke on me. I also had a nice long chat with Ross Wilson about the platform, my car, his car, and where ft86 is going.
nix is offline   Reply With Quote
Old 01-24-2014, 07:45 AM   #486
Pitman
Living the dream
Pitman's Avatar
@nix
I made the shroud myself:
Mould:
Vacuum bagging:
Off the mould:
Fitted:
Air in through a modified FR-S bumper moulding (I have removed the front fog lights)
Air out through louvers fitted into the plastic wheel arch liner:
The Following 16 Users Say Thank You to Pitman For This Useful Post:
blackfireball5 (03-24-2014), DAMotorsports (01-24-2014), DeliciousTuning (01-27-2014), DesertFrs (01-25-2014), Draco_PR23 (01-24-2014), jamesm (01-27-2014), lightdir (10-04-2015), Mr.Jay (01-29-2014), nix (01-24-2014), OmarGC (01-25-2014), protpibe (01-27-2014), RallySport Direct (01-28-2014), rixter145 (05-09-2020), shaunsweeney (01-24-2014), Sportsguy83 (01-24-2014), turbocat (06-29-2018)
Old 01-24-2014, 08:39 AM   #487
nix
nix's Avatar
Drives: AVO BRZ
That is a brilliant job and what I had considered doing many times, but with far less skill. Have you monitored your IATs with that setup and if so what peaks have you seen when the car is stationary and fully heat soaked (hopefully with a hot ambient)?
The Following User Says Thank You to nix For This Useful Post:
Pitman (01-24-2014)
Old 01-24-2014, 08:44 AM   #488
Pitman
Living the dream
Pitman's Avatar
Thank you for the nice comments. I haven't done any monitoring - sorry
Hot ambient in the UK?
Old 01-24-2014, 08:53 AM   #489
nix
nix's Avatar
Drives: AVO BRZ
Yeah wishful thinking. It's hitting 45c here for the second summer in a row since I put my kit on.
The Following 2 Users Say Thank You to nix For This Useful Post:
DAMotorsports (01-25-2014), DesertFrs (01-25-2014)
Old 01-25-2014, 01:58 AM   #490
DAMotorsports
Drives: 2013 Scion FRS "Raven"
lol we see temps of 125F and the track temps tend to be higher
DAMotorsports is offline   Reply With Quote
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
