View Poll Results: What model name will the FT-86 be marketed under?
Celica 64 30.62%
Corolla (Levin and Trueno included) 25 11.96%
Sprinter 20 9.57%
Other (leave a comment!) 100 47.85%
Voters: 209. You may not vote on this poll
Old 03-12-2011, 09:39 AM   #449
Matador
hashiryu
Drives: Mk4 Supra
Originally Posted by NESW20 View Post
V6s are only better than I6s for packaging purposes. that's it.
Indeed. That's exactly why I6s are pretty much a dead breed.
Matador is offline
Old 03-12-2011, 11:37 AM   #450
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by OldSkoolToys View Post
Well BMW isn't Japanese...there's a reason the I6 is completely dead in Japan.
I think the main reason given was that V6's allow you to snub the body, lowering the size and weight of said cars, and making it easier to reach emission/MPG standards in Japan.
Could be mistaken though, Ichi probably knows better than I do. All I know is that I6's are gone from the Japanese market, and there's nothing we can do about it.
And I would totally say Toyota should make another I6. I LOVE I6's, they are by far much better than V6's, imho. Its just sad knowing that it WON'T happen.
It's pretty much what other have said.
ichitaka05 is offline
Old 03-12-2011, 01:36 PM   #451
Aki
Drives: '96 beater Corolla
BMW makes extensive use of I6s, especially turbocharged. Their N/A N52 is one of my fav I6 engines, too bad it's getting phased out.
Aki is offline
Old 03-12-2011, 04:06 PM   #452
Dimman
Kuruma Otaku
Dimman's Avatar
1JZGTE is mine (in my car). But from a pure overall performance point, I have dirty thoughts of putting a 3MZFE (3.3L aluminum closed deck block from Camry, ES300, et al.) into a Supra.
The V6 advantages I see are these:
- Shorter crank can be more rigid which is better for high rpm reliability, possibly lighter for the same strength.
- Less weight on the front axles.
- Allows for larger bore. For example if they wanted to make a 3JZ with the same 92mm bore as the 3MZ while keeping the cylinder wall thickness between them the same, the motor would be 36mm longer than the original 86mm bore 2JZ. Which gets back to the weight over the front issue.
- With the larger bore you have more flow/power potential due to valve and port sizes.
I personally believe that a properly built 3.3L 3MZ could out-power a 3.4L 2JZ stroker at the same boost levels. Now take into effect the reduced weight and improved balance, on a road course it would be an absolute embarrassment for the 2JZ car. These thoughts would be considered blasphemy in a Supra community.
Because titanium.
Dimman is offline
Old 03-12-2011, 09:49 PM   #453
Matador
hashiryu
Drives: Mk4 Supra
BMW and Holden (I think) are pretty much the only companies left that produce I6 engines, hence, a dead/dying breed.
Matador is offline
Old 03-12-2011, 09:53 PM   #454
Dimman
Kuruma Otaku
Dimman's Avatar
I think it's Australian Ford that still does, and Holden's all about the LSx now.
Because titanium.
Dimman is offline
Old 03-13-2011, 10:32 AM   #455
Calais
Calais's Avatar
Drives: 2012 BRZ, now track car and GRC dai
right you are, and theres rumors that the LXa is going to end up in a holden soon
For a pure sports car, it must be internal combustion-Mazda Motor Corporation’s sports car chief Nobuhiro Yamamoto
Calais is offline
Old 03-13-2011, 10:51 AM   #456
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Soon being late 2013 though.......
FT-86GOD is offline
Old 03-13-2011, 10:54 AM   #457
Calais
Calais's Avatar
cant remember the date i read it in this months MOTOR mag which also had the ft86 MkII in it and they said that the only major changes were the front(LEDs, bigger intake), side(vent behind wheel arch) and the mirrors being bigger, didnt even mention the rear light which was the biggest fkn change of the whole car!!
Calais is offline
Old 03-13-2011, 11:01 AM   #458
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
I better go get motor mag then LOL...... What does is say about when FT will hit Australia?
FT-86GOD is offline
Old 03-13-2011, 11:14 AM   #459
Calais
Calais's Avatar
just 2012 from memory no month or period during the year but im guessing late
Calais is offline
Old 03-14-2011, 02:22 AM   #460
almualim
Drives: E46 BMW 325i + '99 Camry LE
Probably celica. Its meant to fit that segment, and Celica is a well known name.
almualim is offline
Old 03-15-2011, 05:08 PM   #461
Allch Chcar
Drives: N/A
Okay so even if Toyota reuses a dead car name or Subaru names it stupid monkey we just call it the Ichi-Nii 1-2. Why? Because it's the big brother .
So it's gimmicky but I like it better than referring to it as that "dead car name" :/.
Allch Chcar is offline
Old 03-15-2011, 05:17 PM   #462
aliphian
Dreamer
aliphian's Avatar
Drives: Nutless Grocery Getter
I think it will be a new name. They want something that will draw attention which means the name can't be related to anything produced in the last 10 years since all of those cars are boring. I would like the name Levin though.
aliphian is offline
Toyobaru joint project, but who's manufacturing / designing what? VisciousGXR Scion FR-S / Toyota 86 GT86 General Forum 78 08-31-2014 04:28 PM
Spy Shots of 086A toyobaru coupe test prototype on the track MR2fan FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 05-08-2014 10:04 AM
New Toyobaru Subaru 216a spy photo from Orange County USA! ftw-86 BRZ Photos, Videos, Wallpapers, Gallery Forum 20 02-28-2010 03:05 PM
