Old 08-22-2013, 05:06 AM   #435
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
SprintHart CPR 16x7 +35 Wheels + Tyres..
My latest acquisition.
My good buddy is selling his SprintHart CPR 16x7 +35
I had been contemplating buying a separate set of wheels for track work soo... jumped on these. They come with some Federal tyres on them, but I'll prob change up to some 225/50-16in tyres for track work
Some additional info here: http://honda-tech.com/showthread.php?t=2307346
JDM KWALITEE
EDIT: Just checked the weight of these off wheelweights.net...
"Racing Hart CP-035R .. Forged .. 16x7 .. 10.8lbs 4.898kgs"
:happy0180:
stevo_12v is offline   Reply With Quote
The Following User Says Thank You to stevo_12v For This Useful Post:
bestwheelbase (08-26-2013)
Old 08-22-2013, 06:40 AM   #436
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Good god that is light. Score!
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 08-25-2013, 05:27 AM   #437
stevo_12v
Japanese Bride
Bought something today..
Old 08-25-2013, 07:54 PM   #438
DarkCard
Drives: Asphalt Scion Frs 6MT
Do you have a link where you purchased the mats?
DarkCard is offline   Reply With Quote
Old 08-26-2013, 12:53 AM   #439
stevo_12v
I contacted Jesse Streeter for them. He deals mainly with Aussie/Japan.
His website: http://jessestreeter.com/
DarkCard (08-26-2013)
Old 08-26-2013, 01:04 AM   #440
stevo_12v
My Daily Acquisition(s)
Need to buy new seats. So I also require that special socket tool to remove the E10 Torx Security bolt that secures the OEM seats.
I bought them from "MALz" for the low price of $6.99. Not too bad!
Also bought these over the phone from VELO Racing Australia. Just under $800 for the GP-90 seat(pic below) including aluminium side mounts(500g) and freight.
The seat weighs 7.6kg, so I think at least a 9/10kg weight saving over the stock GTS heated seats(20kg). I wanted originally to get the "Milano" seat, but that is a 'bottom mount', not a 'side mount' like the other seats. Ie you aren't able to change the incline of the seat.
Seat should be arriving by Friday in time for my local DE/Skidpan/Track event.
Old 08-26-2013, 01:20 AM   #441
bestwheelbase
Drives: 1985 P-Type
Fantastic choice! Bigger is not always better.
The Following User Says Thank You to bestwheelbase For This Useful Post:
stevo_12v (08-26-2013)
Old 08-26-2013, 04:54 AM   #442
Nikkojoe
Nikkojoe's Avatar
Drives: IS200/AE86 2dr/White 86 GTS 6MT
You getting airbag cancelers for the seat Steve?
Hope it rains on Sunday
Nikkojoe is offline   Reply With Quote
Old 08-26-2013, 06:07 AM   #443
stevo_12v
Yup!! Going to go to JayCar and get some 3k3 Resistors
http://www.subyclub.com/topic/5777-d...-seat-install/
hahaha I hope it rains too!! I'll have the advantage with new PS3's on the CP-R's
Old 08-27-2013, 03:15 AM   #444
stevo_12v
My latest daily acquisition..
New 8.8 grade HTS tow bolts. M16x1.5 30mm threaded-to-da-head bolts. I would have bought Titanium, but I was keen to get my strap fitted asap.
Old 08-27-2013, 07:52 AM   #445
stevo_12v
CP-R's fitted with brand new PS3 225/50/16 :D
Bought some Michelin Pilot Sport 3's from Kaltyre in Redcliffe today. $225 per corner, supplied and balanced(I do the fitting myself now because I'm so anal about people working on my car - plus its MUCH QUICKER to just drop off the wheels, and come then back the next day(or couple hours) to pick them up instead of waiting around. I'd still recheck and re-torque the lugs anyway).
The tyres are 225/50/16, giving them a nice chunky race-look(hey I'm a ricer at heart sometimes ) Interestingly enough.. the weight of my WedsSports TC105N plus tyre is actually LIGHTER than the weight of my SprintHart CP-R plus tyre>
Weds + 235/45/17 PS3 = 17.8kg
CPR's + 225/50/16 PS3 = 18.6kg
Maybe be the possibility of a heavier rubber compound? I am not sure, regardless the ride on the 16's is nice and SMOOOOTH(or I must be getting old). And funnily enough, the acceleration from the 16's is slighty faster(although they are a heavier wheel/tyre combo). This may be due to the fact that the main 'mass' of the wheel is centered towards the center, so less centrifugal forces needed to act to spin the wheel.
I will nevertheless have to look into using a much lighter rubber compound(and that is suitable for track) for the next set. I think I will use these as my daily's as the ride is that comfy, and the acceleration feels slightly faster too, and I don't have to worry about kerbing the wheels.(I'll probably get the CP-R's refinished when the PS3's wear out, get it done properly)
Here's a crappy pic from my GS2 with them fitted at work:
I did the obligatory tyre paint pen writing:
EDIT: Uploaded some more pics below
Old 08-27-2013, 04:51 PM   #446
stevo_12v
TRS Tow Strap Installed
Since buying the nuts from the previous post I thought it'd be a good idea to install the TRS tow strap after 5-6 weeks of receiving it. Track day coming up this Sunday so might as well install it. Hope to never use it though.
