Old 02-23-2013, 06:13 PM   #4663
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by djliquidsteele View Post
So just flashed to the latest pump gas tune and took it for a spin and a couple wide open throttle pulls and logged. I have a couple questions and this is more to educate myself and to not hassle John for another update if its not necessary.
1) At WOT I notice AFR averages around 13.5. I seem to remember john saying something about these cars liking something like 11.8. Should I submit for an update or is this normal/correct?
2) I notice several places at partial throttle that there was a knock correction value of 5. Normal?
I'm still learning here, but my thought is if its running 13.5 is running a little lean still and causing a bit of knock.
Thanks for any help.
Did you give the ECU enough miles to finish its learning of the new flash?
Foobar is offline
Old 02-23-2013, 06:16 PM   #4664
djliquidsteele
Drives: Scion FR-S
No. Does it change that much? I know I usually notice an increase in power after 100 miles or so but wasn't sure if the things I listed were attributed to that.
djliquidsteele is offline
Old 02-23-2013, 06:21 PM   #4665
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Just finished sending out 100 tune files.
I still need to work on the automatic tunes and all the non-usdm stuff.
Ill have that done early next week.
And Ill update the pumpgas map notes shortly.
Hope everyone enjoys the update...
Even the pumpgas map update is badass.
John
I don't mean to be ungrateful but my tune file doesn't work. Getting this message:
post_break is offline
Old 02-23-2013, 06:51 PM   #4666
fenton
That is positive knock correction and is good. Mine does the same thing every time I go wot. Its a decrease or negative value in knock correction that you have to worry about.
Someone please correct me if I am wrong.... @Visconti I'm looking at you because this is something I wondered about too
Sent from my Galaxy Nexus using Tapatalk 2
fenton is offline
Old 02-23-2013, 08:28 PM   #4667
M1K3
M1K3's Avatar
Drives: vrooom...
Did you update ProECU before flashing? If not try doing that first and then try flashing the car. If you are still having issues submit a ticket.
M1K3 is offline
Old 02-23-2013, 09:36 PM   #4668
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Originally Posted by Carwhisperer View Post
Put about 40 miles on the e70 tune. Starting to notice the same. Finally feels like a stronger version of pump gas tune.
Just did about 100 miles on the e70 tune so far and it feels great. I dont think ill be changing back to pump unless theres a dealer visit. Car starts up right away, Linear power in every gear, and something that i noticed is that the fuel gauge isnt dropping as much as when i was on e85 tune.(not sure yet). And i read someone was getting error, you have to update proecu first or you will encounter some issues.
brichard0625 is offline
Old 02-23-2013, 10:32 PM   #4669
Carwhisperer
Drives: A lot of supercars.
I wish my 18.2mpg could say the same. Haha. Tonight the car pulled harder than ever on the e70. About 40F outside seems to be the perfect temperature with my michelin super sport tires to grab every gear.
Carwhisperer is offline
Old 02-23-2013, 10:38 PM   #4670
post_break
post_break's Avatar
Everything worked on the other car, we currently have 2 cars on one cable and the other rom worked without a hitch. It seems my rom file is messed up.
Old 02-23-2013, 11:45 PM   #4671
Visconti
Drives: 05 STi
I've put a lot of time in these calibrations so its nice to hear people are enjoying them.
Anyone having a problem needs to make a ticket, posting here in about it doesn't speed up the process.
John
Visconti is offline
Old 02-24-2013, 09:44 AM   #4672
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Maybe one of you guys can help me out with this issue as I think johns busy today
John had to get me a new tuning license so I applied ecutek update to get the license, I applied the license update, and now when I go to the "license & feature information" menu, it still says I have a flash count of 0.
Yes I applied the correct license update. Is there an in between step I'm missing here?
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline
Old 02-24-2013, 09:46 AM   #4673
djliquidsteele
Drives: Scion FR-S
Have you flashed since you got the new license?
Old 02-24-2013, 01:18 PM   #4674
Visconti
Drives: 05 STi
Just landed in Cali..
Finished setting up all the automatic tune files, usdm , non-used
, pumpgas, e85, e70
Visconti is offline
Old 02-24-2013, 01:49 PM   #4675
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
, pumpgas, e85, e70
Where in Cali are you? I'm there on business, you at a shop?
Huehuecoyotl is offline
Old 02-24-2013, 02:01 PM   #4676
Jeong
Drives: pet dragon
John
So would we need to file a ticket or would we receive one automatically for the pump gas
Jeong is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
