Old 03-07-2013, 06:25 AM   #463
Sonolin
Any word on e85?
I haven't heard anything from "Unichip Jack". Considering purchasing, but waiting out for e85 as I definitely want to try that.
Sonolin is offline   Reply With Quote
Old 03-07-2013, 10:37 AM   #464
ML
ML's Avatar
Drives: 13 White MT FR-S
Anyone else have the injen intake map only? When i run the unichip on 0 everything seems fine, but on 1 (which I assume is the aggressive version, but have no way to know for sure) the car bogges down really bad when idling sometimes, or when I hit the throttle from 1st and 2nd there is a slight delay in throttle response. Also it seems I'm getting bad gas mileage from this map (24~25mpg). Looking at a graph of my Air fuel ratio the line is very jagged, and not smooth at all. Any thoughts or experience?
Old 03-07-2013, 11:18 AM   #465
blkwrxwag
Drives: DS FRS
I have the Injen map + exhaust. I also found that the 0 map worked really well and the 1 map just seemed a bit boggy. I assumed that was because of the crap CA gas as the 1 is for 92 octance, and we only get bad 91. I'm going to try downloading the software and try the 0 map + more timing in increments to see if the best map is somewhere between the two.
blkwrxwag is offline   Reply With Quote
The Following User Says Thank You to blkwrxwag For This Useful Post:
ML (03-07-2013)
Old 03-07-2013, 11:19 AM   #466
ML
ML's Avatar
I run Shell 93, so I don't think its fuel.
Old 03-07-2013, 11:20 AM   #467
blkwrxwag
Drives: DS FRS
I would give Jack a call if I were you. I have found him to be very helpful.
Old 03-07-2013, 11:26 AM   #468
ML
ML's Avatar
He actually already messaged me seconds after I posted, and said the same thing about the fuel. Also it could be the wrong map or bad map.
Old 03-07-2013, 11:27 AM   #469
blkwrxwag
Drives: DS FRS
One of the reasons I went with Unichip was Jack's great customer service - let us know how it works out.
Old 03-07-2013, 12:57 PM   #470
Hix
Hix's Avatar
Drives: 2017 WRB PP
Was the same thing with my Perrin Map 1. It was not as peppy as map 0. I finally found the right map for my car which was fuel - timing +
Each area has different gas, elevations, etc... You really should get a usb cable from him and try out which map works best. These are generic tunes but he has so many variations of each one that you should be able to find what works best for your car.
Hix is offline   Reply With Quote
Old 03-07-2013, 02:40 PM   #471
subiestar
Drives: CBS Limited BRZ
So you guys have not downloaded the software and re-mapped your Unichips yet? And you're running maps that came delivered from Jack?
If that's the case, then Map 0 would be the 87 Oct map and Map 1 is the 92 Oct map. And you cars run better on the Map 0 87 Oct map?
Just trying to get a better understanding.
subiestar is offline   Reply With Quote
Old 03-07-2013, 02:46 PM   #472
ML
ML's Avatar
that is correct. I just ordered a cable, so I'll get to the bottom of it soon enough. There was nothing in the packaging that confirmed what maps they put on, at least that i saw. Maybe that would be a good thing to include in the future?
Old 03-07-2013, 02:46 PM   #473
blkwrxwag
Drives: DS FRS
That is correct, although I was told that my map 0 was for 89 octane.
I'm just using the maps that came with it, as I have not had time to set up the software/download stuff yet. Definetely planning on it though.
Old 03-07-2013, 03:03 PM   #474
subiestar
blkwrxwag - looking forward to hear what map works best for you. I'm also in SoCal.
I have the Apexi drop-in filter, but my car seem to like the Stock maps better than the "All Drop-in Filter" maps. So far I like the 92 Oct Fuel Standard Timing Out Stock map. Going to try Fuel Out next.
Old 03-07-2013, 04:06 PM   #475
Ingeberger
Ingeberger's Avatar
Drives: 2013 Scion Fr-S
Hey, I'm in SoCal as well haha. Which setting is the stock map and which setting is the all drop in map (as in 0 and 1)? Can you comment on the map you prefer (Stock); what's better about it? I have my unit coming in today and have the same setting, "All drop-in filters". Thanks!!!
Ingeberger is offline   Reply With Quote
Old 03-07-2013, 04:07 PM   #476
blkwrxwag
Drives: DS FRS
Sure, although it may be a few weeks before I get to it. Too many big autocross events this month in my other custom tuned car!
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
