Old 05-23-2014, 05:49 PM   #4621
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Originally Posted by Michael Blue View Post
Tried, no luck.
Thanks!
http://www.ft86club.com/forums/showthread.php?p=1708981
Try starting there
mikalem is offline   Reply With Quote
The Following User Says Thank You to mikalem For This Useful Post:
Michael Blue (05-23-2014)
Old 05-23-2014, 06:09 PM   #4622
Michael Blue
Drives: 1998 Audi A4 Quattro Sport 30v
Perfect, THANK YOU!
This confirmed the Cusco as well, which was top of my list.
Michael Blue is offline   Reply With Quote
Old 05-24-2014, 01:53 AM   #4623
ntaphse
Drives: beater
Originally Posted by Pekingduck View Post
What are people boosting with 69mm pulley? I am seeing 15 psi on my gauge and I wondering if it normal
Do you have the p3cars gauge with an along boost sensor? Mine was showing 20 psi and I said wtf, looked into it and realized there is a calibration you have to run through.
ntaphse is offline   Reply With Quote
Old 05-24-2014, 02:14 AM   #4624
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by xxscaxx View Post
don't drill it - completely unnecessary. Do like Dustin stated, loosen the other bolts and it should be able to wiggle out and be removed with a pick/magnet.
You won't be able to get a drill back there anyway so you would have to take the supercharger out - so even then just unbolt the back elbow and simply unscrew that thing out. Unless that bolt is cross threaded theres no way it should not come out easy.
Innovate sent me a huge bag of bolts when I bought my intercooler kit. I wonder if they want you replacing them in the event of having to remove the originals.
Edit: Nick just saw that you had a shop replace your blower. I can bet you they didn't torque those down with a torque wrench lol. Either way they seem to break easy. Call Innovate and tell them you had a bolt break, they should send you new ones. If not hit me up and i'll send you a few.
Everyone says their customer service sucks but every time I've called they have been super helpful and sent me out whatever I needed.
I'll send Innovate a email in the morning. Thanks!!! I believe they torqued them down and this one prob had the head twist and the tech just left it... Then after a year the head simply broke off under vibration/heat is my assumption. The shop says "you work on your own car" yada yada yada. They offered to fix it if I bring in the blower..... But i'm just going to do it myself. Hopefully by just twisting the elbow it will come un-done!
Cheers
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-24-2014, 03:51 AM   #4625
Pekingduck
Drives: 4 wheels
I am running HKS mechanical gauge.
Pekingduck is offline   Reply With Quote
Old 05-24-2014, 07:07 AM   #4626
mikalem
mikalem's Avatar
Cheers
I had the head snap similar to yours yesterday - had to completely unbolt the back elbow to and use it to back out the bolt - thankfully I had the manifold completely off the car. Good luck! I would recommend getting new bolts from either innovate, or sourcing them yourself and not reusing them once you get the elbow off though.
Old 05-24-2014, 08:09 AM   #4627
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Delicious Tuning 8.58
Got some remote time with @DeliciousTuning, to dial in new revision.
Latest revision is Unbelievable, smooth and super power.
Here is dyno chart comparing previous tune to latest revision.
70mm pulley on 95RON
252whp 210 ftlb on a extremely tough dyno
Ryan86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Ryan86 For This Useful Post:
Calum (05-24-2014), DeliciousTuning (05-24-2014), Lawnik (05-24-2014)
Old 05-24-2014, 08:28 AM   #4628
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
This is different from 8.58?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
xjohnx (05-24-2014)
Old 05-24-2014, 02:35 PM   #4629
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
X2
Dustin is offline   Reply With Quote
Old 05-24-2014, 02:50 PM   #4630
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Dustin View Post
X2
I asked @DeliciousTuning about that this morning and was told that it's the 8.58 that everyone is getting.
The Following 4 Users Say Thank You to xjohnx For This Useful Post:
CK_Bladesmith (05-24-2014), DeliciousTuning (05-24-2014), Dustin (05-24-2014), mikalem (05-24-2014)
Old 05-24-2014, 06:28 PM   #4631
Michael Blue
One last question and I'll leave you guys alone until I have a kit here...
How is the 6AT holding up with this?
I'm looking at the intercooled State 2 Complete and would be adding UEL headers, overpipe and cat-back.
Use would be mostly daily plus occasional track time.
Thanks!
~M
Old 05-25-2014, 02:31 AM   #4632
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
I have the stage 1 innovate supercharger setup. First off, I like the pull and have faith in my tuner, however I have some issues with my tune that I would like to find out if it is a typical effect of this particular kit.
I have a low end wall I hit just below 3k rpm in any gear that I have been told by my tuner is due to my lack of intercooler. I have not seen anyone else post about this with the stage 1 kit, so is this normal? litterally the car will be accelerating smoothly, then it will bog a little and then take off. It is frustrating because the car does not accelerate smoothly the way I expected the SC to or remotel close to the way it did stock.
I have another issue. I can no longer accelerate the same way I used to be able to in sixth gear. I would like to be able to. Literally the car bogs alot.
also my 6th gear cruise control is ony getting me 28mpg
My tune has come a long way both on and off the dyno but I feel like it is just not hitting the mark. Does anyone else have these issues with the stage 1 kit? I am trying to determine if it is the kit or the tune just isnt there yet?
I am on 93 octane, have the stock pulley, and I am running an innovate lc1 that I am logging through my ecu via the second 02 sensor input, on ecutek.
Thanks in advance.
Maverick22 is offline   Reply With Quote
Old 05-25-2014, 07:15 AM   #4633
mikalem
mikalem's Avatar
Thanks in advance.
I just upgraded to the innercooler setup, ran the the stg1 setup for about two months and I can say my very first tunes had a little of what you were describing but after a revision it was cleaned up. Who is your tuner?
Old 05-25-2014, 11:28 AM   #4634
Powersfrs
Drives: Frs
Thanks!
~M
I have 6AT stage I on e85 n with deliciuos latest 8.58 tune n wow it's amzing ....I'm having no problem with the transmission
Powersfrs is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
