Old 04-12-2016, 12:06 AM   #449
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by rookie View Post
As promised, pics of the STI axleback installed. The size is similar to the OEM and looks like it should clear. If you need more pics or a specific angle, let me know.
I see no reason why it won't fit .
VerusEric is offline
Old 04-13-2016, 04:46 AM   #450
cawith
Drives: Toyota GT86 6M/T
Originally Posted by VeloxEric View Post
This is a difficult question to answer as one person's definition of beneficial is another personal superficial.
The diffuser will do all the things you stated (increased fuel economy, reduction in lift, better stability) and it will do them without the front splitter. The front splitter and rear diffuser work well in harmony but do not need one another to work.
That is correct, the front splitter race upgrade is recommended at speeds greater than 130 KPH due to the forces it sees.
Great, that was exactly the info I was looking for. Do you know by how much exactly the angle from the tires up to the bumper/exhaust decreases with the non-aggressive version? Thinking if there will be any problems going over bumps or up steep driveways..?
I'm really interested in this now.
Do you have any distributors in Europe or is the splitter only available through FT86SF?
cawith is offline
Old 04-13-2016, 10:53 AM   #451
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
Ordered last night, can't wait to get it!
rookie is offline
Old 04-13-2016, 12:23 PM   #452
VerusEric
VerusEric's Avatar
The strakes are the lowest point and when properly installed are near horizontal with the road surface (negating rake).
When installed in the absolute lowest position, the strakes are around the same height as the bottom of the differential.
We currently do not have a European shop; however, we're looking for one.
Old 04-13-2016, 01:10 PM   #453
cawith
Okay, so ground clearance shouldn't be a problem at all...
I guess you aren't close to finding a European shop? Would make it a lot easier than ordering from the states...
cawith is offline
Old 04-13-2016, 01:47 PM   #454
johan
Drives: '14 981CS, '99 NB1
Even with the aggressive one, I've never scraped the strakes. And I regularly go in/out of some excessively steep / arc'd parking lots / street intersections / speed bumps.
johan is offline
Old 04-13-2016, 05:52 PM   #455
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
and you haven't scraped? That's a good sign do you think it ever would? or it would if the car was pretty lowered?
Instagram: trevor.parque
MisterSheep is offline
Old 04-13-2016, 05:54 PM   #456
johan
I take care when I go through a weirdly arc'd parking lot to street transition - I go slow. My car is stock height. Over large speed bumps and stuff, I gun it - zero fucks given.
If the car was .... _low_ - I'd imagine it could hit. But I'm not a fan of low, so again.... zero fucks given.
johan is offline
Old 04-13-2016, 06:05 PM   #457
MisterSheep
Killed Scion
Alright I'd just have to look at the clearance I have in the rear with the current setup I'm at. The aggressive version looks sweet and reminds me of the diffuser off the TRD griffon.
Looking to see if any lowered guys scrape the diffuser when dailying the car? Would almost consider just taking it off for daily use and then place it back on when going to track.
Old 04-13-2016, 06:29 PM   #458
DAEMANO
Time Traveller
Answer from a lowered guy (1.4" rear 1.6" front) and with the aggressive version.
If you can scrape the front, you can scrape the rear with the aggressive version. So, dog walk (approach diagonally so that one wheel is in/on the dip/bump at a time) over them speed bumps and dips, go slowly. Chances are you won't scrape either the front or back. If you do scrape, since the scraping is on the bottom of the strake, it's never seen. The mounting points have some give (vertically), so you won't break or bend the diffuser either. All of these design considerations Velox did a great job with.
DAEMANO is offline
Old 04-15-2016, 10:05 AM   #459
rookie
rookie's Avatar
The rear diffuser should be waiting for me when I get home!
rookie is offline
Old 04-18-2016, 10:59 AM   #460
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Installed the tunnel covers yesterday
Perfect fitment and clearance with the Dezod catback. 130 mph track testing in two weeks!
ATL BRZ is offline
Old 04-18-2016, 12:46 PM   #461
churchx
churchx's Avatar
Drives: 2014 GT86
Next/last step for car underside for completeness would be creating rally skid plate instead of splitter . These tranny tunnel covers .. are they some new product? First time noticing them mentioned.
churchx is offline
Old 04-18-2016, 02:12 PM   #462
ATL BRZ
ATL BRZ's Avatar
http://www.ft86club.com/forums/showt...19#post2471819
ATL BRZ is offline
Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory naikaidriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 02-28-2017 02:48 PM
Single-Exit Exhaust Diffuser/Hole Problem... Solution! Anthony Cosmetic Modification (Interior/Exterior/Lighting) 75 10-13-2016 07:40 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 01:41 AM
DriveWay Labs Rear Diffuser - FT-86 SpeedFactory FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 435 01-15-2015 07:20 AM