Alot of stuffing around with cutting the foam with the box cutter. Spent a good 15mins cutting the foam so the triangular bracket would fit. If your anal about the foam being cut perfectly you can remove the bumper, but I did it this method as its quicker and easier for me.
Here is a photo of the foam that you need to cut. Credit to @JD86 for the pic which I cropped
** Careful you don't cut the tab for the front tow hook cover fascia, I almost cut it straight across **
In the end, I discovered I bought the wrong damn bolts
I need 60mm long bolts instead of 30mm. I'll update this post once it's all installed correctly..
Almost cut the hook that retains the front fascia.
- - - - - UPDATE - - - - -
Went to COVs Fasteners this morning before heading into work. This time I bought three types of bolts of various lengths: 50mm, 60mm and 70mm. All M16x1.5 metric pitch. Grade 8.8 S/Steel.
A comparison of the bolts:
30mm on the left, 50mm, 60mm, 70mm and Original Tow Hook
I ended up using the 50mm bolt
Finally Installed
Tow flap hanging out of the hook recess
TRS Tow Strap all snuggled up and shoved back into the recess.
The Following 3 Users Say Thank You to stevo_12v For This Useful Post:
djdnz (08-30-2013), GT86drifter (09-15-2013), melon (08-28-2013)
Old 08-30-2013, 01:53 AM   #447
stevo_12v
VELO Racing Seats(ADR Approved)
My seats just arrived an hour ago.
Need to shoot off to JayCar and buy some 3.3Ohm resistors to fool the Airbag sensors though.
Some piccies:
Well packaged
Green bubble wrap contains the aluminium side mounts for the seat
Rails are aluminium, I opted for the UNDRILLED base as I am using BRIDE rails.
I have to drill them so they fit.
djdnz (08-30-2013)
Old 08-30-2013, 10:30 AM   #448
stevo_12v
VELO Seat Install - Attempt #1
Well.. took me about an hour and a bit of mucking around. Around 30 mins undoing the clips/sensors under the seat. And around 30 mins stuffing around trying to see which bracket(VELO or BRIDE) that I could use with the seats.
Installed the seats using the supplied BRIDE right angled steel rails, but that causes the seat mounting width to go over by 15mm-20mm.
Installed the seats using the supplied VELO right angled aluminium rails, but that causes the seat mounting width to go under by 15mm-20mm.
I might have to re-adjust the width of the original bride rails with bracket tonight to their most narrow position(I only fitted the seat to the BRIDE rails as a 'test' fit - I didn't adjust the width of each one as I was running out of time and had to go to work.)
Other than that. I might have to do a hybrid of VELO Aluminium rail on the left side, and BRIDE rail on the RIGHT side( The rail slider adjustment actually hits the VELO side mount bracket which is quite unfortunate ).
Some pictures.
MAKE SURE YOU UNPLUG THE BATTERY FROM THE CAR
One of the most trickiest part of the seat change over is unclipping the sensor/power wires from the seat harness.
It really helps if you undo the black clip holding the bulk of the 3 wires first too, will give you more play to unclip the 3 clips.
See annotated picture below..
YELLOW Clip is for the Airbag sensor
WHITE Clip is for the Seatbelt sensor
BLUE Clip is for the Heated Seats
All clips are undone, seat is able to be removed.
A good idea is to have a piece of plastic or carpet or towel or something to stop you from accidentally scratching or damaging your drivers/passenger side door sill(see picture)
Seat completely removed with the 3 plug harness lying on the floor. Would be a good time to vacuum the carpet too..
3.3 Ohm resistor to fool the Airbag sensor(Yellow Clip). If you have a higher wattage resistor you can just plug them in straight away, but I had some lower wattage ones so I had to double fold the wires so they would sit nice and tight in the connector.
I was going to use some blue-tac/plasticine to hold the resistor secure, but didn't have any. I made do with some tissue and some plastic tape.. nice quick and easy dodgey styles.. I'll re-do it after track day. Was just rushed for time.
Here is the Drivers Seat. You will have to remove the side seatbelt buckle AND the seat belt sensor. This needs to be transferred to the new seat. Most of the time spend is unclipping the clips and trying NOT to damage them. The big round plastic panel to the right of the nut(holding the buckle assembley) can be pried up and popped out to remove the wiring harness for the belt buckle.
Test fit of the left side seat with the original belt buckle(with seatbelt sensor installed)
Australian Made
AUSSIE AUSSIE AUSSIE!!
VELO Racing ADR Compliance sticker. This is the main reason I have chosen these seats. They are bucket racing seats, but are fully ADR approved. Ie.. you cannot get defected for these 'aftermarket seats'.
APS86 (08-30-2013), djdnz (08-30-2013), mike_ekim1024 (08-30-2013)
36yroldvirginscar, keyboardwarrior, trd
Dumb idea to get auto tranny? tinnyms3 BRZ First-Gen (2012+) — General Topics 85 06-22-2012 05:22 PM
After this last winter is RWD such a bad idea Nate219BRZ Great Lakes 3 03-14-2012 05:03 PM
Any Idea of U.S. Pre-Order Numbers? markemark24 Scion FR-S / Toyota 86 GT86 General Forum 1 02-21-2012 12:29 PM
I have a great idea! ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 56 07-24-2011 11:14 AM
Marketing Idea for the FT-86 JDMluv Scion FR-S / Toyota 86 GT86 General Forum 21 05-02-2011 05:29 AM
