#463 | |
i'm sorry, what?
Drives: Canada
unlike Football, F1 racing has a very poor mentorship program. THere is no such thing as highschool Formula 1, College Formula 1, backyard-Formula 1, chilling on the beach throwing the ball around Formula 1. There are those kids whose families could afford to get them into the karts, then into the F-series levels, and so on and so forth. Remind me again how much Schumacher had to pay out of his own pocket to get a seat in an F1 car? The culture of support just isn't there, so until karting becomes an after-school activity any kid can participate in, we're not gonna see anything of the sort. |
#464 |
AIM4APX
Drives: 2013 WRB BRZ Limited
You're right. Nothing in F1 has ever been applied to road cars, and nothing in expensive cars ever trickles down to affordable cars.
VVT came from 1980's motorcycles? I don't understand. "Dunlop’s development of caliper-type disc brakes for the Jaguar C-Type racer in 1953 that pushed the braking format we know today into the mainstream. They were reliable, dependable, and infinitely more effective than the then-ubiquitous drums; Jaguar’s victories at Le Mans were more than enough to convince manufacturers that this was the way to go for road cars." Ok...so not from F1, my mistake. But my point still holds that the innovations in F1 (and other top end race series) do trickle down to mainstream cars. The new Alfa C4 uses a carbon fiber chassis...that's not due to the advances and common use in racing that made that possible? At the very least F1 tech trickles down to other racing series, which trickles down to mainstream cars. FYI that's a 50K car with a carbon fiber tub...These things will be in mid-range cars in 10 years. You will see a 30-40K turbo 4cyl hybrid car (ala Mclaren P1) on the road in 10 years.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#465 |
Drives: RV-7
^ You wrote: "VVT (Honda developed VTEC in F1)"
Honda's first VTEC application was the 1983 CBR400 motorcycle. |
#466 | |
Drives: '06 AM V8V Coupe
As for the electric motors thing, okay 2.5kW/kg is 1.2kW/lb or 2.5hp/lb, which isn't far off, but I guess 4hp/lb isn't as easy as I made it sound. The permanent magnet motors in the Leaf and Prius have very low maximum speed limits and if I understand correctly the maximum rotational speed is more or less what determines the power output as the torque limits are hit very easily. The Tesla Roadster's motor is hand wound but it has 288hp for a bit over 4hp/lb, but if you look at the published torque curves it seems like that number is power electronics limited because the hp is constant past a certain point (whereas if it were mechanical strength limited, you wouldn't have to reduce the torque that much). The capacitative systems are close but probably not ready. Taiyo Yuden and such kept on announcing the production of hybrid capacitors a few years back, and nowadays you can buy them online, but they aren't much better than the traditional ultracapacitors. Also Toyota definitely has not produced variable lift engines for years, the only ones have been the 2ZZ-GE, and recent 1ZR-FAE/2ZR-FAE/3ZR-FAE. Everything since 97 has had VVTi on at least the intake cam though, but so has every other manufacturer... That said their Atkinson cycle strategy could work well; The 2GR-FXE is rated 247hp (much healthier than the 1NZ-FXE in terms of hp/L), and can probably make more power if you spin it faster. It's a nice solution because it's very cheap compared to turbo + smaller engine, but if that smaller engine is say a BMW N20 or even a Honda R18 you're going to lag on efficiency. Depends on your definition of VTEC. That "VTEC" was just shutting off one of the two intake tracts, which is inferior to even a cam phasing system. Toyota had it too on the 4A-GE. That aside, F1 doesn't seem to be the best way to develop production car relevant things. Yes new rules force them to figure out how to build certain things certain ways but there isn't much room for getting creative when the entire powertrain is basically specified for you, minus some tweaking of materials here and there. I don't know if VTEC really came from F1 but I kind of doubt it seeing how fixed camshafts was part of the rules for so long. |
#467 |
Drives: Nevermorange FRS
I think (meaning I did no googling) that Honda didn't have a need to develop VTEC in F1 because A) VTEC is meaningless in a straight purpose race car (that's why VTEC-Killer cams exist), B) I'm not sure the rules would have allowed multi-lobe cams.
VTEC has no application in a race car. VTEC's big claim to fame is that a STREET car could have the best of both worlds: low-rpm verifiability while meeting emissions and getting great MPG's while also having a racing oriented aggressive cam profile for higher RPM's allowing the engine to make power in an RPM range higher than the smaller cam profile would allow. It was like having a street engine and a race engine in 1. On a race track, you only need the race engine.
SCCA T4 - FRS
| The Following User Says Thank You to rice_classic For This Useful Post: | Rayme (03-19-2014) |
#468 |
IN F1 NEWS...
Sweet sweet merciful irony BATMAN! http://en.espnf1.com/f1/motorsport/story/150031.html Ferrari and Mercedes defend and back the FIA in the face of the RedBull DQ appeal. Buwahhahahah! RedBull wants to throw Ferrari and Mercedes under the bus for Tire Testing in the 2013 season, there should be no surprise that Merc and Ferrari show up to the FIA and say, "Yeah, fuck those RedBull guys."
SCCA T4 - FRS
| The Following User Says Thank You to rice_classic For This Useful Post: | cfusionpm (03-19-2014) |
#469 | ||
Drives: Firestorm 6MT Scion FR-S
This rules shake up has been nice, but it's still the usual suspects in the top constructors spots.
![]() 2013 Firestorm 6MT Scion FR-S |
#470 |
i'm sorry, what?
Drives: Canada
#471 |
APEXHNTR
Drives: 10 Series FR-S #1867
Don't mean to stray from the current debate but.......
Does anyone think the next race in Malaysia may be postponed or cancelled due to the missing Boeing and the shitstorm that goes with it? Kinda the way NYC cancelled the marathon because people were still recovering from Hurricane Sandy?
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#472 |
Drives: '13 BRZ in WRB--let's mod!!!
#473 | |
Doctor
Drives: Fast
#474 |
Drives: Ultramarine toyobaru
Ahh yes Malaysia. Multi 21 Seb... multi 21
| The Following User Says Thank You to headlikeahole For This Useful Post: | Superhatch (03-20-2014) |
#475 |
Drives: RV-7
Should be a brutal test of the new cooling systems. I think Malaysia is usually the hottest GP of the year.
| The Following User Says Thank You to torqdork For This Useful Post: | FnFast (03-20-2014) |
#476 |
I would have thought Bahrain, which is right after. Both have a lot of full throttle/high engine demands. Both will be hard on teams and I'm guessing we will probably see just as many retirements as we did in Australia.
| Tags |
| no mikey nooo, supersupermaxmax, waawaaalewis |
| Official What are you listening to thread? | TRDMAN | Off-Topic Lounge [WARNING: NO POLITICS] | 2332 | 12-24-2024 11:16 PM |
| Official San Antonio , TX Thread!! | track_warrior | Southwest | 3762 | 03-28-2019 03:03 PM |
| FORMULA D Round 1 Long Beach 2012 Discussion Thread | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 04-08-2012 03:43 AM |
| Official 2011 Formula 1 Season Thread | Shevon | Other Vehicles & General Automotive Discussions | 22 | 05-17-2011 04:37 AM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
