#4621 |
Drives: 2020 DGM BRZ Limited
http://www.ft86club.com/forums/showthread.php?p=1708981
Try starting there Sent from my Nexus 5 using Tapatalk |
| The Following User Says Thank You to mikalem For This Useful Post: | Michael Blue (05-23-2014) |
#4622 |
Drives: 1998 Audi A4 Quattro Sport 30v
Perfect, THANK YOU!
This confirmed the Cusco as well, which was top of my list. |
#4623 | |
Drives: beater
Do you have the p3cars gauge with an along boost sensor? Mine was showing 20 psi and I said wtf, looked into it and realized there is a calibration you have to run through. |
#4624 | |
Drives: 2013 Asphalt FRS
I believe they torqued them down and this one prob had the head twist and the tech just left it... Then after a year the head simply broke off under vibration/heat is my assumption. The shop says "you work on your own car" yada yada yada. They offered to fix it if I bring in the blower..... But i'm just going to do it myself. Hopefully by just twisting the elbow it will come un-done! Cheers
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#4625 | |
Drives: 4 wheels
Pekingduck's Build thread http://www.ft86club.com/forums/showthread.php?t=5717
#4626 | |
#4627 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Delicious Tuning 8.58
Got some remote time with @DeliciousTuning, to dial in new revision.
Latest revision is Unbelievable, smooth and super power. Here is dyno chart comparing previous tune to latest revision. 70mm pulley on 95RON 252whp 210 ftlb on a extremely tough dyno Last edited by Ryan86; 05-24-2014 at 09:10 AM. |
| The Following 3 Users Say Thank You to Ryan86 For This Useful Post: |
#4628 | |
Drives: Raven FR-S
This is different from 8.58?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
| The Following User Says Thank You to CK_Bladesmith For This Useful Post: | xjohnx (05-24-2014) |
#4629 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
#4630 |
Grip>Slip
I asked @DeliciousTuning about that this morning and was told that it's the 8.58 that everyone is getting.
| The Following 4 Users Say Thank You to xjohnx For This Useful Post: |
#4631 |
One last question and I'll leave you guys alone until I have a kit here...
How is the 6AT holding up with this? I'm looking at the intercooled State 2 Complete and would be adding UEL headers, overpipe and cat-back. Use would be mostly daily plus occasional track time. Thanks! ~M |
#4632 |
Drives: 2013 Rocketbunny GT86
I have the stage 1 innovate supercharger setup. First off, I like the pull and have faith in my tuner, however I have some issues with my tune that I would like to find out if it is a typical effect of this particular kit.
I have a low end wall I hit just below 3k rpm in any gear that I have been told by my tuner is due to my lack of intercooler. I have not seen anyone else post about this with the stage 1 kit, so is this normal? litterally the car will be accelerating smoothly, then it will bog a little and then take off. It is frustrating because the car does not accelerate smoothly the way I expected the SC to or remotel close to the way it did stock. I have another issue. I can no longer accelerate the same way I used to be able to in sixth gear. I would like to be able to. Literally the car bogs alot. also my 6th gear cruise control is ony getting me 28mpg ![]() My tune has come a long way both on and off the dyno but I feel like it is just not hitting the mark. Does anyone else have these issues with the stage 1 kit? I am trying to determine if it is the kit or the tune just isnt there yet? I am on 93 octane, have the stock pulley, and I am running an innovate lc1 that I am logging through my ecu via the second 02 sensor input, on ecutek. Thanks in advance.
Rocketbunny Registry
http://www.ft86club.com/forums/showthread.php?t=61282 My Build thread http://www.ft86club.com/forums/showthread.php?t=44226 |
#4633 | |
#4634 | |
Drives: Frs
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
