#463 |
Drives: 2014 BRZ
Figured I'd post mine too
#464 |
After 3 weeks, mine are fading to pink instead of red. Deffinetly getting professional clear sprayed next time but went with spray paint clear this time after I got a few pieces of crap in the tint layers and knew I would have to redo.
#465 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Did you use metalcast and a good clearcoat? Mine look like factory red still after a year--you can fix this yourself
#466 |
Drives: 2013 frs
Some nice stuff In here
#467 |
Drives: sc00ter
how well are you guys painted lights holding up? and how long has it been?
#468 |
Drives: 2015 Raven FRS
My painted lens are holding up just fine.
#469 |
Mine still look like the day I redded them 1 year ago. Still glossy and the few people that noticed and asked me about them were shocked that it was not stock and a DIY job.
I highly recommend spraymax 2k spraycan clearcoat or a professional clearcoat. |
#470 |
Drives: Whiteout FR-S
Mine are starting to fade a bit around the areas that didn't receive enough clear. Any suggestions on how to fix/respray? Can I just respray some clear on them? Or should I just redo the whole thing?
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#471 |
Drives: brz
You would have to respray the whole thing. You can just scuff it up with 1000 or 1500 grit sandpaper or even a red scotchbrite and respray it no need to completely remove the old paint. So it doesn't fade again I recommend a professional automotive clearcoat that's sprayed from a spray gun but if you cant do that then Spraymax 2k rattle can works really good.
| The Following User Says Thank You to ysr50guy For This Useful Post: | Tt3Sheppard (09-14-2014) |
#472 |
Drives: '13 Scion FR-S
Thanks for the detailed write up and suggestions from every one else. I am tired of looking at the stock tail lights, but could not afford aftermarket red tail lights at this time
Did mine today, I used duplicolor metalcast and spraymax2k. they still look foggy, I will keep them on my car for a week, then remove, wetsand the hell out of them and will polish them for the glossy finish.
#473 |
Weird that they are not clear. Mine came out shiny using the same paint/clear. What kind of sanding did you do, if any (at what stage(s) in the process). They don't look that bad in the pics.
#474 |
I used 1000 and wet sanded each time after spraying metalcast. But after applying clear coat I didn't sand it yet.
#476 |
| Are you going to smoke out your tail lights? | Liquidsnake | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-06-2012 10:02 AM |
| HKS head and tail lamps | DIG1992 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-19-2012 02:04 PM |
| Tail of the Dragon | Tomcat9700 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 02-10-2012 03:30 PM |
| Optional coloured tail lights? | m_life | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-30-2011 07:20 PM |
