Old 05-16-2014, 01:33 PM   #477
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by AN View Post
Great ... can you share a link of the ebay item ... also ... I know you have gone through a few motors but in you opinion .. what is the best motor(s) to couple to this new find ?
I just want to start looking/reading on a possible setup.
Thanks
http://www.ebay.com/itm/Seadoo-super...vip=true&rt=nc
This is the one I bought, but there are lots of others. I just went for one of the cheapest I'm not sure what shape the wheel/housing will really be in but it should be good enough to build a test rig.
The biggest motor I currently have is the Turnigy Aquastar T20. That's probably going to be a good match. I was doing some looking on hobby king and I saw this http://hobbyking.com/hobbyking/store...m_Fan_5kw.html it's 5000W and 870Kv so in a 24V system it could run at an average speed of around 20K RPM, and assuming max charge of 28V you might get as much as 28K RPM.
Old 05-16-2014, 02:02 PM   #478
neutron256
neutron256's Avatar
Originally Posted by rusty959 View Post
First of all, 60 farads will lose over 3V each second with the power levels we are looking at.
Furthermore, car audio caps usually have a max voltage of 18-20 volts, so you would only be able to use a single battery (12v) battery with that cap, else put them in series which halves the capacitance. So it would take 4 of those caps to get 30 farads on a 24v setup. 60F would need 8. Therein lies the big issue with running high voltages with caps.
If you look that cap is actually for 24V
Old 05-16-2014, 02:06 PM   #479
rusty959
Drives: DGM BRZ limited
Solid point. I missed that, since I expected important info like that to be in specs.
Regardless, 5kw from that cap will still go quick.
rusty959 is offline   Reply With Quote
Old 05-16-2014, 02:13 PM   #480
neutron256
neutron256's Avatar
Yeah I agree. I found a good calculator at one point which made it clear that caps alone won't do the job. But I will say running them in parallel with a battery bank is a whole different animal.
Old 05-16-2014, 02:15 PM   #481
stugray
Drives: 2013 GBS BRZ Limited
A lot of this could be solved by moving the power system to the trunk as some have with the Phantom ESC.
Or perhaps some of it can be tucked up inside the fenders above the fender liner.
I have never taken out a liner and looked, but I suspect a significant amount of space in there.
I heard about a twin turbo kit for a corvette that puts the turbos in the rear fenders....(with that much plumbing, I am guessing that an intercooler is not required :-)
Old 05-16-2014, 02:20 PM   #482
neutron256
neutron256's Avatar
It's possible. The only reason I haven't gone the direction of putting the power system in the trunk is the complexity. Same issue if you were to tuck it into the fender. Fabricating mounts, and the work to actually install it is very time consuming.
I really want to design a system that someone could build with minimal custom fabrication. But for others interested in a more complex setup I encourage them.
Old 05-16-2014, 02:48 PM   #483
AN
Drives: 2010 MX-5
Actually no .. since it will be in parallel to the battery , its voltage will not drop a whole lot more than the battery ... as immediately charges itself from the battery. Those combo will not discharge quicker than the battery alone. The cap only increases the systems ability to provide high spikes in current demand ... which the 1.5 pack shows is a bottleneck for the Pb-Acid batteries for this scenario.
We can find some caps that surge at 30V. Even if we have to put 2 caps in series ... the capacitance halves but energy storage doubles ... given twice the voltage ... we do not have to go huge on caps in the first go around ... I think 2x of the most compact caps with 10+ F in parallel should do the trick ... again .. not for primary energy delivery but to ease the most extreme loads on the battery pack. What implication will it have on the motor controller ... I am not sure ...
AN is offline   Reply With Quote
Old 05-16-2014, 02:54 PM   #484
AN
Drives: 2010 MX-5
I agree ... I think Rob had a great reply on the battery pack being too far away from the motor ... its all big gauge high current wiring ... needs a lot of heavy duty connectors/ fuses ... cost goes up fast.
An easy way is to move the starter battery to the trunk and keep the ESC batteries in the engine bay. Also , using 6x or 8x 10Ah batteries will give more flexibility. I think 6x batteries will fit in the existing bay ... An appropriate sized/shaped dual cap combo can find some reasonable home int he engine bay too.
Also, neutron256 I think the MinnKota charger is a great find but kinda bulky. It would make aesthetic sense to have all the electronics as compact as possible .. ideally in a single enclosure.
The Following User Says Thank You to AN For This Useful Post:
neutron256 (05-16-2014)
Old 05-16-2014, 02:58 PM   #485
neutron256
neutron256's Avatar
I currently have 12 1500f 2.7 volt ultra caps. I did the calculations once, I don't remember what it worked out to but it would be a good setup run in parallel with a 24V battery setup.
Old 05-16-2014, 03:00 PM   #486
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
That would be ~32V in series.
Luckrider is offline   Reply With Quote
Old 05-16-2014, 03:01 PM   #487
neutron256
neutron256's Avatar
I agree about it being bulky. It is just so perfect for this application otherwise though. I have considered cracking it open and seeing if it could be cut down in size at all.
Old 05-16-2014, 03:02 PM   #488
AN
Drives: 2010 MX-5
Nice .. how big are they ? any pics / links.
Old 05-16-2014, 03:02 PM   #489
neutron256
neutron256's Avatar
Correct in theory, but without a charge balancing setup you don't really want to push them beyond 70-80% of their total charge.
Old 05-16-2014, 03:04 PM   #490
neutron256
neutron256's Avatar
http://www.ebay.com/itm/Maxwell-1500...item461a649e50
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 05:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
