View Poll Results: Have you had an issue with your Direct Injection System?
I have had a DI issue and was fixed under warranty (Subaru) 10 12.35%
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) 2 2.47%
I have had a DI issue and was fixed under warranty (Toyota) 31 38.27%
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) 3 3.70%
I have had a DI issue and denied warranty by (Subaru) 7 8.64%
I have had a DI issue and denied warranty by (Toyota) 14 17.28%
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) 8 9.88%
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) 6 7.41%
Voters: 81. You may not vote on this poll
Old 01-30-2014, 10:36 PM   #463
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
My cylinder one DI seal failed after tracking my car for a year.
I paid a 3rd party mechanic to replace all four seals, updated my ECU with the Toyota fix, added an oil cooler, and replaced my coils with Okadas. After a second year of tracking I had my injectors pulled this week and all four were still good.
romin is offline   Reply With Quote
The Following 4 Users Say Thank You to romin For This Useful Post:
DAEMANO (04-04-2014), normancw (02-04-2014), Ozzman (02-26-2014), SuperDave (04-19-2014)
Old 01-31-2014, 12:23 AM   #464
strat61caster
strat61caster's Avatar
Did the mechanic do the flash or dealership?
I'm trying to get the courage to go to the dealership and fight for the tune, mine doesn't do the rpm drop anymore so the TSB technically doesn't apply to me...
ineedyourdiddly
Old 02-01-2014, 02:04 AM   #465
romin
romin's Avatar
I did the flash - EcuTec
The Following User Says Thank You to romin For This Useful Post:
strat61caster (02-03-2014)
Old 02-01-2014, 11:26 PM   #466
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
What's the warranty on the DI issue? Is it 5yrs/60,000 mile, or 3yr/36,000 mile?
I'm coming up on 2 years of ownership this June but only have 5,500 miles on my car. Dealer did a reflash last summer but I'm not sure for what. I haven't experienced anything people have mentioned in this thread but sometimes get a very brief idle dip. I normally shift by 5000 rpm but have taken it past 6000 from time to time. Never tracked, tuned, or modded in any way.
ashtray is offline   Reply With Quote
Old 02-02-2014, 12:17 PM   #467
Lonewolf
Lonewolf's Avatar
Drives: Moped
It is a powertrain issue so the warranty would be 5/60,000 miles...
Old 02-04-2014, 02:24 AM   #468
microcarmag
Send a message via AIM to microcarmag Send a message via Yahoo to microcarmag
so after reading all of this... looks like I may have this same issue - Car is with dealership right now and they are basically looking at the injection system... Car basically got a warning light then traction control light went on... then started having idle issue... This is really sad but good thing is I am still under power train warranty...
Founder / Writer - MicroCarMag
Driver / Builder Project Chimera - https://www.facebook.com/MCMProjectChimera
Check out my sponsors: D2BD Motorwerks / Bavaria / Nutek Wheels / Continental Tire
microcarmag is offline   Reply With Quote
Old 02-09-2014, 11:11 PM   #469
tailspin
tailspin's Avatar
Drives: Honda
Is this DI issue only affecting earlier 2013 cars or is this unresolved and continues to affect 2014 cars as well?
tailspin is offline   Reply With Quote
Old 02-10-2014, 01:20 AM   #470
trd87t
Drives: Supra, BRZ
^ x2
In for this info as well if someone has had this with their 2014.
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB
trd87t is offline   Reply With Quote
Old 02-26-2014, 09:34 PM   #471
bjun
bjun's Avatar
Drives: white premium brz M/T
I purchased the 700cc fuel injectors with my turbo kit and wondering if it replaces OEM DIs?
bjun is offline   Reply With Quote
Old 02-27-2014, 08:45 AM   #472
andrew20195
Drives: 2013 Subaru BRZ
Highly unlikely.
andrew20195 is offline   Reply With Quote
The Following User Says Thank You to andrew20195 For This Useful Post:
bjun (02-27-2014)
Old 02-27-2014, 08:47 AM   #473
bjun
bjun's Avatar
Originally Posted by andrew20195 View Post
Highly unlikely.
Ah I see. So they are two different things?
Old 02-27-2014, 10:12 AM   #474
FRSure
Drives: Toyota
Just a question, does this problem only affect manual transmission cars?
FRSure is offline   Reply With Quote
Old 02-27-2014, 10:39 AM   #475
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
It might be a good idea to understand the system before you continue. Read the article and watch the vid at the bottom. http://www.treadstoneperformance.com...brz-explained/
turbocat is offline   Reply With Quote
The Following User Says Thank You to turbocat For This Useful Post:
bjun (02-27-2014)
Old 02-27-2014, 12:57 PM   #476
bjun
bjun's Avatar
So is anyone using aftermarket DIs?
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
