Old 02-24-2013, 02:01 PM   #4677
Visconti
Drives: 05 STi
Originally Posted by Huehuecoyotl View Post
Where in Cali are you? I'm there on business, you at a shop?
I'm going to be all over
Visconti is offline
Old 02-24-2013, 03:03 PM   #4678
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Just landed in Cali..
Finished setting up all the automatic tune files, usdm , non-used
, pumpgas, e85, e70
Sweet!!! Can't wait to try it out. Thanks john for all the hard work you put in for your customers!!
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline
Old 02-24-2013, 03:07 PM   #4679
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by djliquidsteele View Post
Have you flashed since you got the new license?
Nope, I figured I wouldn't be able to since the flash count is at 0.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline
Old 02-24-2013, 04:18 PM   #4680
djliquidsteele
Drives: Scion FR-S
The flash count goes up as you flash. If you plugged it in, it should have put the new license on the ECU. Since you haven't flashed with the new license number, it says 0.
djliquidsteele is offline
Old 02-24-2013, 04:52 PM   #4681
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
My mistake, I should have said that license count is at 0.
Laika is offline
Old 02-24-2013, 05:34 PM   #4682
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Just did a quick comparison from my 93 tune to e70 tune 60mph-80mph in each gear.
93 octane e70
3rd gear 3.7 3.6
4th gear 4.8 4.5
5th 6.7 6.4
6th 9.3 8.0
* not sure why it took such a long time in 6th gear for the 93octane run.
Both runs were done on the same road but on difference days. I know it takes about a tank or two to be running on full e70 because when i filled up i still had about 10-12% pump gas still inside the tank and ive only done about 120 miles so far on e70. i tried a 0-60 and got 6.0 flat using torque app. On the next fillup ill try another run and see what numbers i get.
brichard0625 is offline
Old 02-24-2013, 06:32 PM   #4683
Visconti
Drives: 05 STi
93 octane e70
3rd gear 3.7 3.6
4th gear 4.8 4.5
5th 6.7 6.4
6th 9.3 8.0
Exit 15 on 95 is back to 85 !
Visconti is offline
Old 02-24-2013, 06:36 PM   #4684
brichard0625
thats where i filled up at yesterday. So should i throw the e85 map on instead? or wait till i fill up again and then go back to e85?
Old 02-24-2013, 06:38 PM   #4685
Visconti
Drives: 05 STi
I forgot to call , just checked the ethanol content a few days ago.
Flash the e85 map in and get new data!
Visconti is offline
Old 02-24-2013, 06:42 PM   #4686
brichard0625
Ok ill do that tonight when i get out of work
Old 02-24-2013, 06:58 PM   #4687
djliquidsteele
Drives: Scion FR-S
Yeah thats normal/correct. Flash away.
Old 02-24-2013, 07:43 PM   #4688
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
You might be thinking of the same situation but when there IS a license on the ECU.
As I suspected, no luck
Laika is offline
Old 02-24-2013, 07:52 PM   #4689
djliquidsteele
Drives: Scion FR-S
ry flashing back to stock tune and then flashing using the new license/tune.
Old 02-24-2013, 11:27 PM   #4690
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Torque dip.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
